Samsung HLN617W 61 in. Rear Projection HDTV Television
Problem for Samsung HLN617W 61 in. Rear Projection HDTV Television
I don't know how a program it, since you change digital.
By mrrflash on Aug 10, 2009
Since you change to digital I can't get anything I don't Know how to program it.
Solution #1
posted on Aug 18, 2009
Not Rated)
kklare
Rank: Guru
Rating: 87%, 35 votes
So far as I know the HLN series does not have an ATSC tuner, thus no over the air (OTA) reception. You can probably still get a $40 coupon for an OTA ATSC to NTSC converter. Note that will NOT get you high definition (HD). With Dish you can get HD receivers that do get OTA ATSC both HD and SD. With Direct, no OTA AFAIK. With cable you would need a QAM tuner, not in your TV AFAIK to get clear channels as required for locals. Otherwise cable needs a Set Top Box for digital and scrambled channels although the standard definition (SD) non-scrambled channels work with your NTSC tuner. Too bad there seem to be no ATSC to 5-cable RCA or HDMI HD converters except Dish. -Ken
Was this helpful?
Yes
No
Popular Solutions for Samsung HLN617W 61 in. Rear
Questions and Unsolved Problems for Samsung HLN617W 61 in. Rear
Do you recommend Samsung HLN617W 61 in. Rear Projection HDTV Television?
Answer
Answer
brand new samsung lcd....flashing red light. flashes twice and won't turn on.
Answer
Samsung HLN617W 61 in. Rear Projection HDTV. Left side of screen has 4 inch section from top to... (More)
Answer
It is powering itself off.. It will turn back on ,but turns off again in a few minutes
Answer
have a 63" dlp model HLN617W and its making a grinding noise it turns on then shuts itself off... (More)
Answer
samsung flat screen keeps turning off...sound stays on...what is the problem
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Projection... Experts
Top TV Repairmen
in , TX
(316) 283-8873
(316) 838-0811
Authorized Warranty On Rca,Integrity In Sales...
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
