Question about Toshiba 40H80 40" Rear Projection Television
Toshiba 40pw8db rear projection tv
Heard a small 'pop' lost picture and sound, but power is still getting to the set as the on/off standby light by the switch is still illuminated.
2 Suggested Answers
SOURCE:
  • 375 Answers
SOURCE: Toshiba 40PW8DB Rear Projection
the scan derived voltages are running ,not firing up the b+ voltages for remainder of the set to operate.pop migt have a cap ,ic etc. service required .
Posted on Apr 13, 2008
Vizio TV heard lot pop len lhen lost sound and picture but them comes on
l suspect power supply board has failed---someone would have to open and check all voltage going in and out of the board----if outs are missing (any) the board would have to be replaced.
If you get it open examine the filter caps on the power supply board to see if any are puffed up on top---the tops are silver and should be perfectly flat with no brown material leaking out at top or bottom.
I suspect based on description a component (likely a big IC) failed and they are usually covered with a metal heat sink (plate) so cannot be actually seen---they pop and dead set.
3_23_2012_2_48_04_pm.jpgTypical filter cap (capacitor)
Mar 22, 2012 | V, Inc. VIZIO RP56 Rear Projection...
Mitsubishi VS-45605 rear projection tv
If the green light is not lighting up, you will need to check out the standby power supply inside the TV set, or if this set has a DM board, you will need to change the capacitors. Good Luck
Jul 13, 2007 | Mitsubishi VS-45605 50" Rear Projection...
Pop sound and now no picture or sound still gets power
Try disconnecting all the cables from the TV then reconnect them after a few minutes. It's suggested that you connect the power cable from the TV directly to a functional wall outlet.
If still there is no picture on the TV then it's required to replace the projection lamp.
Sep 08, 2009 | Toshiba 57H81 57" Rear Projection...
Turned tv on, heard a pop, no picture, standby light blinks conti
POP goes a fuse in your power supply or maybe even a capacitor you need to have this repaired unplug this immediately. Take it to a local repair shop to have it fixed.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
May 03, 2009 | Sony Grand WEGA KDF-42WE655 42" Rear...
Tv black, no sound
is there any led or small lights on front panel ... red green or flashing
Aug 08, 2008 | Toshiba 46H84 46" Rear Projection...
Apr 13, 2008 | Toshiba 40H80 40" Rear Projection...
Toshiba 42 in 720 DLP TV MODEL HM66
You need to replace the lamp in this set. The "pop" you heard was the lamp popping.
Josh
Feb 24, 2008 | Toshiba 42HM66 42" Projection HDTV
No sound or picture
What is your model number
Jan 08, 2008 | Televison & Video
Toshiba tz50v51 popping sound
Possible problems: * The TV set may be unplugged. * A fuse or circuit breaker may be blown or switched off. * The remote control unit (RCU) may be disabled. Solutions: * Make sure the TV/VCR are plugged in and the wall switch is on. * Check the fuse or circuit breaker. Test the outlet with a lamp. * Replace the RCU's batteries: if this fails exchange the unit.
Jan 18, 2006 | Toshiba TZ50V51 50" Rear Projection...
Toshiba 40H80 40" Rear Projection Television Logo
137 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
