Question about CD Players
I have a technics 5 disc changer sl dv 290 part of a midi hi fi system the cd does not play message comes up saying no play tried cleaning but it still does not play never hadany problem before
Cd player has message saying no play model is technics sl dv 290 5 disc changer
3 Suggested Answers
  • 112 Answers
SOURCE: technics 5 cd changer sl-pd787
Does it show the disc length or any other details? Have you carefully cleaned the lense with a q-tip and some alcohol? Can you hear the laser moving in and out of focus? If you push the laser sled out away from the centre does it move back to the middle when youi put a disc in?
Posted on Feb 29, 2008
  • 30 Answers
SOURCE: I put 5 cd's in and they do not play. When I hit
have you tried removing the cover an using some canned air to blow dust and debris from the laser, try a cleaning disc..if all this fails..the you need to replace cd mech, I'm not sure if it is still available..i have replaced them before ..I can get part numbers and price if needed
Posted on Jul 27, 2009
  • 99 Answers
SOURCE: technics sl-pg580A
this player uses a philips mechanism, spindle motor failure is very common on these mechanisms, yours may be on its way out. take the lid off and insert a cd and if you can hear the laser trying to read the cd without it spinning, it's definately the spindle motor.
Posted on Dec 20, 2009
0 characters
1 Points
Power it on and just get an off reading
Technics SL-MC4 61-Disc CD Changer Not reading ... - Fixya > ... > Technics > Technics SL-MC4 61-Disc CD Changer
Technics SL-MC4 61-Disc CD Changer, not reading cd related issues. Get free ... IHave A Tascam CC-222Mkll Will Not Read CD-R Or CD-RW But Will Read Store Bought CD's. I Have A ... I have just spent $69 for the software to convert it the way I wanted into mp3 format, being a format that I figured . ... Power the unit off.
Technics SL-MC4 61-Disc CD Changer Message center ...
Dec 29, 2015 | Technics SL-MC4 61-Disc CD Changer
I have not played my cd changer for a year and when I just try to play a cd now the system appears to look for cd but the word error comes up on the display. Just the word error not number. Any ideans...
I dont't think that your cd-changer is broken. It may only need some cleaning. One year is time enough for dust to set on optical reader. I suggest to use a cleaning disk, available on every store selling optical media.
Hope it helped,
Sep 23, 2011 | Technics SL-MC70 60-Disc CD Changer
I burned a CD on my PC to keep in my car and it plays OK in the car and on my PC, but does not play on my Technics SL-PD687 5 disc cd player. It's recorded in *.cda format and it's on a CD-RW. Any...
The problem with old CD Players are that they sometimes are a little fidgety when it comes to reading CDRs.
You could try burning a new CD on the lowest possible setting, say 2x or 4x.
Also try changing the CDR brand as some cheap CDRs are prone to not reading in old CD Drives.
Try using a regular CD-R (CD recordable - record only once) instead of a CD-RW (CD rewritable - rewrite multiple times). CD-RW use a different "ink" to write the data to the disc and can be re-recorded/erased a couple of times before it loses its ability to write effectively to it.
Mar 05, 2011 | Technics SL-PD687 5-Disc CD Changer
SL PD887 5 disc CD changer was working one day but not the next day - does not read the CD - goes from one CD to the next but unable to read each CD in the changer. Have changed the CD's and cleaned the...
I have a model sl-pd847 and experience similar problems to many other submitters. I checked the main pcb and found discolouration around what appear to be 2 (power?) transistors and probably a voltage regulator. After about 4-5 minutes after switch on these get really hot. I suspect that may be the reason why it doesn't work anymore. Worth fixing? I don't think so. This one didn't even play CD-R let alone CD-RW! Get something a bit more up to date I say.
Jan 16, 2011 | Technics SL-PD887 5-Disc CD Changer
Disc will not play appears to be skipping
There is a product called a cd/dvd lens cleaning disc. Worth the investment to have around.
Be sure discs are free of dust and scratches.
Apr 27, 2010 | Technics SL-PD6 5-Disc CD Changer
When Making A CD To Play On My technics SL-PD8 It
If thhis happens quite often , and does not depend on the media, then it is usually a dirty lens problem. The lens is dirty or scratched and sometimes cannot read CD TOC (table of content).
If this happens only on reocrded CDs , try changing the media used. For example if you used +R, try with -R.
If this happens on all media, then try cleaning the lens with a lens cleaner CD or blowing some canned air on the lens.
See: CD and DVD Lens Cleaner...
May 02, 2009 | Technics SL-PD8 5-Disc CD Changer
Random play
Hi - You can download the manual by clicking the link underlined in blue below:
See page 17:
Note this feature requires the remote control!
Please take a moment to rate this solution & let us know if the information given was useful to you - Good Luck!
Sep 05, 2008 | Technics SL-MC70 60-Disc CD Changer
Volume Control??
Unlike low-end hi-fi systems where you buy one box that does everything, the CD player you have is part of a component hi-fi system (i.e. you buy your CD player, tuner, amplifer etc. as separate items.) This is why there is no volume control. It needs to be connected to an amplifer. It's on the amp that you will find the volume control and where you connect the speakers. (When you connect it to your television, you are just using that amp in the TV instead.)
The CD player did originally ship with a remote control, but I don't know where you would be able to buy one on its own. You may find the the remote does allow you to alter the output level of the CD player, but you still need to connect it to a proper amp to get it to work.
Hope this helps,
Mar 27, 2008 | Technics SL-PD887 5-Disc CD Changer
No play
Sounds like the drive belt that spins the disk is slipping or broken. You have only one actual cd reader so no matter what slot the disc is in it has to go to the same cd reader drive.
Hope this helps...
Dec 27, 2007 | Technics SL-MC7 110-Disc CD Changer
CD Players Logo
125 people viewed this question
Top CD Players Experts
Dave Jukebox
Are you a CD Player Expert? Answer questions, earn points and help others
