FixYa.com
Tags:
Quasar VHQ401 VHS VCR
Use of tv channel 3 or 4
posted by DonLin on Nov 28, 2007
I bought my Quasar VCR in NY. I have moved to Florida where both Channels 3 and 4 are used for tv. How do I set my VCR? I doesn't work on either setting.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Dec 29, 2007
Not Rated (0)
sedonix
Rank:Guru Guru
Rating: 86%, 436 votes
You either have to choose either 3 or 4 or - instead of connecting to your TV through its tuner, go directly to the Audio/Video inputs using A/V cable (also known as RCA cable - probably has red, white, and yellow ends) Connect it from the color coded outputs on the VCR to the similar inputs on the TV. The TV may have several sets to choose from. Take you choice, but set the TV's input selector to this same designation when you want to watch the VCR. Sometimes its is called "VIDEO" sometimes A/V, sometimes "AUX"
Was this solution helpful? Show your Appreciation by rating it:
Can you Help with these VCRs problems?
VCRs
orion vcr model vr0210
do not have manual. can put in... Answer This...
VCRs
VCR eating tapes when...
Everything works fine on my... Answer This...
VCRs
setting date on my JVC HR 636U...
I cannot change the DAY on my... Answer This...
VCRs
date setting
I cannot figure out how to set... Answer This...
VCRs
power problem
no function is working, head is... Answer This...
Repair Service
Find VCR Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
