Question about Copystar CS-1510 Copier
Loud groaning noise when copier is turned on.
My Copystar CS-1510 makes a loud groaning, whining, moaning type noise every time it is turned on. There are no error codes or messages on the display. I can still make copies; but, the noise is horrible.
Your laser unit is going bad
Posted on May 08, 2009
  • 215 Answers
Sounds to me like the laser unit is going bad. common problem on this model.
razors
Posted on Jan 09, 2009
    Scholar:
  • 95 Answers
Great Suggestions, also, if there is a toner "cartridge" and the machine or toner cart. has been sitting for a while (especially in heat) it may need to be shaken, loosened up, or otherwise replaced all together. Good Luck!
Posted on Nov 29, 2007
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Copystar Master
  • 1,362 Answers
Try this to localize the problem:
1- take out the drum and turn it by hand, does it make a noise?
sometimes the drum makes a sqeaking hollow sound, because the blade is rubbing against it and is too dry.( will not be as loud but you will know if it is the problem)
2- take out the fuser and do the same.
Now you have isolated the problem, if none of them are making any audible noise then it's probably a gear.
Good luck
  • 64 Answers
Hi cayb1221,
This sometimes a common problem that cannormaly be solved by one of two ways:
1: replace cartridge. it is most likely that this is causing the grinding nose.
2: Replace the fuser
these are the two main parts of any laser unit that will make grinding noises (cog driven parts)
Hope this helps
Pete
COPS
pete@wedotoners.com
Where can I get a drum for a copystar cs1510?
http://www.digitalsystemcopiers.com/Copystar_CS-1510specs.html
About Us How to Order
Warranty
Contact Us
Email
CopyStar CS-1510 Digital Copier
CopyStar CS-1510 Digital Copier Supply Prices Toner Type Cartridge: Price: $37 Yield:7000 Developer $54.00 per 100,000 copies Drum $107 per 100,000 copies
CopyStar CS-1510 Digital Copier Optional Equipment
Oct 22, 2011 | Office Equipment & Supplies
Machine makes a loud siren like noise when started up or making copies
This is the polygon engine (laser writing system) which is weary
Contact your service department to replace it, or wait until it fails ...
May 12, 2011 | Copystar CS-1510 Copier
Need Manual for Copystar CS 1510
Use the link below to download the manual from the maufactures website. The link is for the KM-1510 which is the same as the CS-1510.
http://usa.kyoceramita.com/americas/jsp/Kyocera/resource_details.jsp?pid=5051&rid=2076
Apr 29, 2011 | Copystar CS-1510 Copier
Copystar CS1510 Error E70
Your fuser needs to be replaced
Apr 28, 2010 | Copystar CS-1510 Copier
On a copystar cs-1510...waht does c 710 mean?
C710 might be the problem with toner or the developer might be faulty
Apr 07, 2010 | Copystar CS-1510 Copier
Hi I have a copystar CS 1810 and it started to make a loud clicking noise and now I have a code showing on the display 620 and C. Can you help Thank you, John
Hello sir; It's a fuser problem, but you need to reset, the procedure as follow; Press and holding down following keys in order, "stop/reset", "start", and "left copy density", then press "stop/reset" key again, then enter U63 press "start", window will display "CLE", press start again to clear.
Oct 27, 2009 | Copystar CS-1810 Copier
Copystar 1810 document feeder slips grinding noice
Sorry Mike,
No spare parts are available.
Jun 27, 2009 | Copystar CS-1810 Copier
Cs-1510 makes loud high pitch noise when copying
loud noise is usually coming from the laser unit. if you can ger to it, lubricate it's polygon motor shaft with some oil. It usually works fine afterwards. It is a bit of a hassle to remove the laser unit.
Mar 11, 2009 | Copystar CS-1510 Copier
Moaning noise in steering column
The probably lubed the intermediat shaft conenction. The loud poping noise could be from them not sitting the boot back correctly. Inspect your boot. As for the moaning noise Only thing I can think of is a hydraulic noise.
Dec 11, 2008 | 2007 Saturn Outlook
Copystar CS-1510 Copier Logo
230 people viewed this question
Top Copystar Office Equipment & Supplies Experts
Tammie Duggan
Tammie Duggan
Timothy Van Der...
Adorjani Laszlo
Are you a Copystar Office Equipment and Supply Expert? Answer questions, earn points and help others
