Question about Sony Handycam CCD-TRV108 Camcorder
Cassette stuck on Hi8 hsndycam sony
Hello, I have Hi8 handycam sony, I think the cassete is stuck and now when I try to eject it, nothing opens, how can I fix this?
Please help, my email is [email protected]
    President:
  • 4,402 Answers
Take the battery out and turn selection switch to camera and then turn it off. Put the battery back in and its working again.
if that doesn't work try
Try smacking the side of the camera relatively hard with the palm of your hand. Eject the tape and reinsert. You may need to do this a couple of times.
good luck
please mark the post with a fixya
Posted on Mar 17, 2008
I hate you ctf1800 your solution is bogus
Posted on Apr 21, 2008
SOURCE:
Tape stuck
DIY remove Hi8 tape stuck camcorder Check this link as it might help out to remove the cassette.
Jan 23, 2014 | Sony Handycam DCR-TRV30 Mini DV Digital...
Handy cam hi8 dcr
Try removing the battery and charging it. Then put the battery back on the camera. This will reset the cassette system. The cassette should open or close depending upon what status it is in. Once you get the camera to eject fully, clean your heads with a dry head cleaner cassette for Hi8 video. If your camera is still eating tape, could be a broken pin or damaged heads.
Aug 26, 2013 | Sony Handycam DCR-TRV280 Digital Camcorder
Handycam Hi8 CCD-TRV81: There is a cassette in cam. Will no play, or FF, or reverse. Eject arrow flashing, but will not eject/open
Before i proceed, do you see any flashing triangle in the viewfinder?Any error message?
Thanks!!
Aug 25, 2010 | Sony Hi8 CCD-TRV138 Camcorder
My sony hi8 Handycam TRV 138 gives me a message reinsert tape What is wrong? do it need repair
The cassette is not being detected when the tray is landing. If the head is not spinning but you are getting the cassette ejected then it is a malfunction of the loading mechanism. Even if the tape end detection optocouplers are defective the fault could be so.If you can check this out then try and test the voltage before and after the cassette loads. there should be a change if not replace. check on the loading mechanism too. Hope this helps. Good day
Jun 28, 2010 | Sony Hi8 Cleaning Cassette / Head Cleaner...
HELP, I have borrowed an older camcorder from a friend. A sony Hi8 CCD-TR101 handycam. My child put the tape in backwards and now it wont eject. What should I do??
Tape can not be inserted backward in.It is impossible to to insert cassette inside video wrong way.
If it is not ejecting its eject switch might have got broken by physically pulling its cassette compartment outward before closing last time.
Its mini switch is very fragile in all sony models. so only way is to take to technician to bring it out.If i were you,I would buy used one from ebay at lower price than repairing.
May 07, 2010 | Sony Handycam CCD-TR87 Camcorder
I get an eject symbol and beep and error code c32:11, original issue was that it ate a tape
The error C 32:11 denotes for mechanical unsuitability, This problem appears when the improper insertion of the cassette been done, or lose cassette tape stuck,
In all these situations mechanical adjustment is required, You are suggested to please contact any expert for the mechanical adjustment.
Hope you will understand my sayings.
Thanks for using fixya.
Jul 11, 2009 | Sony Handycam CCD-TRV68 Camcorder
Cassette jammed after camera dropped
I think your ejecter motor is not working.temporarily open with any tool.
Dec 10, 2008 | Sony Handycam CCD-TRV107E Camcorder
Sony Handycam DCR-TRV19E Pal do not eject tape
I think, your camera requires new DV Mechanism replacement.
May 08, 2008 | Sony Handycam DCR-TRV33 Mini DV Digital...
Inserted cassete in wrong way in Sony camcorder CCDTRV68, not ejecting cassette Error codeC32:20
Sony camcorders C:31:23 error
good luck
Dec 24, 2007 | Sony Handycam CCD-TRV68 Camcorder
Cannot playback hi8 ccd trv107e pal
Dirty video head! Playback newly opened blank tape for five minutes, after that eject, reinsert, playback then eject again five times, these will serve as your video head cleaner, never use "video head cleaning cassette tape" for it will only damage your camera. Most camera has built in video head cleaner installed inside and activates only when you insert, initial play/rec, and ejects a tape. If the problem is still there you need pro fix then.[:0)
Jun 18, 2007 | Sony Handycam CCD-TRV107E Camcorder
Sony Handycam CCD-TRV108 Camcorder Logo
636 people viewed this question
Top Sony Video Cameras Experts
Ekse
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
