Question about Answer Lands Phones
How do i answer the phone - Answer Lands Phones
    New Friend:
  • 64 Answers
What kind of phone?
Posted on Jul 05, 2019
SOURCE:
Phone is plugged in to a fax machine and the phone rings too many times before answering machine picks up so the fax machine takes over. How can I reduce the number of rings so that the answering machine...
Change the answer machine rings to answer number to less than the fax number of rings to answer or increase the number of rings to answer on the fax machine. Would need exact model number of phone system to give more detail on programming steps. Info should be in manuals of phone system and fax machine.
Dec 07, 2010 | AT&T DECT 6.0 Cordless Phone System with...
Answering system won't record messages...phone defers to Telstra 101
Had a problem on wireless home phone with answering machine not taking messages when had the answering machine set to 12 rings before answering. Found the sim card (my wireless system) auto response would answer first. Fixed it by reducing time to 6 rings and answering machine now comes on first.
Oct 12, 2010 | Uniden Cordless Phone
I have Comcast on my phone & have had the phone answering taken off from them, however, I cannot put a message on my GE phone answering system. The "phone lady" answers saying we are unavailable at...
The phone lady thats answering the line,it that message through comcast or the GE answering machine? Also, whats the model number of the GE answering system?
Jun 09, 2010 | GE Lands Phones
I have philips landline phones. My main phone does not ring or flash when an incoming call comes in. I t won't go onto answer phone either it just rings out. I can pick it up and answer the call. i can...
Looks like the basic functions of the phone are correct. Remain the answering machine. Are you sure it can act as an answering machine?
If it can act as answering machine the reason it is not doing so may be the following.
  1. Answering function is turned OFF
  2. Answering function may be ON but the number of rings before it answers is set too high.
I suggest you try the following
Call you phone. Let it ring at least 10 times. If it can act as an answering machine it will pick up the phone and read the welcome message, because most answering machines (the recent ones at least) answer after 10 rings even if answering function is turned OFF.
The phones that can be answering machines usually do have a display that shows the number of incoming messages, or a LED that flashes to let you know that you have new recorded messages.
Jan 03, 2010 | Philips Lands Phones
Turn answer phone off on Samsung tocco lite mobile
Goto Settings-->Call Settings-->All Calls-->Answering mode.
and check the required options.
Sep 30, 2009 | Samsung Tocco F480 - Pay Monthly Cellular...
My phone has a answering machine with it but i now have call answer with cable how do i set up the phone to show that i have messages
If you want to use a different answer machine just run the phone line from the wall to the machine you want to use. Be sure you plug in the cord that say's "Line". Then use another cord that will plug into the answer machine that say's "phone". Plug that other end into your phone and be sure to turn the answer machine off on the phone. Good luck.
Apr 15, 2009 | Uniden Cordless Phone
Can I use cordless phone answering machine even if I have voicema
You do not have to cancel the phone company voice mail service. You need to change the number of rings the phone uses to answer the voice mail.
For example, if the telephone company voice mail answers if 4 rings, set the telephone answering machine to answer in 3 rings or less.
Good luck.
joequevedo@charter.net
Mar 03, 2009 | GE 27992GE5 Cordless Phone
My answering system and my instructions are all in won't pick up
is the incoming phone line plugged into the answering machine directly? the answering machine should then be plugged into the phone. the signal comes through the answering machine then to the phone. you may have the connections reversed on the answering machine. check those connections.
Nov 26, 2008 | GE 27831 2.4 GHz Twin Cordless Phone
Parasonic auto-logic answering machine
Hello, yes it sounds like your trying to connect a "analog device" to a "digital" telephone. If you wish to connect the answering machine to answer your line or lines, you should contact your facilities maintenance department and see if they can "hardwire" your telephone line (your primary phone number), to another jack in your office so your answering machine will work by being placed in "parallel" with your phone system and your primary phone number. If you have more than one phone line (number) you wish for the machine to answer, you will need to ask for a "analog extension" from your digital phone system and have it programmed to ring when any of your roll over lines ring. However, keep in mind the machine can only answer one call at a time, the other simultaneous callers will get a ring no answer until the first caller has hung up. Good luck, hoped to help. CG
Jan 07, 2008 | Panasonic KX-TM150B Digital Answering...
Lands Phones Logo
20 people viewed this question
Top Answer Lands Phones Experts
Marvin
Marvin
John Donghia Jr.
John Donghia Jr.
NOEL
NOEL
Are you an Answer Lands Phone Expert? Answer questions, earn points and help others
