Question about Panasonic TH-42PX60U Television
Child lock reset
Hi....i have a 15 inch lcd tv flat screen...the problem i have is that whilst messing around with the settings using the control buttons i accidently set the child lock so that now i cannot manually retune the tv when i go away in my camper....what info do you need to help or is it a common format to reset?
  • Anonymous Sep 24, 2008
    Reset problem, I had my tv remote stolen how do I reset the TV.
  • grace1216 Oct 21, 2008
    My son reset the childlock and forgot the number. How can I reset the child lock for the T.V.??
1. Turn the television on.
3. When self-check is displayed, press any button.
Posted on Oct 22, 2008
  • grace1216 Oct 22, 2008
    I was so glad to have the solution I posted it here so others who pull it up can have the solution too.
    shavediceman mistakenly posted under solution rather than 'I have the same problem.'
  • grace1216 Oct 23, 2008
    This solution is for the Panasonic Viera
Perfect, this worked!!
Posted on Apr 12, 2009
Mikomi TV
no original remote, child locked on, and no manual?
You will find no magic here---you need all three of those to even attempt what you are trying to do.
Apr 17, 2012 | RCA Mikomi 5290925 15 in. LCD TV
How do you reset a pin code for a phillips tv
If you have not set your PIN-code when you first turned on the TV set, you need to do this before you can use the Child lock feature.
If you forget the PIN Code, unplug the AC power cord for 10 seconds to restore the PIN Code to 0000.
If you need to set your PIN Code for the first time, proceed as follows:
  1. Press the ' MENU ' button on the remote control to access the main menu.
  2. Press the cursor up/down to select FEATURES and press OK.
  3. Press the cursor up/down to select Child Lock and press OK.
  4. When the Enter PIN appears on the screen, enter '0000'.
Dec 07, 2010 | Toshiba 26AV502U 26 in. LCD HDTV
Locking Controls of Insignia 40'' LCD TV
Alas, I have been through this with my children and unfortunately outside of a Parental Channel lock, I have not heard of a vendor who has created the capability of locking the set controls. It's just the unfortunate case that the controls are accessible to the child (I have another TV where they are on top and even my 9 yr old can't reach them - ha ha).Sorry my friend.
Jul 24, 2010 | Insignia 42" LCD Flat-Panel HDTV
The battries in remote are new. the remote wont change channels or turn power on and off.The buttons on the tv set wont work either.It keeps saying child lock is on.
As the remote is not working please
1.check the batteries are properly installed with correct polarity.(+ and -)
2.Check weather correct remote operating is set.(TV,VCR etc)
If both are OK then please programm your remote again with the TV.As you removed your battries it might reset the code
When using buttons on TV it says CHILD LOCK is ON.
Child lock fuction is to prevent children operating buttons in TV console. This can be set only by remote. Cannot set by TV console Buttons.If this fuction is activated you cannot use the TV console buttons.
Jul 23, 2010 | LG 47LC7DF 47 in. LCD HDTV
GOODMANS GTVL26W26HDF - no Remote control/child lock is locked!!
hi just got a goodmans x pro witout the remote any chance you could let me no how to turn it on as its just on stand by now thanks
Feb 06, 2010 | Goodmans GTVL32W27HDF 32 in. LCD TV
Child lock
From the main menu choose "Parental Controls;" it's option six.
  • Step 2 Choose the first option, V-Chip TV Rating Limit, and using the arrow keys and the OK button on the remote, scroll through until the TV-MA rating appears. Press the right arrow button to move the highlight over to the "Status" field and toggle to "View." Press the OK button. This will set the age-based ratings to Mature.
  • Step 3 From the Parental Controls menu, select the second option, V-Chip Movie Ratings Limit and change the rating to TV_MA and the "Status" to "View."
  • Step 4 From the Parental Controls menu select the third option, V-Chip Unrated Program Block and select item one, which will be "View."
  • Step 5 Select the fourth option, which is "Channel Block." Highlight the Channel field and using the channel up and down buttons, go through and check they are all set to 'View." Any set to "Block" will need to be toggled back to View.
  • Step 6 Lock the controls to activate the changes using item six on the "Parental Controls" menu.
  • Nov 30, 2009 | RCA Mikomi 5290925 15 in. LCD TV
    How to unlock child?
    i think but im not sure but its worth a shot. turn the tv on then press and hold the power and action button on the set for 5 or 6 seconds this should reset the television and run a diagnostics test proceedure
    Nov 22, 2009 | Sanyo DP32746 32 in. LCD Television
    How Do I remove child Lock
    This problem can be solved flashing the firmware again, but you need a cable interface between a rs232 port and a VGA D-SUB 15, I have the firmwares for American, Australian, European and Pal models, and the software used to flash it, but I haven¡t the interface cable and I don't know how to build it...Maybe somebody can help with this...
    Jan 21, 2009 | Acer AL2671W 26 in. LCD Television
    How to take off child proof lock?
    try 0000???
    Parental Menu Options
    1. Press the MENU and VOL+/VOL- button
    2. Press CH+/CH- button to select PASSWORD .
    3. Then input the password 0000. It will bring parental menu display on the
    The "Default Password" preset by the manufacturer is
    "0000" . If you want to change the preset password to your own password, just
    choose any four digits that can be easily remembered and set. Once you set
    password for a particular channel, that channel will be blocked.
    to reset tv you might have to contact support at this link.
    Apr 12, 2008 | Haier HLH15BB 15 in. LCD Television
    Freeview locked
    Phil.. to reset: Info>Menu>Mute>Power Button make sure tv is off to start with! messing around in here could void your resets the tv to manufactures settings. if you just want to reset freeview.. 0 0 0 0 then press the colour buttons in sequence.. im having a much bigger problem..i think my freeview has blown on my LE46m87bdx..its only 1 month old..i turned it on and it went crazy..then no more signal..and i get a max bit error with 0 signal strengh..add to this with the fact that the screen goes crazy and resets on the DTV mode..ive got a service person coming round on the weekend! if it is blown..then ill have to do without freeview on the not letting him take away the no no no no!
    Jul 14, 2007 | Samsung LE40R74BDX 40 in. LCD Television
    Panasonic TH-42PX60U Television Logo
    433 people viewed this question
    Top Panasonic Televison & Video Experts
    Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
