Question about RCA RT2500 System
No Audio With RCA RT2500
Have a problem with my RT2500 where I have no audio output. Found that fuses F106 and F107 (125v 1.5a). After replacing fuses the unit would not power on (standby light on). Pulled fuses and was able to power on with holding the standby sw and unplug and plug. Put F106 in and powered on and did not blow fuse but when I put in F107 it powered on and blew the fuse again. Looks like F104-F07 are on the outbut of the large xformer (behind small speaker board). Also noticed that the 6800uf 16v caps (beside heat sink) were bulging at the top although I had not other audio problems prior to this. Have not checked resistance between the windings of the xformer yet (with 60-70 hour work week have limited time). Haven't been able to locate a schematic for this product so any insite would be helpful. Thanks...
  • EmperorBOB Nov 28, 2007
    I have the same issue. Same two fuses blown.
    I also noticed I get no audio via the Headphone jack either (though the front panel displays Headphone when I plug in).
    If you figure this one out that'd be great as I loved the unit! I don't want to have to replace it. ;(
  • Anonymous Jan 07, 2008
    I have the same problem with no audio out. However fuses 106 and 107 are blown. Also the 6800uf capacitor is bulging. Thanks for the help on where to
    start looking but if you come up with a fix i would appreciate it.
    Gary
I had the same problem! My fix was replacing both fuses and both 6800uf 16volt
capacitors. You can get the fuses at radio shack and I found the caps on ebay
in canada.
Tinker
Posted on Jan 28, 2008
Hey EmperorBob, was reading a short across D119 & D120. pulled (I think it was) C139 and was able to get a good reading across the two diodes. reading a short on the cap (out of circuit). Still poking around. Will let you know if I find anthing else...
Posted on Dec 14, 2007
Set won't turn on. Was working fine last evening. Now nothing.
Reciever RCA RT2500 ' Techlore
www.techlore.com/forum/thread/11889/reciever-rca-rt2500
Aug 20, 2005 - 31 posts - ‎23 authors
hey ive got the rca RT2500 home theater system. .... won't power up) regardless of number of times I try to simulate a 120 V power flash (pulling plug .... My RCA receiverturns on but there is no sound...what can this mean?
Trouble getting sound from home theatre system with my ...
www.tomsguide.com/.../trouble-sound-home-theatre-system-appreciated....
Mar 27, 2013 - TV: Sony Bravia KDL-60EX645 Home Theatre System:RCA RT2906 ...-I've set the television, per the manual's instruction, to "Audio System" and "Audio Out: Fixed." This should allow the TV to turn off its internal speakers and switch .... SolvedI have F & D home theatre system, my rear speakers won't work.
Problems connecting surround sound to LCD TV... - Forums - CNET
www.cnet.com > Forums > TVs & Home Theaters
CNETJul 30, 2006 - Hey I have a 26" LCD TV from Polaroid and a Philips DVD home theatersystem. ... the Audio setup on the tv and TELL it to output the sound via the RCAcables ... However, you would normally turn off the TV speakers with a menu ... I just can't figure out why the TV audio won't play on the surround sound. Anynet+ - Home theater won't turn on with tv
Jun 11, 2015
TV won't turn on
Jun 10, 2015
Audio Return Channel Problem
Aug 23, 2011
rca tv no sound?????
Jan 1, 2006
More results from www.cnet.com
Jan 19, 2016 | RCA Audio Players & Recorders
Low Frequency Effect
Hi
in this case the audio is good but the output speaker is not working because you have blown fuse at the amplifier section thats why cant hear the sounds... check the amplifier section then check the fuse speaker protector.. replace a new fuses with the same rate....
Thanks....
Jan 24, 2008 | RCA RT2500 System
How come I don't get any sound from my RCA rt2500 audio receiver?
I've owned this receiver since the Summer 2001 and it worked well until the audio became intermittent several years later. Eventually, the unit was ON but all sound was dead. It turns out that there are solder joints that developed tiny solder breaks. These were found in the main power board on the large electrolytic capacitors and on the 7 power tab transistors that share a large square heat sink. Thermal cycling can cause microscopic solder joint breaks over years of use. After I re-soldered the broken joints the unit worked properly and is still in use in 2017. Consult a qualified electronics repair technician for the repair, which can be accessed via the removable panel on the bottom of the cabinet. Of course, be sure the unit is unplugged from AC power before starting your inspection and repair.
Aug 21, 2014 | RCA RT2500 System
Lost my remote for my RCA RT2500 Audio/Video Receiver and i cant turn it on because the power button is stuck on standby. I purchased another remote model CRK76 but it wont turn unit on. I also unplugged...
You need to confirm if the power switch is working as the button is stuck . So it is best to get this part corrected before we move to the remote as the power switch or the button aligment can be corrected if you open to check the continuity.
Next the remote controller must be checked for the IR outputs. please check this link below for tips to repair or find a link for a universal type remote.
http://www.fixya.com/support/r6178946-tips_repair_remote_controller
http://www.espares.co.uk/search/remote-controls/p/1090
Oct 06, 2011 | RCA RT2500 System
I am connected to the TV from the sound system. Of my six speakers connected, I can only get sound from the SW, and the front L & R speakers. No sound is coming out of the Center or Rear L & R. ...
You don't say HOW the 'TV' audio is carried to the RT2500? TV's are usually the end of the chain, not a link in it. For multichannel audio you need a multichannel digital source. Is that the TV or would it be the cable/sat box? Try running a digital audio cable from one of those to the RCA.
Dec 27, 2010 | RCA RT2500 System
Rear speakers not working
Your FM tuner will only generate sound from the front sepakers. CD's, Tape, and I guess mp3 player, as well, will only play through the front speakers.
I've included a link for the manual. The audio on this rig is pretty complex. read through the info, especially pages 11,12,13, and play with the audio controls.
http://support.radioshack.com/support_audio/doc61/61792.pdf
Aug 16, 2009 | RCA RT2500 System
What is the remote conrol code for an RCA A/V Receiver?
If you are looking for a code to program a universal remote, you probably won't find one. Universal remotes are for TV DVD VCR and Cable boxes. A replacement remote might be found at MCMelectronics or Vance Baldwin. I would guess $40-$60
Jan 14, 2009 | RCA RT2500 System
RCA rt2500 "CHK SPKR" comes on when i turn it on.
"CHK SPKR" Check Speakers. Remove all speaker wires and turn on receiver. If it still says check speakers, you have an amp that needs output transistors or possibly just soldering of an emitter resistor but thats rare.
Dec 28, 2008 | RCA RT2500 System
RCA RT2500 NO SOUND
Similar problem here, at first 20-30 min warm-up time, followed by irregularity in sound levels, to a complete failure after using for around 30 minutes after warm up (choppy sound to a steady buzz). I wonder if over heating has something to do with it since I left it on all the time after the need of a warm-up occurred. One night, a horrid buzz came from the system and ever since it would become unbearable to listen too after a few minutes, I am debating either to attempt a fix or chunk it. I haven't tried the caps and fuses yet, but seeing your problem leads me to believe it is something more to the problem, and more likely a better investment would be an upgrade.
Jan 18, 2008 | RCA RT2500 System
RCA RT2500 System Logo
375 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
