Question about GE GSH25JSTSS Stainless Steel Side by Side Refrigerator
Confused / I am confused by your question. If your fridge stopped cooling why do you think that you need to defrost it? That does not make sense.what are you getting at?
  • 770 Answers
Ok the freezer section works the refrig section think of the refrigerator as a large cooler with an inlet and outlet hole cold air is blown into the refrig from the freezer via the fan motor in the freezer the really cold air comes in the top of the refrig and drops to the bottom of the refrig then it is sucked back into the freezer thru a vent hole in the bottom of the refrigerator ..GOT IT?? Now when a unit has a defrost problem there is an ice or frost build up in the freezer on the coil (bad heater,bad bi metal, bad timer can cause this) the ice builds and builds to the point where it blocks the air flow across the coil hence the air can not get to the refrigerator section making it warmer but the freezer section will work ok .. I hope this makes sense...Hint : A sign of this is a lg frost buildup on the back wall of the freezer.
Posted on Jan 26, 2008
    Problem Solver:
My frig was fine until I left the freezer door open a crack for three days by accident causing the freezer to work overtime to keep it cool and it frosted over and cooling on both sides of the unit reduced to inadequate. once I did as fix ya told me and unplugged it to make it defrost for 23-48 hrs. it then worked fine ....for about 3 weeks. obviuosly that incident caused something to malfunction...but what?
Kitchen aid fridge freezing in fre ezer and fridge section
Hi Jake, Thank you for listing a good model# and what you have tried along with what is the issue! It helps us help you a lot!
So no, do not throw this out! It is a good model and should last ya a while longer yet once it is fixed.. On to it
The damper is just a doorway similar to the vents in your home for the heat and cool. You flip the lever up and no air blows through but flip it down and you get the full effect. Close it halfway and you get some but not all. Same principal in your fridge and normally the "freezer" control should be set in the middle for the damper to be half open.
The defrost board is a counter.. Every eight hours that the fridge runs, it will shut down for 30 minutes and turn on the defrost heater as needed. Then "dwell" to allow water to drip off before it turns the fridge back on to cool. This does not control the cooling! It can if it is dead off, or if it stops defrosting.. But not in an "overcool" scenario like what you have.
Lastly you have the thermostat.. Think of it as a switch that works off temperature so it gets cold and turns off, it gets warm and turns on.
The thermostat usually goes bad and it does not run at all but it can go bad and never shut off!
Remember the switch?
Part# is W11088945
how to video here
https://www.youtube.com/watch?v=cnL65Kg3iHw
Feb 13, 2018 | Refrigerators
Refrigerator stopped cooling. As close as I can tell the fan in the freezer part was frosted up for a length of time and has possibly ruined the fridges cooling fan? Kenmore model 106 freezer on top.
If the fan in the freezer stops, then coll air from freezer will not pass from freezer section to fridge section.In that case, the freezer section will get over frosted but fridge section will not get cold, because cool air will not pass from freezer to fridge.The fan is there for two things, 1) for cooling the heating evaporator coil and 2) For flowing the cool air from freezer to fridge.---------- If the frost is getting collected and fan is getting stuck up in frost, then this is the problem.The defrost cycle is not running, the cooling cycle is running.---------------
This problem is called defrost problem.-------------
So first thing you try is , perform, manual defrost reset procedure.---------
The manual defrost reset procedure is as follows : ----
First unplug the unit from main power outlet. Then empty whole unit completely. Then keep both the doors open. Wait for 24 hours. All the ice collected on the coils and in the freezer section will get melted. Clean the water from the sections. Then Connect the power cord of the unit to main power outlet after 24 hours/.Then set the temperature to normal in both fridge and freezer section. Then check,if same frost is getting collected, then its defrost problem,. If it's again building up ice that means the unit is not defrosting. It's starting the cooling procedure, and then while defrosting, it's not working. The defrost assembly consists of three main parts. The defrost thermostat, the defrost heater and defrost board. Any of the one is not functioning. When thermostat sense the maximum cooling, it triggers the defrost heater to start heating and this defrosts the ice collected on the coils and the system works. Both thermostat and heater are controlled by defrost board. First the thermostat and defrost heater to be checked, if both check ok by meter and visually, then its defrost board causing the problem. You can get required parts from from online sites like: --- www.repairclinic.com or from searspartsdirect online site. --------- This should help.Thanks.Helpmech.
Sep 18, 2011 | Kenmore Refrigerators
The fridge part of my style Amercian whirlpool 6th sense fridge freezer is not keeping the food cool
Insufficient cooling is a fridge repair job that you can do without the help of a professional. Often the fridge has a frost-free failure, or the compressor is faulty but there are many other reasons for a fridge not cooling properly.
Step 1 - Find the Problem
Your first job is to locate the source of the problem. Consider each of the following:
* Gaskets - Make sure the gaskets/seals are not torn and are sealing properly.
* Evaporator fan - Make sure it is working. If it is now working you may have a problem with the fan motor. Check for power to the motor and also examine the fan switches around the door (not all fridges have these switches).
* Air damper - Sometimes the air damper will not open up to allow the cold air from the freezer part to blow into the fridge section.
* Condenser coils - Check to see that the condenser coils don't have a dust build-up and that the condenser motor is working.
* Compressor - Make sure your compressor is working with on and off clicking noises.
Step 2 - Frost-Free Failure
This is the most common cooling problem in fridges. Expose the evaporator coils by accessing the panel in the freezer section. The coils in the freezer section can sometimes get clogged up with frost. This can stop the evaporator fan motor from blowing cold air around, or cause the fan to hit it and stop, or become noisy. The defrost timer can be a bit tricky to find but it is usually located behind the back bottom corners of the fridge, although they can sometimes be found in the ceiling of the fresh food section, or behind the cold control cover.
Step 3 - Find the Timer
When you find the timer, turn the wheel-like screw slowly with a screwdriver until the fridge shuts off. The refrigerator is now defrosting. If you find that the fridge starts now, you will need to replace the defrost thermostat and the defrost timer.
Step 4 - Volt Test
If the heaters do not come on, use a volt meter to ohm test the defrost heater or volt test for 120 volts to the heater. You can bypass the defrost thermostat if you haven't got power to the defrost heater to check if the defrost heater will come on. To bypass the thermostat, join the two wires together. Replace the defrost thermostat and the defrost timer if the heater comes on now.
If there is a ticking or squealing noise in the defrost timer, or it seems hot to touch, replace it.
Many fridges have and inline fuse on both sides of the defrost heater. You will need to replace the whole heater if one of those fuses blows. Check these fuses with a volt meter if the defrost heater doesn't work.
A quick check if you have a cooling problem is to inspect the evaporator coils. If there is a build up of white snow on the coils, this indicates a frost free problem; if there is balled ice on part of the coils with the rest bare, this indicates a system problem, like a problem with the pumping compressor.
Hoping this will help in solving the problem...
Jul 03, 2011 | Whirlpool Refrigerators
Whirlpool 6th sense side by side fridge/freezer 25rid4 model,freezer working fine but fridge part does not cool
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Oct 30, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
I have a Frigidaire FRT04GM fridge. The Fridge stopped working. I looked in the back and found what appears to be a timer with a small opening for a screwdriver. I reset the Timer and it worked for about...
I think you are thinking correctly...:-)
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
heatman101
Sep 21, 2010 | Frigidaire Refrigerators
Hi.. i am having whirpool 6th sense double door fridge.fan is working but cooling is not there.guide me
Step 1 – Find the Problem
* Evaporator fan – Make sure it is working. If it is now working you may have a problem with the fan motor. Check for power to the motor and also examine the fan switches around the door (not all fridges have these switches).
* Air damper – Sometimes the air damper will not open up to allow the cold air from the freezer part to blow into the fridge section.
* Condenser coils – Check to see that the condenser coils don’t have a dust build-up and that the condenser motor is working.
* Compressor – Make sure your compressor is working with on and off clicking noises.
Step 2 – Frost-Free Failure
Step 3 – Find the Timer
Step 4 – Volt Test
If the heaters do not come on, use a volt meter to ohm test the defrost heater or volt test for 120 volts to the heater. You can bypass the defrost thermostat if you haven’t got power to the defrost heater to check if the defrost heater will come on. To bypass the thermostat, join the two wires together. Replace the defrost thermostat and the defrost timer if the heater comes on now.
Many fridges have and inline fuse on both sides of the defrost heater. You will need to replace the whole heater if one of those fuses blows. Check these fuses with a volt meter if the defrost heater doesn’t work.
Hope this helpout in solving the problem.....
Aug 17, 2010 | Whirlpool Refrigerators
Refrig was clicking on and off now nothing not cooling
heatman101
Aug 02, 2010 | Frigidaire FRS26H7CS Side by Side...
Double door fridge stops cooling, autodefrost not working
It wud need a new defrost heater, the fridge gets its air from the freezer , if the defrost heater does not work , ice builds up in the airduct , equals to no cooling in fridge
Feb 01, 2010 | Whirlpool 21.0 cu. ft. Top Freezer...
Freezer,Frost fan does not work,deos not destribute temp in coolr
Confused: You may well have a defrost issue but your description makes no sense.
https://www.repairclinic.com/RepairHelp/Refrigerator-Repair-Help
keep this link handy for future reference
I’m happy to assist further over the phone at https://www.6ya.com/expert/david_dc2f9e0a44104720
Oct 08, 2017 | Freezers
Fridge/Frezer stop working
Can you tell if the compressor (black soccer ball looking thing in the rear of the unit) is running? Is it really hot? Is the little fan running near it? If the compressor isn't running it won't cool. Also check that the coil in the freezer section isn't frozen solid blocking all air flow inside the unit. The other thing is that the defrost cycle may be "stuck" so it thinks it should be defrosting (therefore not running the compressor, etc.) Lots of things to check but that info will help decide which way to go so post what you find please.
Dec 30, 2006 | Zanussi ZX56 / 4 Bottom Freezer...
GE GSH25JSTSS Stainless Steel Side by Side Refrigerator Logo
201 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
