Question about Toasters
1148X Toastmaster Bread Machine
This machine gets way too hot - especially in the dough cycle. The dough is too hot and partially baked when I take it out to shape into rolls.
I have a E70052 Toaster Model T2001W K not a bread machine.
I have plugged it in to power and observe that it does catch when the handle is depressed.
Nor does it heat the coils.
  • 537 Answers
SOURCE: Russell Hobbs Toaster Model # RH4T9379
It would be NICE if you didn't abort the chat session when I was tyring to help you. Geez!!
Posted on Dec 03, 2007
SOURCE: only toasts part of bread
The solution I got from the FixYa team was: "Get a new toaster." Which is how I ended up with 4 new toasters that don't work. I'm glad I didn't PAY for THAT answer.
Posted on Sep 05, 2008
SOURCE: 1148X Toastmaster Bread Machine
why does the machine get so hot??
Posted on Jul 29, 2009
  • 30 Answers
SOURCE: Russell Hobbs RH2T toaster bread won't stay down w/o hold handle
Hi, most new toaster have a selenoid that hold down the handle while toasting then release when done so a spring bring the toast up. Possible problem with the selenoid, the electronic circuit that controls it or the plate that the selenoid holds. When you lower the handle you close the contacts of the AC line inside the toaster so if the handle is raised there is no power.
Posted on Aug 05, 2009
  • 109 Answers
SOURCE: Only toast one side of the bread
The other side that isn't toasting has an open element. Usually, the good side will burn twice as hot, and may have stressed that element. You might want to replace both in that slot. make sure you check the voltage rating plate. 208 and 240 volt toasters use different elements.
I just posted the procedure to replace elements, in a similar post here.
Posted on Aug 13, 2009
SOURCE: My toaster doesn't stay in the down (toast) position unless I hold it down
I solved this problem on my Cuisinart CPT-90 Classic Style Toaster twice for two different problems. Of course: make sure it's UNPLUGGED while working on it and WATCH IT several times when testing so you can unplug it first and then extinguish it if it catches on fire.
1st time: There is a small solenoid mounted in the center of the circuit board. When the pop up mechanism is pressed down the circuit energizes and the the solenoid magnetically locks a plastic clip that holds the spring loaded pop up mechanism down until it's done toasting. The plastic mounts for the circuit board broke or weakened until the whole circuit board would tilt up and the solenoid clip would slip under the spring tension. I used a plastic tie-wrap to hold the circuit board firmly in place and that worked to this day.
2nd time : The four copper reed tabs can be miss aligned. If they
do not make contact, the circuit will not energize the solenoid.
The reason they warped was that, over time, the contacts build up carbon and have more resistance. Resistance equals heat. The
plastic base of the copper reed switch melted and misaligned the reeds. The second time I cleaned the reeds and bent them back into position, The third time the the plastic was to badly burned to be reliable. If I had cleaned the contacts once a year, it probably would still work now. I haven't found a place to buy a replacement reed switch so my toaster is toast. If anyone knows where to order them, I'd like to know. If the white plastic base of the reed switch is not melted, then they can be cleaned and aligned.
Note: When aligning the copper contacts, don't just hold down the pop up mechanism. The pop up mechanism will push lower than the position for toasting. Push it down and then hold the solenoid clip instead. Then the two center reeds will be at the correct spread.
Posted on Jun 26, 2010
0 characters
1 Points
P90D23el-b1a microwave
Try putting butter on the bread before putting it in the machine.
Jun 23, 2014 | DeLonghi DTT900 2-Slice Toaster
Why do all toasters have a setting that burns all my toast to a crisp?
The highest setting on most toasters is not meant for sliced bread straight from the bag. The highest setting should be used for frozen bread.
Jul 15, 2012 | Franklin Machine Products DIAL, THERMOSTAT...
Do I have to wait for the toaster to warm up or put the bread in then switch on
Letting the toaster heat up first before putting in the bread is really just a waste of electricity and is unlikely to improve the efficiency of the machine or the quality of the end product in any way.
Just stick the bread in and then turn the toaster on and it should work fine. Within a short time you will learn just how long you have to leave them in so that they are toasted properly according to your own personal tastes.
Good luck.
Jun 14, 2011 | Toasters
Need parts diagram for toastmaster tp409 can't find need it for part # of switch.
If you are looking for 3 position (on-off standby) switch, the part number is 33388. Visit the toastmaster site at for verification and local sales office.
May 19, 2011 | Toastmaster TP409 4-Slice Toaster
I want Toastmaster TC17A3-FEC Toaster
contact sales agent of toastmaster.try visit
Mar 01, 2011 | Toastmaster TC17A3-FEC Toaster
Outter wires not working only toasts on the inside of the bread
Check the machine has not got a selected programme that switches off part of the elements...
Jan 31, 2011 | DeLonghi KT52 Cool Touch 2-Slice Toaster
Toaster won't stay down. Toastmaster Toaster
The contacts on my magnetic lock (lever) had some crumbs and build up on it. I had to take it apart but just cleaning it made mine work fine again.
Sep 21, 2009 | Toasters
Can an old Toastmaster toaster be refurbished?
there is no manual forthe repair of toasters . but the toaster you have is a common one on e bay , i dont see one right now but there have been a few over the years , and a well used one sells for around 10.00 , it may not work but its great for parts ( i collect and restore kitchen appliances) so i would take a look . you might find a cream puff for 20 .00 and put yours into retirement ..... other than e bay there not a lot of resources out there for parts . good luck ........Please if this answer helped , please rate this 3 or 4 stars . and keep me in the paid answer department . A 1 or 2 may knock me down into the unpaid ranks. Thanks Cactus Bob
Mar 05, 2009 | Toasters
Toastmaster toaster
thermostat seems to have given way, needs replacement
Sep 25, 2007 | Toastmaster TP409 4-Slice Toaster
Toasters Logo
Top Toasters Experts
Mike Cairns
Mike Cairns
Are you a Toaster Expert? Answer questions, earn points and help others
