Question about Philips Flat Panel Televisions
Phillips model 32pfl5322d/37 will not power on
My phillips 32 in LCD HD tv will not power on and there is a red light flashing on the front.
  • 4402 Answers
SOURCE: Phillips 37 LCD Service Manual
Posted on Mar 10, 2008
  • 5 Answers
SOURCE: My magnavox 37mf321d 37 LCD tv
This is a bad power supply and an easy fix. Their are several electrolytic capacitors on the power supply. If one is bad it will have a bulge on the top. Mine had a bad 2200uF and a bad 1200uF capacitor. About $7 worth of parts at Radio Shack. Radio Shack had the 2200uF but it was axial leads instead of radial. (leads come out of each end instead of one end) but It will still fit. They only had a 1000uf capacitor so I combined that with a 220uF capacitor and wired them in parallel. Make sure you put them in with the correct polarity.
Posted on Dec 06, 2008
  • 90 Answers
SOURCE: Did you ever get your Philips fixed?
that specific flashiing is the software in the computer, the television has inside
you need to go to the philips website and download an upgrade software repair it is free-- put it on a thumb drive without any other things on it---- the television ,must be on to install --- turn it on with the remote and then insert the thumb drive-- the television will run a scan--- then turn off television and wait a few minutes-- turn it back on with the switch on the side of the unit-----
the power problem is something else--- the power board sounds like is going bad--- a new one is around 300-400 and a rebult unit is around 100 --- you can find them on
this television is poorly built -- when you get the new board it is easy to install -- before ordering a new board -- check the fuses on the board-- there are two fuses -- one is 1amp and the other is 5amp -- both are slwo burn fuses
Posted on Feb 24, 2009
  • 90 Answers
SOURCE: Red flashing light. Light flashes red 8 times pauses & repeats
power supply board going bad
Posted on Mar 03, 2009
SOURCE: No picture
had same problem....Its fixed now working great....had 2 blown capacitors.Cost me two bucks and about an hour to fix.Look at the capacitors on the main power supply they should be flat...I you need help email me
  • 9 Answers
if you bought a new rca tv, the codes have changed. until the cable companies catch up, you will need to use the remote that came with our tv AND the remote that came with your comcast box. Or, you can buy a LEARNING UNIVERSAL remote. this is different than a regular universal remote.
Posted on Aug 29, 2009
0 characters
1 Points
I have a 37" Philips (37PF9431D/37) flat panel tv. It won't power on. When you plug it in you can hear a click the green light stays on for a few seconds then goes out. I've checked the power board for bad...
i am having the same problem. My Phillips 37" 37PF9431D/37I LCD High Definition TV won;t turn on. When I press the power button i hear a click and the green light comes on for a couple of seconds and then the red light appears. I can;t figure it out. Did you find a solution?
May 20, 2010 | Philips 37PF7320A 37 in. HD-Ready LCD...
I have a 37" Phillips LCD TV. it will not turn on and the light that used to show green (to signal the tv on) now blinks red. What does that mean?
how many times does it blink red. the will help determine whats wrong. Most lightly its going to give you 6 or 7 blinks whick points to the power supply this is sometimes a false indication to the ssb/signal board being bad. you coulb try the parts or have a tech come out and verify which is the problem.
Apr 27, 2010 | Philips 37PF7320A 37 in. HD-Ready LCD...
Flashing red light
Power board is dead,replaced the power board will get power back.
Jan 30, 2010 | Philips 37PF7320A 37 in. HD-Ready LCD...
Philips 32pfl5322d/37 gives a blue light for just a second and then flashes red 8 times pauses and flashes eight times again and again
Power board is dead,U know how to solders?Take the tv aparts check the power board for bad Capacitors,like puff up or burst open,replaced these capacitors,should get ur power stable,come back.Or replaced the whole refurbish power board,buy at websites,
Jan 11, 2010 | Philips 32PFL5332D 32 in. LCD Television
Philips 32pfl5322d/37 went off and won't come back on
Sounds like you have a bad power supply board! This is not hard to do yourself, as long as you are somewhat handy! Take the case apart (back side), and look some bad caps (capacitors) on the power supply board. They will look bulged on thetop an may be a little leaky (brownish stain).
Then you can buy a new one at or ebay, you will need to use the brand and model number! Good luck, I hope this is helpful!!
Mar 02, 2009 | Philips 37PF7320A 37 in. HD-Ready LCD...
No picture or sound just six red blinking lights
Use your warranty in a hurry before it expires. Your TV when into protection mode to prevent further damage. Most TVs have a 1 year warranty. Good Luck.
Jan 24, 2009 | Philips 37PF7320A 37 in. HD-Ready LCD...
power board is bad if it doesnt power up -- the red flashing lights mean that you need to upgrade the software-- you can get a new software upgrade on the website for philips --- use a thumb drive to install it into the television
Dec 16, 2008 | Philips 37PF7320A 37 in. HD-Ready LCD...
My samsung tv wont turn on, red light keeps flashing on the front.
i had this with my samsung and my mums instead of pressing red power button press either switch from analog tv to digital button or just press a number
Jun 04, 2008 | Samsung LE32R74BDX 32 in. HD-Ready LCD...
Flat Panel Televisions Logo
305 people viewed this question
Top Philips Flat Panel Televisions Experts
Are you a Philips Flat Panel Television Expert? Answer questions, earn points and help others
