Question about Sony KP-53HS30 53" Rear Projection HDTV-Ready Television
KP-51WS500 The screen is red plus I have red lines that go from one side of the screen to the other, what is the fix?
  • hiro_one5 Oct 13, 2008
    my tv turns on looks normall then the screen turns all red
Try this link it has many great reviews. It is very informative for the DIY.
http://www.somelifeblog.com/2007/06/sony-projection-tv-red-line-repair.html
Posted on Dec 31, 2007
KP-51WS500 when on it blinked 4 times and has redscreen
Typically if you have a all Red Screen it is caused by either the Red CRT being shorted or The Red CRT Driver Board being bad.
Jul 17, 2009 | Sony KP-51WS500 51" Rear Projection...
Red lines across screen
had tv that did the same thing after three years but they were green cost me 300 bucks to get it fixed and the guy said every 3 to 5 expect it
Jul 03, 2009 | Sony KP-51WS500 51" Rear Projection...
Red horizontal curvy lines
You need to turn the voltage on the red tube down slightly, also you would need to adjust focus to compensate for the lower voltage to the red tube. On the left and right bottom side of speaker cover are two round covers, take them out and there are 2 1/4" hex screws take them out carefully take cover off, there is another service cover same hex screws remove. You will see the focus block on the right side, tubes are labled on block. 2 knobs for each tube. Make voltage adjustments while tv is on a black screen, then for focus, turn color all the way off in the menu, and adjust focus until it looks right in black and white. These adjustments should only be very small; if alot of adjustment is needed, you may have other issues.
May 29, 2009 | Sony KP-51WS500 51" Rear Projection...
Why my screen turning red after minute of use
If the screen looks like the one in the link I posted, then you might want to try fixing it with what is suggested on the site. Keep in mind that this is a band aid fix which compensates for weakening components, however it "should" buy you some time. Don't do these adjustments if this is not the same problem you are having. If the TV shuts itself down, check to see if the blinking code is the same as the one in the web site.
Hope this helps.
Apr 29, 2009 | Sony KP-51WS500 51" Rear Projection...
Wavy coloured lines on the screen all the time & hue
Tv repairman. the green picture tube has an intermittent short in it. This is an expensive fix.
Mar 30, 2009 | Sony KP-51WS500 51" Rear Projection...
Sony KP 51WS500 -having faint red lines on the screen. How can I fix it
just checked out a thread on a fix it yourself and im happy to say it worked...I thought mine was really bad. it got to the point where the picture was all red, but it can easily be fixed
here is the link to the how to...dont forget to skip the advert at the beginning.
wife is on cloud 9 right now looks like daddy's goin to get some tonight
this took me less then 10 minutes to fix. once i fixed the red i noticed blue lines also so i adjusted that as well. who ever posted this needs to get an award this is the first time the internet actually was usefull. cheers
Jan 22, 2009 | Sony KP-51WS500 51" Rear Projection...
Faint red curved lines on Sony KP 51ws500.Converged = no work???
Hi There!
This sounds like a typical problem related to a older CRT.
If you remove the front cover of the tv, you can then remove a wood panel. Behind this panel you will see a block (high voltage splitter) it will have 6 "knobs" on it, 3 will say focus, 3 will say screen.
They will also be labeled R - G - B
Put the tv on a blank input so you can see the lines clearly on a black screen  - Find the knob for red, and SLIGHTLY turn it down until the red lines disappear.
Dec 22, 2008 | Sony KP-51WS500 51" Rear Projection...
Sony KP-51WS500
c chip bad....get a tech to repair.265-365
Nov 13, 2007 | Sony KP-51WS500 51" Rear Projection...
Sony KP-53HS30 53" Rear Projection HDTV-Ready Television Logo
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
