It sounds like you have a monitor with a common problem. After a few years some LCD monitors
will blow a power supply. The problem is caused by parts called
capacitors overheating in the confined space of the monitor. If you are
good at electronicsrepair/soldering you can usually fix the problem. Check out a few pictures on my web sitewww.ccl-la.com/badcaps.htm You can take the back cover off your monitor and look for the bad parts,replace any that look like the pictures and your monitor should work
fine. The capacitors do need to be installed with the correct + and -
connections, note the stripe on the old one and insert the new one the
same way. If you have additional questions just email me. If you can't do the repair we offer a repair service, contact us for more details.
princeton 19 inch LCD blinks and chirps. i need a manual for it ,plus i have anHP pavillion zd7310...
(More)
princeton 19 inch LCD blinks and chirps. i need a manual for it ,plus i have anHP pavillion zd7310 17 inch laptop I need a manual on to.
I have a Princeton VL1918 Monitor with built in speakers. the volume is to low. how do I increase...
(More)
I have a Princeton VL1918 Monitor with built in speakers. the volume is to low. how do I increase it? I have the speaker set on the computer to the highest setting. Is there a volume on the monitor itself? If so, how do I get there?
It is a bit blurry and I want to know if there is a way to adjust the focus, or sharpness. None of...
(More)
It is a bit blurry and I want to know if there is a way to adjust the focus, or sharpness. None of the 4 buttons in front seem to have that function. Thanks!
