Question about Fuji FinePix S1000FD Digital Camera
What does the yello camera with the yello
What does the yellow camera with the yellow exclimation point to the left mean? how do i get rid of it. it was not there for some time, showed up and no matter what setting, etc is changed, it does not go away.
I cant change the flash using the flask icon arrow on the back screan anymore.
  • 244 Answers
I have an S1000fd and to get rid of the yellow camera icon with the exclamation mark next to it I pushed the button on the side of the flash to pop the flash up. Its a low light level indicator basically.
Posted on Oct 10, 2009
    President:
  • 423 Answers
The yellow camera icon means you have the camera set in "hi speed shooting" mode (check index in manual...page 82 I believe). The exclamation point (sideways?) is the "white balance" indication (try page 81). Sounds like during some poking around the menus, a couple of things have been set away from the "normal" settings. Go to the setup menu and find "reset". That should put things back to the factory defaults settings.
Posted on Aug 10, 2009
On a Fujifilm fine pix z : to remove the yellow camera icon with the yellow
exclimation mark to the left of it, simply press the flash selector button
with the lightning bolt icon on it a couple of times to select another flash
setting. The yellow camera icon is "supperssed flash option" press the
lightning bolt icon button twice to select "auto flash".
Posted on Oct 28, 2012
    Problem Solver:
  • 5 Answers
On the S1000 what it means is that you are currently taking a photo n a setting with a high risk of blurring. If changing settings (have you tried landscape (sport) setting?) then you might be able to fix the problem just by cleaning the lens and the indicator light (between lens and shutter button) basically play with it until you find a setting that best suites the situation. And if it continues to show up but your pictures are not showing up blurry then you can either learn to ignore it or send it in to be replaced (which doesn't seem necessary)
Posted on Aug 11, 2009
SOURCE:
What does yellow exclamation point light mean
YELLO and RED mean danger - clogging, not brush turning, overheating, .... it is time to RESET -- turn it all off and let it sit for half hour - that is what the manual says, check the brush that is not clogged up and check the inlet to the hose and where the hose goes into the body from the head unit where the brush is - make sure those not clogged either. Turn it on, push the RESET button on left back side of head unit by the switch that changes height. The reset button is like a circuit breaker - stops unit when overheats, starts when reset. Yello is ERROR, and fix it before it turns red and stops all the way. Cheers!!!
May 31, 2014 | Electrolux EL8807A Precision BrushRoll...
Yello mechanical light on ,in dash averthing to go ok
have the codes read as it may be an engine service light that is pointing to a failure.
Mar 11, 2014 | 2003 Chrysler PT Cruiser
Need color list for factory stereo for 99 cutlass
Constant power orange switch power ground Yellow illumination Gray dimmer Brown antenna trigger antenna pink left front + tan -gray right front + light green - dark green left rear + Brown - Yello right rear + Dark blue - Light blue
Jul 29, 2011 | Car Audio & Video
I have a Fujifilm finepix S1600 camera and it has a yello camera symbol with an exclamation mark infront. I cant find out what it means, any thoughts?
The yellow icon is a warning that a slow shutter speed has been selected and to use a flash or tripod for the picture otherwise it could be blurry. An explanation can be found on page 27 and 28 of you user manual. A similar icon but in red and the letters AF will be seen if the camera has failed to auto focus.
Dec 26, 2010 | FUJIFILM FinePix S1600 Digital Camera
There is a yello light lit on my dash that has an exclamation point with wavy lines underneath. What does that mean?
I had this problem as well, I was told that the tires didn't have ample enough tire pressure.
May 20, 2010 | 2004 Mercury Mountaineer
Crystal eye webcam for acer aspire 6920G says camera not found
hey, I had the same problem, I've got an Acer Aspire 6920 and I swapped out Vista that was on it for Windows XP
I went to the link you posted but it just goes to acer.com
so I figured I'd try something
if you go to acer aspire 6920 drivers, you can only pick Vista and Windows 7, and not Windows XP
instead, pick 6530 drivers (older acer) and pick the Bison driver:
http://global-download.acer.com/GDFiles/Driver/Camera/CCD_Suyin_2.0.8.3.zip?acerid=633639858186446758&Step1=Notebook&Step2=Aspire&Step3=Aspire%206530&OS=V10&LC=en&BC=Acer&SC=PA_7
Install it (with or without installing the previous Crystal eye, doesn't matter, and it will work properly
Feb 25, 2009 | Acer Aspire 6920 Notebook PC
Exclimation point on dash
is it yellow, then it may be your low tire pressure warning
the spare is also monitored, so if all tires are okay then check the spare
Nov 24, 2008 | 2005 Toyota Highlander
Yellow cartridge problem
its a quarantee issue, go back to seller, brobably you need to change yello IU
Jun 07, 2008 | Konica Minolta Magicolor 5450 Printer
Lost yellow but "maintenance" gave no diagnosis
sounds like a clogged printhead but I would try the tech 3 to make sure. 800-474-6836
Apr 20, 2006 | HP DesignJet 10ps InkJet Printer
Fuji FinePix S1000FD Digital Camera Logo
7,981 people viewed this question
Top Fuji Cameras Experts
Steven Wander
Steven Wander
Azam Ali
Level 1 Expert
KJ Soni
Level 1 Expert
Are you a Fuji Camera Expert? Answer questions, earn points and help others
