AMPLIFIER CAN YOU HELP PLEASE, WE HAVE NO POWER IN BEHRINGER AMP, WE HAVE CHANGED EXTERNAL FUSES AND STILL NO JOY.
Problem #1 you bought a behringer amp. Solution. buy a new amp
Posted on Feb 12, 2008
SOURCE:
I want to purchase a behringer 15 band graphic equaliser and connect it to a numark 5000fx mixer via skytec pro600 power amp can you help.
The signal path to follow is explained below:
*Audio Source(Cd/LapTop/Ipod)output to,
*Numark 5000FX Input, Then master/main outputs go to,
*Behringer FBQ1502 Inputs, then outputs go to,
*Pro600 Power Amplifier Inputs, then power amp outputs hooked up with a speaker each side.
Hope this helps.
Nov 06, 2013 | Behringer FBQ1502 Ultragraph Pro Dual...
My bass amplifier requires a ceramic fuse T10H250V. Where can I find one exactly like it?
hi,
Fuse breaks when it has succeeded in limiting further damage.
Check for other possible shorted electrical and electronic
components.
• Could be drive transistor , output transistor or both on the main amp.
But check for power supply and in the preamps also.
• Measure supply voltages,
• Check DC offset voltage
• Check idling current (main amp)
Isolate , and trace afterwards.
Aug 22, 2012 | Behringer Audio Players & Recorders
Behringer epq2000 power amp, limit lights stays on and no sound.
have the same problem... no solution found for mine.. and you?
May 13, 2012 | Behringer Epq2000 Professional Power...
I have the Behringer 10watt amp used but it wont power on at all...
Please open the amplifier and check from the power supply to the output section. You will need a multimeter to check for the ac input , then the fuses, the switch continutiy and the output secondary section ac. Now the DC to the circuits, the rectifiers, the filter capacitors, fusible resistors. Once the power is coming over to the main board and to the output drive, the premap section needs a check . The fault will be around this section if the outputs are clean. hope this helps.Good day
Jun 10, 2010 | Behringer Audio Players & Recorders
Both fuses burnt and both clip and signal led on? seems to have full power behringer ep2500
Suspect an overload in either the power supply section or the devices on the main heat sink. In the power supply you are either looking at a transformer problem or semi-conductors associated with it. However since the clip and signal lights are on, I would go to the amp devices on the heat sink. If they are transistors test them with a Ohm Meter on the 1K setting in circuit even! You will soon notice which ones are gone! The meter will show like you had touch the test probes together!
May 15, 2010 | Behringer EUROPOWER EP2500 Amplifier
The fuses have blown due to a short circuit, ie some part acting like it was a piece of wire. The chances are (with the LED's showing) it's the main amp semiconductors (on the heatsink) that have gone. The cause is either connecting a wrong (unsuitable) speaker(s) for the job, or letting the two wires (to each speaker) touch each other.
Mar 28, 2010 | Behringer EUROPOWER EP2500 Amplifier
Nothing comes on on a europower ep2500 power amp
Hi...
Check fuse in the rear where AC comes in and there should be a couple of small fuses ( 20mm long ) inside the amp. CHeck those too
Mar 15, 2010 | Behringer EUROPOWER EP2500 Amplifier
Behringer ep 2500
if after the pop it smells like a firecracker just went of than you fried the circit for that speaker or if it has fuses on it or ferther down the wire check them but it could be just the radio and nothin to worry about:)  a friends car does it, and it is very anoying
Jun 01, 2009 | Behringer EUROPOWER EP2500 Amplifier
How would i conect a ep2500 amp two 2 subs @ 4 ohms, or 8ohms
hey" i got 2 behringer 2500 amps and i have 2 peavey speaker that are 4 ohms 2000 watts eachand want to mono the amp separte,and i want to run 1 amp to each speaker so can you help me?
Nov 26, 2008 | Behringer EUROPOWER EP2500 Amplifier
Pyramid pb8 45x amp bein an ass
too much input, lower the volume of source.
Jan 31, 2008 | Pyramid PB845X Car Audio Amplifier
73 people viewed this question
 Grubhead
Grubhead
Marvin
Marvin
