Question about Casio Exilim EX-S600 Digital Camera
Button doesn't function
Power on/off button doesn't function
You may wish to replace the battery. I would check a new battery before sending in for repairs. A local camera shop I am sure would be happy to test it for you with one of their display batteries. Or repost your question with ways you have tried to check already.
Posted on Dec 11, 2007
SOURCE:
My computer still functioning even its shutdown already
have you tried to hold the power button down for 5 seconds? if that doesn't work, it's possible that when you click the shut down the last option used was the hibernate option. when you click the orb click the arrow pointing to the right next to the power indicator and make sure it's set to shut down and not hibernate
If you need further help, reach me via phone at https://www.6ya.com/expert/joel_63c670a84e9f6a97
Aug 02, 2012 | Lenovo Computers & Internet
X1000 power button
The power button on these laptops is easily depressed underneath the power button strip especially when the switch becomes dirty, the screen doesn't light up, and the user gets frustrated. When I find a depressed button, I take the keyboard off by removing the 2 13mm screws with the keyboard emblem from the bottom and moving the 4 tiny plates between the esc-F1, F4-F5, F8-F9, & F12-delete keys. The power strip is then removed by gently prying up near the CPU and pulling it up and toward the front of the laptop. You can then either repair or replace the button or strip. I small drop of contact cleaner down into the switch will help it function reliably. Even a small drop of rubbing alcohol will sometimes work but contact cleaner is the best.
Mar 02, 2012 | Compaq Presario X1000 Notebook
Cubic root button
not sure what you want,cubic root button is like a tick with a line at the top
Jan 09, 2012 | Texas Instruments TI-30XA Calculator
Automatic Doors won't function-How do I fix or what could be the problem
The door doesn't open with the remote or the in-car switch? I'd check the fuse, then check for power to the door actuator when the button is pressed. If there is power at the door actuator then I'd suspect a bad actuator motor. If there isn't power, please post back and I'll put my thinking cap on.
Dec 25, 2011 | 2002 Chrysler Town & Country
When I want to print it says error 6C10 switch off switch on. Doesn't work!
that indicates full waste ink pads/absorbers. to reset the counter try this:
1) With the printer power turned off, while pressing the Resume/Cancel button, press and hold the Power button.
(DO NOT release the buttons. The Power LED lights in green to indicate that a function is selectable.)
2) While holding the Power button, release the Resume/Cancel button. (DO NOT release the Power button.)
3) While holding the Power button, press the Resume/Cancel button 2 times, and then release both the Power and
Resume/Cancel buttons. (Each time the Resume/Cancel button is pressed, the Alarm and Power LEDs light
alternately, Alarm in orange and Power in green, starting with Alarm LED.)
4) When the Power LED lights in green, press the Resume/Cancel button the specified number of time(s)according to the function listed in the table below. (Each time the Resume/Cancel button is pressed, the Alarm and
Power LEDs light alternately, Alarm in orange and Power in green, starting with Alarm LED.)
any way if the absorber/pad is full, it have to be cleaned!
Sep 20, 2011 | Canon PIXMA iP4600 Color InkJet Photo...
I have a ge universal remote and a panasonic tv but i dont have the directions on how to program it or what the codes are to set it up. i need step by step instructions.please help
There are two types of GE universal remotes. Does your remote use the 4-digit code or the 3-digit code?
These codes listed below are not for combination TVs (TV/VCR, or TV/DVD). If you have a combination tv, see the appropriate code list here: http://www.jascoproducts.com/support/universal-remote-codes.asp .
The 3 digit codes for Panasonic TVs are 003, 054, 055, 062, 070, 148, 149, 170, 171, 374, 381, 437 . If you have an LCD or Plasma Panasonic only try 170.
The 4 digit codes to try for Panasonic TVs are 1182, 0171, 0148, 0054, 0170, 0062, 0374, 0381, 0437, 0950, 0003, 0070 .
Next to program the remote: Turn on the TV manually. Press and hold the Code Search or Setup button (depending on your remote). Hold the button until the indicator light comes on and then release it. Then press and release the TV button. Type in the first code for your remote and TV combination. The indicator light should go off. Then point the remote at the TV and see if the TV turns off. If it doesn't, repeat the above steps. Once you have a code that seems to work, check if the remote controls all of the functions that you need (based on the available buttons on the remote). If you have a code that turns off the TV but doesn't control other functions, continue trying other codes.
There is an option to search through all of the codes of the remote to program the remote. Press and hold the Code Search or Setup button. Release the button when the indicator light comes on. Then press and release the TV button. Now press and release the Power button on the remote repeatedly and wait until the TV turns off. Do this slowly (pressing the Power button every 2 seconds). When the TV turns off, press Enter on the remote to save the code. Then test the remote. If the remote doesn't control all the functions of the TV that you want it to, then repeat the search.
Please note that the codes in most universal remotes are limited to those for devices released 6 months or more before the remote was programmed. If your remote is older than your TV, then you may need a new remote.
I hope this helps.
Aug 06, 2011 | GE JASRM24912 Remote Control
I can't get my DVD V5500 to work. I can't get any of the function buttons to work on the unit and I can't get the remote to work either, the menu doesn' even come up when I press the...
Possible that the processor is not working. So check on the +5 voltage to the processor IC , if this is absent then power supply is faulty.
If not the mother board can be faulty. Try and see if the board can be switched and confirmed.
Jul 28, 2011 | Samsung DVD-V5500 DVD Player/VCR
I have a tedelex television model nr ec2127m. I want to know how to take the childlock off wihtout a remote
almost all flat panels have a "press and hold" unlock function. Try pressing the power switch and holding it for 10 seconds. If this doesn't work, try the other panel buttons.
Jul 01, 2011 | Televison & Video
I have both lost my remote and activated the child lock on my Sanyo LCD-24K40. How do I deactivate the lock without the remote?
Most TVs will have a "Press for 5-10 seconds" unlock function.
Usually it's holding the power button that unlocks it, but if that doesn't work, try all the other panel buttons in the same manner.
Jun 18, 2011 | Televison & Video
My dish remote will not work with my naxa tv
Hey sevenwindham,
If the remote won't work it may need to be programmed to the TV. You can personally look at the steps in the link below, just look up the model of your remote. The steps to program your remote are also provided
http://www.dishnetwork.com/SupportSection/remote-setup
Addressing Remote to TV:
1.) Press and hold the clear TV button until all mode lights light up.
2.) Release and TV light will be blinking.
3.) Enter code and press #.
4.) Try functions (Volume, Power, etc..) and see if working.
5.) If no function, repeat steps 1-4 with another code.
If that doesn't work you can also try the Power Scan listed below.
Power Scan:
1.) With the TV on, press and hold the desired mode button (about six seconds) on top of the remote until all mode button backlights come on, then release.
2.) Press 0 then press STAR (*) and press and release the Power button.
3.) Press the Up button once a second while pointing the remote at the TV. If the code for the TV comes up, the TV will power off.
4.) Press the POUND (#) button. If the code entered is valid for the remote, the mode light flashes three times. To verify the code works try several different functions for that equipment.
If you have any other questions let me know!
Tommy Faust
DISH Network
Jun 15, 2011 | DISH Network IR Remote Control
Casio Exilim EX-S600 Digital Camera Logo
19 people viewed this question
Top Casio Cameras Experts
Ekse
atollminsk
Level 1 Expert
Parshiv Luthra
Are you a Casio Camera Expert? Answer questions, earn points and help others
