Question about Kenwood KDC-X590 CD Player
Display is OUT but everything functions....... what to do?
My display on the faceplate has stopped working, is there a battery in this unit or some type of recall or fix for this ?
Help!
  • 28 more comments
  • headNashol Dec 06, 2007
    same problem. I looked into the display and it appears ok. I don't believe it's burnt out. I think I hit the wrong button(s)?
  • acanders Dec 26, 2007
    same problem for me, display went intermitant for several weeks now I think it's out for good. Anything digital on the display does not show but eveything, all buttons and functions, work fine. It's a real pain. I am probably way past warranty even though the problem showed itself within warranty period.
  • Shmemily Dec 27, 2007
    Same problem for me. Display went in and out for awhile and now it doesn't work at all. The knobs light up, but nothing else does.
  • decktard Jan 03, 2008
    I'm having the exact same issue. The buttons work and everything lights up EXCEPT the LCD display in the middle.
    It really bums me out because I'm near sure, as are you guys, that it is the faceplate but I need to take the whole thing out of my car to bring it to a service center.
    I've had this less than a year and I'm kinda worried that even if I do get this fixed the problem will just crop up again and at that point the warranty will be expired.
  • Anonymous Feb 05, 2008
    same thing. Called Kenwood...No joy.
  • soydeedo Mar 18, 2008
    This has happened to me as well - buttons light and it still plays, but the actual display is nice and blank. It came back on for a fraction of a second after the first time it happened and haven't seen it since. I haven't had a chance to take apart my faceplate, but I'll give it a shot when I have some time.
  • Anonymous Apr 04, 2008
    Same problem as everyone else. I'm heading back to the dealer tomorrow.
  • ryousideways Apr 12, 2008
    Same thing. It acts like an old friend that comes back to visit for a day. I bought it last 2 years ago. After 6 month, it started working on and off. then nothing for 5 months. Then suddenly last december it worked once. 2 days ago it worked for a whole day then left again. All the other functions work.
  • rockbox May 02, 2008
    why is someone saying there is 2 year warranty on kdc-x590, and also Crutchfield admin says also. I have the warranty card in front of me and clearly says 1 year. my x590 screen also went out, about 18 months after purchase, purchased via Car Toys but I have moved now, any idea how I can get this 2 year warranty?
  • Anonymous May 20, 2008
    Same problem. took unit apart, looks fine. Took faceplate apart...same burn in the lower left corner as everyone else. As far as buying a replacement goes, I wonder if they will want my left arm or my first born child. The word "recall" comes to mind, but that's for companies that CARE!
  • taylor_ridin Jun 26, 2008
    dose any one have a pic of what to fix it and ahve pic they can email .me of the spot to fix
  • Anonymous Jul 07, 2008
    Got the same problem on my KDC-MP632U.
  • Lakerfan333 Jul 09, 2008
    Same thing as everyone else...no display. Solution offered up was EXACTLY what I was looking for! I'll fix myself and save the headache! Good luck fellow Kenwood display victims!
  • Photec Sep 01, 2008
    Hoo Haw! Thanx Tech48!
    Your fix is "Spot-on". Mines a MP532U and I had my main unit apart and had "Scoped" the board for a bad solder joint and couldn't find one. Without a schematic it was tough to pinpoint the culprit. Flowed the resistors per Tech48s advice and I'm back in business! Oh by the way and I'm sure Tech48 knows this, that "burned spot" everyone is talking about is reminiscent of tops of vacuum tubes! The florescent display is a "tube" and requires a vacuum to operate. After the tube is manufactured, a high current charge is sent to 2 leads connected to a metal shunt which evaporates under load and creates the vacuum necessary for operation. It's great to be old....I think...
    Thanx Again Tech48.
  • jpcloutier Sep 06, 2008
    Would someone please send me a diagram of the resisitors to be soldered? My display is out exactly as described on the original post. I now have my device open, ready to go and just need to know what I am looking for and what to solder. Thank you, in advance. [email protected]
    Please disregard my previous post.
    I figured it out and VOILA it worked! My display is working again!!!
    THANK YOU SO MUCH!! Jpc
  • EmVet2010 Oct 18, 2008
    I have the EXACT same problem! Soon after I bought my kenwood (less than a year) the faceplate burned out but the unit still works. What can I do?
  • Anonymous Oct 28, 2008
    my display is the only thing that doesn't work on my unit how do i get it working again???
  • tanderson789 Jan 23, 2009
    Could this cause my dashlights to not work? I fixed my deck with these great instructions a month ago and my dashlights worked when we turned it on for the first time in months! Now they both are out again. Any ideas?
  • Anonymous Mar 16, 2009
    Display out
  • Anonymous Mar 20, 2009
    I am from singapore and i tried Tech48 method on my KEnwood HU and viola, the display came back to life..
    thanks.
  • Anonymous Apr 02, 2009
    same problem here - everything works, except for the display
  • adyong Apr 13, 2009
    Glad to found this thread , DIY and it works, save me lots of $$$ as was quoted $100 plus or just change to a new ones as was told not wotrh to repair but now just works fine and the display came alive again, thanks....
  • BenElvis Apr 21, 2009
    a resistor came off, and i lost it. where can i get a new one and what do i ask for?
  • Anonymous Apr 23, 2009
    Mine is the Kenwood KDC-832U. Same sympton. Display out, but everything works. The display came back on once & then never again. Then the rest of the receiver woiuld not work at all, intermittently. Resoldering the resistors fixed it. On this model, there are no R numbers markings on the circuit board, but the resistors you need are all lined up on the right side of the board, and all marked the same way.
  • Anonymous Apr 24, 2009
    Thanks a lot Tech48.
    I got myself a soldering iron, used it as you explained, and the display is showing again on my KDC-X590.
    Soldering some of those resistors was a tough job, as the space there is small... but it took me only 10 minutes to make it work!
    I want to make a donation as well!
  • Anonymous May 03, 2009
    Audio works just fine, all buttons on faceplate work perfectly fine, but visual on faceplate is totally out. Kenwood should have recalled this, as it happened less than a year after I bought the thing. I wish I had known about their warranty!
  • Anonymous May 06, 2009
    Tech48s procedure worked like a charm. I'm an experienced solderer and still found it a bit challenging to get at all these resistors since many are directly between the chassis and several large caps, but I got it done. One had virtually no solder on one pad, when I heated up the other side to apply more solder, it moved! Pretty sure that one was my problem. Although all of them seemed overly skimpy on the solder IMO. Many thanks to tech48 who saved me lots of trouble and an expensive repair since I probably would have bought a new faceplate first!
  • chrisaayers May 13, 2009
    Same face plate problem. I will tell you how it goes
    I put the deck back in and it is fixed. Thank you Tech48
    President:
  • 624 Answers
The problem is not the faceplate for any of you, it is inside the main unit. If you know how to solder, you can fix is very easy. First take the top off the unit, there is 1 screw in the back middle. Then take the CD player out. It has 2 screws holding it in at the front corners at the bottom of the CD deck. Use a number 2 phillips and take out the gold screws holding the CD deck in place. Then you can pull out the CD deck, and be careful not to damage the ribbon cable connected from the CD deck to the main board. The deck can just sit up and over to the left to get it out of the way for what needs to be soldered.
Look inside the main unit on the board and you will see in the front right corner a series of surface mount resistors all connected in series. Just reflow that solder on them with a small amount of new solder added and the display will once again work perfectly. That solder is very heat stressed, that is the problem. I have fixed dozens of these over the last few years. Make sure you put it back together the same as it came apart, and you are done.
Posted on Jun 16, 2008
  • 4 more comments
  • ubelikewow Dec 27, 2010
    How did you manage to remove the cover for your KDC-MP532U to get to the circuit board? From the outside, it looks sealed up with only a few screws. Thanks
  • 1mobetter Mar 28, 2011
    Thanks a mil!
    This solution works, don't let the burned mark on the lower left of the face fool you this solution worked on my kdc mp632u. just as I was about to abandoned this receiver. Popped it open and found the about 5-7 surface mount resistors. I simply re-soldered, using a fine tip on my solder station, and a little soldering flux to help flow the solder. first remove the top 1 screw and some snap clips and the lid comes off. next remove the 2 screws on the cd drive and lift up and remove the ribbon cable by releasing the little brown plastic clip toward the ribbin cable and it simply slips out. now you can accese the main board with the resistors are on the right side.
  • SpringbokNZ May 31, 2011
    Thanks for the info, which side do I have to solder, do I take the board out and solder the underside or do I solder at the resistors?
  • lmkju8 Jul 19, 2011
    Just to clarify the resistors are very small rectangle black pieces on the far right side of the board. Adding solder to the third unit fixed my faceplate. Thanks for posting this tech 48 !!!!!!!
  • Philip
    Philip Dec 05, 2011
    Hello, Can this problem be solved in the same or similar way on Kenwood Kdc-M9021 ? The unit does the same thing ... all working great but nothing on the display. I came across your post and now i'm hopeing you can help me with some advice. I'm good with soldering but the only thing is that in my unit there are no R43, R44, R46, R47, R49, R50, R51, R55 AND R57 or resistors with 2R7 on them. Thaks allot.
  • terrijoeysam
    terrijoeysam Feb 23, 2013
    once i saw the r27 on the resistors, i knew exactly where to solder. first i heated the existing solder and let it cool till it flashed to solid, then added solder to all the resistors so i made sure i wouldn't have to take it all apart again. my hubby put it back in the truck and turned ignition key - and there was the working display YAHOO!
I did the repair posted by Tech48. Open up the radio, take the cd player portion out, and resolder all of the resistors in the right front portion of the radio ( when looking from the face side) There are a row of around 10 or so of them, with the letters 2R7 on them. Place the solder gun on the joint and it will begin to melt the joint, then flow a tad of new solder onto each joint.
My face is now working after the repair. Thanks again!!
Posted on Feb 01, 2009
I have the KDC-632U and experienced the "black screen of death" error on my deck. It would occassionally come on and eventually failed altogether. I opened the faceplate and did notice the mark on the LCD...but it's not a factor. I opened the head unit (Thank you Tech48) and found the resistors on the right side. When magnified, you could actually see where the cracks had formed on the solder and there was a break in the circuit. I resoldered these resistors (and some others, for good measure), put it back together, and it works like a charm. THANKS for all the help folks. It's a quick fix, and a great save!
Posted on Nov 20, 2008
I have the same problem with my faceplate... but the problem isn't actually with the faceplate. I have friend who bought an X590 head unit a month after me, his still works properly. So I swapped our faceplates, and what do you know, my faceplate works fine with his head unit. So the problem is within the head unit itself.
Posted on Feb 11, 2008
I am going to attempt fixing my X590 soon, but I want to know if anyone actually took any pictures, or if anyone is kind enough to take theirs apart to take a few pictures of exactly what and where needs to be soldered? I have never done this before, but I think I am handy enough to pull this off. Thank You.
Posted on Aug 31, 2009
Wow....Thanks alot for the help Tech48. I want to make a donation! I am back in business :)
Posted on Nov 19, 2008
    Problem Solver:
  • 5 Answers
Would the KDC-MP532U head unit suffer from the same bad solder joints? I have two of these and my wife's just followed mine with a non existant display. I am so glad I saw this post.
Posted on Jun 30, 2008
Guys, I just wanted to say thanks to Tech48's solution and because of his technical expertise my KDC X590's display is back up and running like it should be. Even though the problem seems as if it would originate from the faceplate itself it isn't. I too took apart my faceplate and looked at it and found the "burnt black spot" that everyone talks about. Again though this isn't the problem. Download the service manual for the X590 and follow Tech48's guide on which resistors to solder here: http://www.fixya.com/support/t689830-kdc_x590 and you are good to go. Thanks Tech48!
  • 132 Answers
The ones that are burnt need a new faceplate assy, for the ones who work sometimes and dont its usually a loose solder connection osmewhere on the board, not the faceplate board but the main board of the unit, im currently working on one now if i find it ill post the curcut # for every1
Posted on Jan 02, 2008
  • don350k Jul 30, 2008
    SYMPTOM: No Display.
    COUNTERMEASURE: Re-solder the following components on PCB X34-415:
    R43, R44, R46, R47, R48, R49, R50, R51, R55, and R57
I have exact same problem with all LED's on my KDC-X590 faceplate do not illuminate anymore but all functionality is OK (all the buttons and functions work). It started as intermitent problem but lately haven't seen the display for months.
Posted on Dec 26, 2007
  • 1 more comment
  • acanders Dec 31, 2007
    I checked with the local distributor in PA, where I bought the unit, and he said because the Excelon brand is top of the line it has a two year warranty. I have until April '08 to take it in and have them send it for repair. They have a repair center on east coast (Georgia, I think he said) and it usually takes 5 - 10 days to get it back. Unfortunately I have to send the entire unit back, not just the faceplate.
    As follow up to my previous comment, here's link to Kenwood USA. (http://www.kenwoodusa.com/) One of the tabs sends you to authorized distributors in your area. If you take it there they should send it out for service.
  • acanders Feb 15, 2008
    This seems to be a repeating problem with this Kenwood model. I was able to return the entire unit to the distributor where I bought it to get it repaired. This model is the high end and has 2-year warranty so if yours is < 2 YO, send it back through the Kenwood distributor/authorized repair center. Got it back in about 5 days even though they said 1 - 2 weeks is typical. Did not cost anything except didn't have a radio for a week. Everything is fine now. Hope it stays repaired for long time. BTW - the repair document didn't mention details about what they fixed.
    New Friend:
I fix it too....
My Kenwood model is DPX-501U (2din)
I resolder the 2R7 resistors at the mainboard and the display works fine again.
Thanks.
Posted on Jan 30, 2017
    Master:
  • 192 Answers
    New Friend:
I hv a same prob with dpx-4020
but i could not find the resistor..
anyone can help
Posted on Aug 09, 2015
    New Friend:
Brilliant! Thanks everyone for sharing. Same problem here, so this site was perfect! I will post my results after breaking out the solder gun.
Posted on Nov 09, 2009
Thanks a 1.000.000 tech48! My display cut out whilst on holiday in sunny Italy. Radio controlled blindfolded, with random results.
Soldering the 5 SMT resistors in place did the trick. This is what I love about the internet. Real life issues and ways to resolve them.
Posted on Sep 08, 2009
Tech48!!!! wOw! I was ready to give up... You ROCK! Instructions were PERFECT! If you ever get to Canyon Lake, Texas, I owe you some beer, scotch, whatever you like. Look me up... www.dgdigitalimaging.com
Posted on Jul 11, 2009
Just to let you know the burnt out looking portion in the face plate is supposed to be there. It is not actually burnt out. If you follow "tech48" solution you will find that it will fix the problem. I have been driving around for about 5 months not being able to see what station I am on, or what song is playing. Thanks to "tech48" solution I can see in the dark again. : )
Posted on Jun 09, 2009
Just fixed my KDC-MP532U following tech48 instructions. Works great just be cautious not to overheat the surface mount resistors or they will come off completely.
Posted on Mar 29, 2009
Thanks Tech48! $5.00 for gas, $11.37 for a soldering gun and solder.. seeing my display again...PRICELESS!!! THANKS!!! It worked!!!
Posted on Feb 04, 2009
    How did you guys manage to remove the cover for your KDC-MP532U to get to the circuit board? From the outside, it looks sealed up with only a few screws. Thanks
Tech48's solution is exactly right -- worked perfectly on my mp632u.  Once I got the unit open, found the resistors, and didn't see any that were visibly loose, I thought 'there's no way that simply putting a bit of solder on all these ends is going to make any difference', but sure enough -- it did.
one more thing -- if you can't find the resistors (or don't know what a surface mount resistor looks like, as i didn't), there is a diagram here:  http://claims.satisfusion.com/ServiceLit/Kenwood/BulletinsAndManuals/KDC-MP632U.PDF
Posted on Aug 19, 2008
Hi well i just got a 2000 dodge dakota and it hade the kenwood deck in it and the face plate did not work !!! i open the face to see if there was somthing wrong and only saw that there was that burn on it but i open up the hole deck and still could not find the problem !!!! so i put it all back together conetet back in the truck but since i dint realy car about the deck i started hiting the top of it whit a wrich like 3-4 time and it came back on !!!! just hit hard but not to hard and it should come back on!!! am just happy that i dont have to get a new one
Posted on Jun 11, 2008
I took my faceplate apart and noticed there is a little burned spot on the bottom left hand side of the digital display. My assumption is that some sort of transistor burned out. I don't see how that part could be replaced unless you replace the entire digital display unit. Kenwood should have known better and created a display that would not fizzle out. I love this deck and hate to replace it. I won't buy a Kenwood because their new decks seem to have the same type of digital display.
Posted on Dec 27, 2007
I just took my faceplate apart... what do you know... a burned out portion on the lower left hand side of the faceplate.
Poor engineering.
Posted on Jan 03, 2008
3 Suggested Answers
SOURCE:
  • 132 Answers
SOURCE: display is OUT but everything functions....... what to do?
R43, R44, R46, R47, R48, R49, R50, R51, R55, and R57.
Ok so if you remove the top of the unit and cd player down the right side you see a line of surface resistors that say 2R7 on them, they all need to be resolders to the bord theres 9 total.
Posted on Jul 25, 2008
I just followed tech48's solution by resoldering the resistors on the main board.
Posted on Dec 30, 2008
DISPLAY ON MY KENWOOD STEREO STOPPED WIORKING
I also created a tutorial on fixing faceplates with 2R7 resistors (refer to my tip).
But, your unit will have a different chassis, as the faceplate is also a video display.
First you need to determine if the buttons on the faceplate are operating the various functions. If the buttons are NOT operating, then the faceplate itself (or connection to the main unit) can be considered faulty.
It's highly probable that the RIBBON cable (which connects faceplate to the inside of the unit) may be defective - this is common in some Kenwood units.
Try searching Google or youtube for ribbon cable repairs etc.
Hope this leads you in the right direction.
Cheers,
Scott
Dec 29, 2012 | Kenwood Car Audio & Video
I have a Sony CDX-GT310 FM/AM Compact Disc Player with detachable faceplate. The unit still plays fine, but the display on the faceplate quit working. I've tried resetting the unit as well as cutting...
check the connectors between the faceplate and the unit carfully they can get damaged with constant removing/refitting if not the faceplate and/or unit is faulty
Dec 09, 2017 | Sony CDX-GT310 CD Player
I have a JVC KD SH55 and won't eject CD. Fix please. Recall?
there is a ribbon wire that connects the faceplate contacts behind the faceplate that always go bad on all radios with rotating faceplates. you can probably find this part on ebay or on parts.com or by jvc.
Sep 08, 2009 | JVC KD-SH55 CD Player
Dec 29, 2008 | Kenwood KDC-MP632U
Jul 13, 2008 | Kenwood KDC-X590 CD Player
OEL Display not Working on my Pioneer DEH-P7800MP
Do you take the faceplate off often? If so mayeb you could try wiping the metal contact plate on the unit b4 u put on the faceplate.
Jun 02, 2008 | Pioneer DEH-P7800MP
Faceplate not working - will remote solve problem?
PLEASE FIRST CHECK THE FACEPLATE TO HEAD UNIT CONNECTIONS (WHERE THE FACEPLATE CONTACTS THE HEAD UNIT ).
THEN IF U ARE SATISFIED ,REPLACE THE ENTIRE RECEIVER.
May 10, 2008 | Pioneer DEH-P4700MP CD/MP3/WMA/WAV...
Kenwood KRC -X858 Faceplate/Power Problem
I have the exact same problem. I called the tech line and the tech reported that the ribbon cable is probably broke. It is the flex cable between the head unit and the rotating face plate. He said it's not an expensive fix but we would need to mail it to a service center if you're like me and not near one. I just replaced mine with a new unit. It was about time anyways.
Apr 26, 2008 | Kenwood KRC-X858 Cassette Player
Faceplate starts flahing and no controls work.
Sounds like you might need to clean the contacts on the back of the faceplate or the ones on the front of the actual unit.
Jan 18, 2008 | Kenwood KDC-MPV619 CD Player
VR500CSBT Reseting itself when I remove the faceplate
no man, you should take a direct line from the car battery to the unit, then you radio station will be saved all the time, do it in specialist in cars, just tell it that
Dec 04, 2007 | Roadmaster (VR500CSBT)
Kenwood KDC-X590 CD Player Logo
11,300 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Mike Duncan
Mike Duncan
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
