Question about Dryers
Dryer will not dry
Dry runs and drum rotates but will not dry
  • Anonymous May 27, 2008
    its electric. drier will not dry very well and leaves clothes damp
  • bmbodine Sep 28, 2008
    Same problem:
    Frigidaire Affinity AEQ7000ES
    Everything functions as it should, but unit will not dry at all.
    Error code 1: E56 then 004
    Error code 2: E9E then 001
  • 164 Answers
Could be several things. first check that the globar heats up, that is the ceramic bar atthe end of the gas valve. if that lights it could be either your gas valve coils (likely) or could be the sensor on the chimney (unlikely) could also be bad thermostats, easily checked. after removing power from dryer, using a meter check for continuity thru the thermostats, if continuity is unbroken thermostat is good
Posted on Nov 29, 2007
Drum squeaks on rotation. can drum be lubed?
would not lube the drum but the two small wheels that the drum rotates on sometimes their "axles" get dry and rusty and will squeak. Put some antisieze on them and see if the noise goes away.
Mar 16, 2014 | Whirlpool Cabrio WED6400SW Electric Dryer
I was drying rugs and one of the rugs got caught and the drum stopped turning. The power comes on but the dryer drum will not turn.
Hello, one possible cause of dryer drum not rotating is the rugs stuck between the drum and front panel.Secondly, maybe the dryer belt dispart.
Jul 31, 2013 | Sears Kenmore Elite Gas Dryer Front Load...
Maytag dryer drum not rotating
Sounds like the belt that turns the drum has slipped off or broken. Not sure if I would consider this a DIY project, but if this is the problem, a professional fix should not cost much.
Jun 19, 2012 | Maytag Dryers
My GE Dryer is not drying my clothes completely on the first cycle but when I feel inside the dryer it feels hot? Do you have an idea of what could be the issue Model# DJXR433EG1WW
If your dryer still heats, but your clothes take longer than usual to dry, you may want to check the dryer interior cabinet and/or the entire run of the exhaust ducting from where it exits your dryer to the point where it leaves your home to ensure you have no kinks, clogs, or excessive bends. The following link explains many of the common problems that can cause poor drying efficiency and longer dry times:
http://www.fixya.com/support/r3578821-dryer_takes_too_long_to_dry
Before assuming you have a problem with the appliance, check your installation to ensure you are providing the dryer with proper exhaust and air flow. This is the NUMBER ONE cause of poor drying efficiency. A dryer that is clogged, or has restricted air flow, will not dry efficiently and will cause the heating circuits to OVERHEAT. This will eventually will lead to component failures and is the source of many fire hazards.
Exhaust ducting that runs to the attic is usually the worst configuration, because the air has to be forced up. The blower fan will meet more resistance and any lint that does not exhaust completely, ends up stuck in the vent. Water appearing in the drum is another sign that you have a clog somewhere causing condensation to develop. FYI: There are no adjustments that can be made to any of the internal thermostats or heating element to make it run at a higher temperature. All these components have a fixed setting. If the dryer still produces heat, this is generally a sign that the heating element IS working. If the dryer is clogged, however, the internal protection devices, such as the Hi-Limit Thermostat and Internal Bias Thermostat will shut the heating element off prematurely to prevent the dryer from overheating, and to prevent damage to the heating element. Eventually, the Thermal Cut-Out (TCO) or Thermal Fuse will trip and the dryer will not run.or produce heat. If you have any questions, please post back and let me know. I hope you find this information helpful.
May 19, 2011 | GE DBXR463EDWW Electric Dryer
I have the GLEQ212ES1 dryer. When it is running. it sounds like something is rubbing against the drum. When you turn it by hand manually, the drum is harder to turn.Could a piece clothing gotten stuck...
Although this is possible, usually one of the wheel bearings may have gotten dry or even is stuck. Inside there are wheels that the drum is steadied by and that rotate with the drum. If it's a year old it should be under warranty and a tech can fix it. If that is a problem, remove the back (after unplugging it) find the wheels and rotate the drum by hand. If a wheel is stuck or dry you will find it. I hope this helps.
Jul 15, 2010 | Frigidaire GLEQ2152ES Electric Dryer
Rattles when drying
I need more details but typically a dryer will make a rhythmic rattling noise when loose change and other small metallic objects as well as buttons become trapped in the tumbler impellers (those wing shaped things in dryers).
Loosen and remove the top of your dryer.
Rotate your drum, taking care not to rotate it the wrong way. The right direction of rotation will produce friction to the belt, the wrong direction will cause slack on the belt on one side or the other of the drum.
Rotate the drum until the back side of the impeller is directly on top with the outer screws facing you at the top of the dryer. Remove the screws and pull out the impeller and you will find your noise makers. Do this with the remaining impellers and reinstall.
Mar 05, 2010 | Dryers
Dryer drum stopped rotating, dryer blower continues to work.
The belt probably broke, and coincidentally happened while drying the shoes. The belt is easy to replace. Open the back and you'll probably see the belt laying on the bottom
Nov 10, 2009 | Bosch Axxis WTA 3510 Electric Dryer
TD 4112W Dryer does not auto reverse
my new dryer makes athumping sound when in use and it sounds like a pair tennis shoes are being dried
Feb 16, 2009 | Zanussi TD4112W Electric Dryer
Kirkland Dryer drum does not rotate, but heat comes out
check capacitor next motor its a white long got three clips coming off it change good luck
shaun
Jan 16, 2009 | Whirlpool GEW9250 Electric Dryer
Dryer stopped running, will not restart
When you try to restart do you hear a motor running? If you do hear that sound and the dryer does not turn your belt could be the problem. (broken)
May 26, 2008 | Maytag Atlantis MDG8400AW Gas Dryer
Dryers Logo
670 people viewed this question
Top Dryers Experts
Marvin
Marvin
