Question about Motorola Mobility H500 Wireless Headset
Battery replacement How do I replace the battery in an H500 bluetooth headset? Unit's not connecting properly anymore. It's over a year old. Not keeping a charge. Ready to pry chassis apart to get at battery. Don't want to break unit.
  • 1 more comment
  • Mark Conty Dec 29, 2007
    I'll keep looking, but I'm curious how to get the "M" off...?
    ... and are we talking about the "M" in front or in back??
  • oldearpeace Jan 03, 2008
    Just what I needed.
    Thanks.
Oh, I found it!
What comes off is the T-shaped chrome piece on the topside. To pry it off, start at the blunter end of the H500, on either side of the USB port. And note that this chrome piece is just a veneer, sitting on top of the black (in my case) plastic housing.
This web page shows and discusses the disassembly process, on the way to reusing the H500 innards for something else:
http://badacetechshow.com/BT%20Hat%20Pg.2.html
See ya...
-- Mark
Posted on Jan 01, 2008
  • Mark Conty Jan 01, 2008
    Oops, there's more. The "M" disk on the top seems to be held in place with a mild adhesive. A very finely-tipped screwdriver worked to gently pry it off. And sure 'nuf, as the Guest above indicated, there's a screw underneath it, the removal of which permits you to pop apart the upper and lower halves of the device. Carefully, though, because there are two very small, twisted wires that connect the two halves. (I'll shut up now... :-)
    -- Mark
Screw under the M, cover around multifunction button comes off to reveal 2 screws, remove to access
Posted on Dec 27, 2007
HOW TO CHANGE BATTERY HEADSET H500
Why do you think you need to replace the battery? A common sign that your Motorola Bluetooth headset needs a new battery is when you repeatedly hear five quick high tones in successive, one-minute intervals. Another symptom of a low or dead battery is when you try to scroll to Power and your headset doesn't come on. The Motorola H500 headset has a long battery life, but the battery eventually will go bad. Unfortunately, the battery is integrated as part of the headset's circuitry and should not be replaced by its user. Motorola strongly advises against trying to change the battery. Attempting to replace the battery voids the headset's warranty. By sending the headset to Motorola for repair, you can have a new battery installed without the risk of damage to your equipment.
But you can try the following at your own risk:
Locate the battery door at the rear of the headset and open it.
Remove the old battery. Install a new battery to match the plus and minus illustrations on the battery compartment. Shut the battery door back in place.
Select "Menu" on your phone. Select "Settings."
Select "Connection," "Bluetooth Link," and "Setup."
Select "Power." Select "Change."
Select "On," and then press "Select."
Press the "Call" button and hold it down. Release it when the LED light blinks.
Oct 11, 2014 | Motorola Mobility Universal Bluetooth...
HOW BATTERY TO CHANGE ON A H500 HEADSET?
Hi Anonymous,
If you are experiencing problems with the battery of your headset, the best is to get in touch with our support team, you can do that following this link: http://bit.ly/ContactUs-Locate
Regards,
Gaby
Motorola Mobility
Blueparrot B250 XT - 2 months old - battery will not hold charge. When plugged into charger a solid green light is on.
If your headset is showing a green light when it is plugged into the charger it means the battery is receiving power. If you remove the unit from the charger and it will not turn on or function properly there is likely an issue with one of the control circuits. Without seeing the unit we would not be able to tell you which circuit is experiencing some sort of issue but the unit does need service. The VXi, Blueparrott B250-XT has a one year repair warranty from date of purchase. Please call our After Market Services Department at 800-742-8588 x2011 to obtain a return authorization number (or RA#). After you have received your RA# you may send us your headset to us via any means you choose (prepaid) with your RA# marked on the package, please include a copy of your invoice or receipt. If you do not have a copy of your proof of purchase we use the production date in the serial number as the warranty default start date. The After Market Services group will either replace your unit with like new product or repair your headset as necessary. In either case, our goal is to turn the unit around for outbound shipping in two business days (please note this goal can be affected by volume at the time your unit arrives).
We hope this information is helpful to you. Feel free to visit us on line at www.vxicorp.com for more details on our warranty process as well as FQA information for all of VXi's products.
Jul 30, 2011 | VXI Corporation Blueparrott B250-XT...
Motorola Razor V3M and H500
This is a common issue with headsets is they stop working properly when they go bad. Not all of them of course, and the symptoms are different. Take it back and get a replacement.
Aug 25, 2008 | Motorola Mobility H500 Wireless Headset
Broke the ear hook for the Motorola h500 bluetooth headset
They do not make earhooks alone. You must send it back and they will replace the whole unit.
May 12, 2008 | Motorola Mobility H700 Headset
How do i connect H500 to my phone
Hey guys. found it. Go to
www.simoncells.com
then go to manuals
than click on the H500 Bluetooth.
It will walk you through step by step its pretty easy..
Or, you can do it easier.
- Press and hold the Power/Call buttom for 6-10 seconds, until there is a steady blue light
- when there is a steady blue light, go to your phone's Menu, then click on Bluetooth, than Handsfree, It will then start locating your bluetooth. In about 3-5 seconds it will pop up as H500.
-Connect to H500, or push Yes to Connect. (which ever way your phone tells you)
-It will then ask for a password. ALL PASSWORDS ARE THE SAME;AND CANNOT BE CHANGED.
- YOUR PASSWORD IS 0000. typle that in.
Congratulations! Your Now Connected.!
Good luck guys.
Any questions, im on here usually every other day
Ed
Feb 18, 2008 | Motorola Mobility H500 Wireless Headset
H500 bluetooth
AFTER CHARGING headset hold down big button in center of headset until BLUE INDICATOR LIGHT REMAINS SOLID BLUE
tHEN TURN THE BLUETOOTH OPTION ON YOU CELL ON
GO IN TO MENU UNDER BLUETOOTH OR CONNECTIONS SELECT ADD DEVICE YOUR CELL WILL SARCH FOR DEVICE WHEN IT FINDS IT THE NAME OF THE BLUETOOTH WILL APPEAR ON DISPLAY CELL WILL THIS ASK CONNECT OR BOND WITH DEVICE SELECT YES IT CELL WILL ASK FOR PASSCODE PUT IN 0000 THEN AFTER THIS BLUETOOTH HEADSET SHOULD START FLASHING INDICATING HEASET HAS CONNECTED
Dec 31, 2007 | Motorola Mobility H500 Headset
Problems With Pairing H500 and Motorola V190
1.Press and hold the Multifunction button in the middle of a boom headset while the headset is closed. The light will glow blue.
2.Open the boom microphone and the blue light should remain on. If not, repeat step 1.
3.On the cell phone, press Menu > Settings > Connection > Bluetooth > Handsfree > New Device
4.Select H500once a connection is detected.
5.The passkey "0000" is now entered to confirm the connection has been made.
6.The cell phone screen will now read "Bluetooth Connection".
Tips:
1.Provided you set the Bluetooth power to "On" after the initial connection has been made, the phone will automatically re-connect to the headset.
2.To set the Bluetooth power on - Press Menu, Select Settings, then Connections, then Bluetooth link, scroll to Setup and select that. Scroll to Power and chose Change. Scroll to On and press Select. The screen should now read "Changed: Power On".
3.Test Your Connection: Close the headset and watch for cell phone to say "Disconnected". Re-open the headset and the phone should be connected automatically and will now display "Bluetooth Connected".
please give good rating if the solution works.
Thanks for using FixYa.
Dec 24, 2007 | Motorola Mobility H500 Wireless Headset
It's on but earphone not working
Remove the battery from the phone then re-insert the battery. Try to pair the device again.
Nov 01, 2006 | Motorola Mobility H500 Wireless Headset
Motorola Mobility H500 Wireless Headset Logo
3,376 people viewed this question
Top Motorola Mobility Radio Communications Experts
Lawrence Oravetz
Dennis
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
