Question about Kenmore 62642 / 62644 / 62649 Microwave Oven
Troubleshoot why light underneath doesn't work on kenmore 62644 microhood
Everything works with the microwave except the underneath lights and now also the light inside when you first open the door...when you close the door and set it to start then the light inside comes on...what's up???
how and where do I get the part to fix this problem
thank you,
debbie zigal
[email protected]
  • burnselk Nov 19, 2008
    I have the very same problem on my Kenmore model 721.67601790 microwave. My two "beneath the cabinet" bulbs are both good but they will not work. My fan works fine and the light inside the microwave works fine.....but the two bulbs at the bottom of the microwave do not. I can't recall if I unplugged the microwave when we first had trouble with these lights or not.
  • Kenmore Master
  • 9,173 Answers
We see this a lot. The problem is on the control panel, which we regularly repair nationwide for $39.95 postpaid.
We see this a lot. This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
This can often also affect the exhaust fan operation, too. The lights and fan can be inoperable or stuck on too.
Details of our service and critical safety information and disassembly information is at our site, linked here on Fixya:
http://tinyurl.com/yzjozk
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Nov 28, 2007
SOURCE:
Magic chef MCD1611ST microwave, the display lights up, the time and powerlevel can be set, the light works when the door is open but when i hit start everything shuts off. Any suggestions?
There are a lot of possible causes, but I'd look at the door switches first, and the wiring connectors to them. Make sure the contacts on all the switches are opening and closing.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/david_29ad5d1dd86564b0
Nov 19, 2016 | Magic Chef MCD1611ST Microwave Oven
Why won't my interior microwave light turn off and my microwave won't start?
It sounds to me that your door switches aren't working.Your oven is protected by a couple of switches that engage when you open or close the door.They control a couple of safety features and also your interior light.One of them seems defective.
Dec 17, 2014 | KitchenAid Microwave Ovens
Frigidaire microwave not working
Is the door closing properly? Do you hear it "click" when it closes. A lot of times the problem is the door switch. It is located inside the microwave. They are made of plastic and they break. If the switch is broken, the magnetron(microwaves) will not start.
Mar 27, 2014 | Microwave Ovens
Frigidaire microwave fmv156dcc
There could be an open fuse inside or a failed magnetron.
The fan and light com on when the door is open and the carousel turns. When you close the door everything stops.
Check the door interlock switches, you may have a faulty switch or a blown fuse inside the microwave.
Dec 31, 2010 | Emerson Fans Emerson MW8115SS Microwave...
Nothing is hot - everything is on
Check the door safefy interlock switches before you plunk your $ down.
If you open your oven to check the contents without turning the oven off first ... the tiny switches arc and start to burn ... once they cannot make contact ... the oven doesn't know if the door is open or closed so it will not turn on the heat.
It is worth checking ...
Jun 26, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
GE 1800 XL not heating, no power, except fan works and clock also
Hello :
It could be bad door switch or loose door switch mount . There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
or it could be problem with the control panel .
good luck .
please rate !
Mar 29, 2010 | GE XL1800 1100 Watts Microwave Oven
Tappan microwave turns on but will not heat at all....still cold after heading for several minutes.
Test your door safety interlock switches. If you are like me, you 'turn it off' by opening the door. This causes arcing at the little contact in these micro switches. Eventually, the contacts inside burn up and cannot make contact. If they cannot make contact, the machine doesn't know if the door is open or closed.
Unplug the machine - do not touch the silver thing inside - potentially lethal! - check with a volt-ohm meter. The switch should read "open" when the door is open and "closed" when the door is closed. If it reads open when the door is closed, the microwave doesn't know the door is closed so it will not turn on the magnatron.
Yes, everything else will work except the magnatron if this $10.00 switch is broken. Buy a replacement at a electronic parts or appliance place. Be ready to give make and model of your machine.
Let me know how this works for you.
A
Sep 13, 2009 | Electrolux Microwave Ovens
Underneath Light funtion stopped working on Kenmore 62642 model
Details of our service and critical safety information and disassembly information is at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
Feb 17, 2008 | Kenmore 62642 / 62644 / 62649 Microwave...
Light Stays ON Inside - GE JE2160
It may be a stuck relay on or other problem on the control board.
We repair these on a regular basis for customers nationwide with our guaranteed $39.95 service.
It's possible but not likely that you have a bad door swith or door switch mount.
If you or a friend decide to look into it, we have critical safety information, info on door switch diagnosis and replacement, and
disassembly information at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
Please write back with more details if you need further help.
Nov 30, 2007 | GE JE2160 Microwave Oven
Kenmore 62642 / 62644 / 62649 Microwave Oven Logo
130 people viewed this question
Top Kenmore Microwave Ovens Experts
William Miller
William Miller
Steve Allison
Steve Allison
Jaime Hernandez
Are you a Kenmore Microwave Oven Expert? Answer questions, earn points and help others
