Yamaha k-720 cassette deck
Will not work/play tape
  • 1 more comment
  • Anonymous Jan 27, 2008
    tried 20 tapes ALL keep reversing and will not play any.
    But will fast forward and reverse. has not been played for some time. In great condition, in cabinet with other components and all others work. I bought it Oct 1985. Has always had great care, and worked perfectly. Now will not play ANY tapes!!! PLEASE!!
  • Anonymous Oct 17, 2008
    Same Problem...I noticed that what appears to be the capstan motor is hot, and seems to be powered even when the unit is idle (turned on, but no fuctions selected)
  • nonbiz_paul Nov 20, 2008
    yep. I have the exact same problem. Have not used the deck in years. But, boy, it is a killer deck, especially for recording.
    New Friend:
No play but fast forward and reverse work ok--yes it is the drive belt. I disassembled the unit to find that the belt is actually sticky and stuck to both weighted flywheels, the drive motor pulley and managed to stick to itself. The drive motor is warm from trying to turn. Now, anyone know where to find the belt??
Posted on Jun 04, 2010
  • dfsiegel Jul 26, 2011
    I read that you disassembled your K-720. I need to do the same to get to the belts. Any tips on how to remove the cassette mechanism would be appreciated.
    Thanks,
    Dave
    Scholar:
  • 116 Answers
This unit may have a tape tension sensor. If that sensor isn't working properly, the mechanism always thinks the tape has reached the end during play/record. Sitting unused could allow some grease on the sensor mechanism to harden which would disable it.
The sensor probably isn't used during FF/REW.
Posted on Mar 21, 2008
SOURCE:
Stop Paying .. ????
if the take up side gets stuck it could feed excess tape and stop the mechanism. Look to see if both reels are turning when you push play. Remove cassette door for a better view if possible.
Make sure your tapes have NO slack in them. Fast forward and rewind one cassette all the way, then try again looking to see if both sides are turning. If not, you may have a belt that is old, stretched and slipping or it's split apart or just fallen off
Sep 11, 2015 | Yamaha Audio Players & Recorders
How do I dub using the onyx double cassette deck?
There should be a button or switch that will select the recording deck and the dubbing deck. You put a blank tape into the recording deck and the pre-recorded one into the play deck. Pressing the record button on the dubbing deck, on some models should start the play deck running. If not press play on that deck.
Jun 05, 2014 | Sony TC WE435 Stereo Dual Cassette Deck...
How to tape from one deck to another?
Press the Dubbing A to B button. Put your blank tape in deck B. Press REC/PAUSE on deck B. Press Play on deck A
May 21, 2014 | Technics RS-TR272 Single Cassette Deck
Difference between a Yamaha KX 580 and a KX 580 SE cassette deck
Managed to find this blurb...
"The KX - 580SE is a refined model of the popular KX - 580, three time winner of ''What Hi Fi? Best Cassette Deck Award''. The KX - 580SE is a special edition which is UK specified. This cassette deck features CD to tape synchronized record start, timer record / play, new audiophile components in both the dolby and audio output stages, two - motor stable transport, Dolby HX pro dynamic bias servo, auto tape tuning and improved power supply."
Feb 11, 2014 | Audio Players & Recorders
Technics M14 cassette deck has hum. Bought used and had hum but I got it to go away by switching the tape select dial to metal,etc. but hum came back later. I'm thinking ground or a wire to that switch. ...
If the hum is audible without monitoring a tape playback it has nothing to do with the oxide formulation or any aspect of the media.
Determine the conditions present whenever the hum is present:
Player just turned ON?
Tape deck Playing or Paused?
Tape deck Recording or Paused?
"Tape" selected at the receiver?
Any source selected?
What switch are you referring to? You could have a floating ground or shield through a Tape Monitor or other control. Audio cables between the Deck and the receiver could be faulty or require reseating with a twisting motiuon to remove oxide build-up.
Hum can enter any unshielded cable running near any motor, magnetic field or some light sources. Sometimes simply reversing the polarity of an AC power cord will cure it.
Feb 02, 2011 | Yamaha KX-393 Cassette Deck Dual Cassette...
Yamaha K-720 cassette deck will not play tape--immediately stops on auto-stop (or, perhaps, auto-reverse.) Fast-foward and fast-rewind are okay. Had this same problem repaired in the 1980s. How do I...
your problem is the flat belt that drives the 2 capstans. I asked you to check switches but remembered afterwards there is a different motor for fast forward reverse. When the machine is powered on, the capstan motor runs all the time. I bet the 2 capstans are not turning. You can see this if you slide up (gently) the cassette tinted cover. You need a new belt. If you are handy, you can do it yourself (about 2 hours) but it is tricky as you have to remove the complete cassette mechanism and then partially dismantle it to put on the new belt. If you need help I can probably guide you a bit. I just did it a few months ago. The belt size is 9.6 inches. One part number is FBM9.6 or you can try Yamaha service.
Jul 04, 2009 | Audio Players & Recorders
Downloading an instruction manual for the K-700 Cassette Deck
Make sure you have the correct model # and go to the Yamaha web site. There is no K-700 but there is a K-720 (I have this tape deck).
http://www.yamaha.co.jp/manual/english/search.php?div=emi
May 06, 2009 | Audio Players & Recorders
Tascam 122 cassette deck the cassette player won't play
There is an idler wheel behind the platen ( black plate behind the cassette)..replace the idler wheel.
The guy in texas is Marrs communications
Mar 18, 2009 | Tascam 122MKIII Single Dual Cassette Deck
DECK B PROBLEM ON RARELY USED MACHINE
if the heads are getting jammed in the up position it may be a failing capstan belt in the transport not disengaging the transport properly. replace the capstan belt. If one has failed both will probably be bad.
Oct 06, 2007 | Yamaha KX-W321 Single Cassette Deck
641 people viewed this question
 Grubhead
Grubhead
Marvin
Marvin
