Unplugged TV for 2 hours. Replugged into socket. TV does not turn on via remote or control button on set. Is there a re-set button that needs to be pushed?
Thanks for using FixYa. Unfortunately there is no reset button for the TV, you can leave it unplugged for 4-24 hrs and see if it reset itself, if does not then the issue could be due to bad power cable or a power circuit board going bad. If you have electrical expertise and know how to solder/desolder then you can just open the back cover and check for a burned capacitor/cold solder joints, if not then it is recommended to contact a qualified repair technician as these units have high voltages even when switched off.
Please do accept the solution if the issue is resolved or else revert for further assistance.
The mitsubishi tv model #cs-26201 won't let me access the television because there is a password...
(More)
The mitsubishi tv model #cs-26201 won't let me access the television because there is a password from the previous owner. How can i reboot or override that password?
I need the code for a mitsubishi cs-26201 tv, so that I can program it in to a Dish Network remote....
(More)
I need the code for a mitsubishi cs-26201 tv, so that I can program it in to a Dish Network remote. I am not able to adjust the color on the tv because, I don't have full asccess.
My tv is shows a blue screen. My tv does not respond to the function button's and there is a lock in...
(More)
My tv is shows a blue screen. My tv does not respond to the function button's and there is a lock in the upper left hand corner of screen of JENSEN 27" tv
