Question about Panasonic SC-AK200 CD Shelf System
Remote problem remote will not operate the player at all, batteries are correct and ok.
  • 682 Answers
Dear friend:after apply fresh and new battery and install it in right direction bring an normal radio set -put it in am postion tune dial in position between channel and press power button in remote many times you will hear clicks eash time you press the button if you hear the clicks clearly the problem will be in the player .
Posted on Feb 24, 2008
SOURCE:
Why did it suddenly stop working?
the "pat answer" is the magic smoke leaked out. all electronics work on magic smoke, once it gets out of a device, the device wont work anymore. OK smoke comes from burned out devices. Point the remote at a digital camera and watch through the view finder, does the led in the remote light up? (you cant see it with the human eye) if so next step. plug the dongle into the TV, select the correct input and point the remote directly at the window on the dongle and try to operate the fire stick, if it works, you may need an HDMI EXTENSION cable (male to female) to move the dongle to a position where it isn't blocked from the view of the remote. Also, can you operate it from your computer using Google Chrome and the correct firestick extension? (incase the remote isn't infrared operated)
Apr 03, 2016 | Amazon Fire TV Stick
Remote problem
Find the web-site for your remote control, and download the manual for the remote. The remote needs to be programmed to send the correct signals to your TV.
Jan 19, 2014 | LG RH1999H DVD Recorder/HDD Recorder
Remote stopped functioning for dvd\vcr unit
When the remote control won't operate the DVD player recorder, check the batteries. Try replacing them and see if the remote works. If the batteries are fine, the code on the remote and the code on the DVD player recorder might not be the same. When aiming the remote at the unit a number will be displayed. To set the remote to the same number, which will be 1, 2, or 3, press down OK on the remote as the appropriate number at same time.
God bless you
Sep 27, 2012 | Samsung DVD-VR375 DVD Recorder/VCR
I get set 3 when i press the remote and nothing else no matter what i press play etc any suggestions
Try reprogramming the remote so it matches the unit. If you get SET 3 or DVD 3 on the display, chances are the remote's command code is different to the unit, in which case the following may help a bit:
Ensuring new batteries are in the remote, correctly polarised ( + and - ) and with the remote pointed at the unit (while unit is on), press and hold both the [3] and [ENTER/OK] buttons TOGETHER for 5 - 10 seconds, then release. The remote should now fully control the unit.
If it doesn't, check the batteries and repeat the above. The above procedure is a suggestion based on Panasonic DVD recorders and their operation troubleshooting manuals. Give it a try at least.
Aug 14, 2011 | Panasonic DMPBD45 BluRay Player
LG 42PX4MVH remote control does not operate the TV, it seems that it needs to be re-synchronised, how do I do it? The batteries was replaced yesterday and the lights on the remote control flashes and...
Hello
If you are using its original remote control handset with this set, replacing batteries will poise no problem at all. If remote control does not works properly check the following.
Check to see if there is any object between the TV and the remote control
causing obstruction.
Are batteries installed with correct polarity (+ to +, - to -)?
Correct remote operating mode set: TV, VCR etc.?
The light at its side
Illuminates the remote control
buttons of selected mode.
OK.
Apr 26, 2011 | LG 42PX5D 42 in. Plasma HDTV
I entered,in error, Command mode 3 on the set up and now the remote control won't operate the machine.The display keeps showing DVD 1,how do I restore things?
Try this (works for Panasonic) - remove the batteries from the remote (as if to replace them with new ones), press any button on it to clear its buffer, then re-insert them (if they are reasonably fresh). Point remote at unit, press 1 and ENTER/OK buttons together - hold for 10 seconds, then release. This should restrore the command back from remote to the unit, and it should now fully operate. Just something to try, it may work.
Many Panasonic DVD recorders operate on the same principle; there are 3 remote command mode settings (default is DVD1) - so it's very easy to make errors in setup, but just as easy to correct.
Apr 18, 2011 | Sony RDR-VX420 DVD Recorder/VCR
My Blu ray player keeps flashing an "RC-1" error anytime a button is pressed on the remote.
Remote command mode is different to the unit. Try resetting the remote by doing the following;
While unit is on, but no discs loaded or playing, remove the batteries from the remote (as if you were replacing them), press any button on the remote to clear its buffer, then, if the batteries you removed are OK, re-insert them. Point remote at the player, press and hold 1 and ENTER/OK buttons together for 10 seconds, then release. This should restore your remote's command to the original default mode, and it should control the player fully.
Panasonic and some SONY units operate on this principle with remote command modes (these differ between models). RC1 / DVD1 / SET1 is usually the default.
Very easy to do, takes a few seconds, and costs nothing.
Apr 18, 2011 | Sharp BD-HP21U Blu-Ray Player
When i push the buttons on the remote it keeps saying set 1
The remote is probably set to another command mode (for example, SET2, DVD2 or RC2 depending on the model unit) or the batteries were replaced recently, so the remote needs to be reset. You can try this: take the batteries out of the remote (as if to replace them), press any button to clear the remote's buffer, then re-insert them. Point the remote at the player, then press and hold 1 and ENTER/OK buttons together for approximately 10 seconds, then release. This should restore the remote's function back to your player. This 'remote reset' must be done whenever the batteries are replaced, otherwise either the remote will not function correctly, or the device will not recognise it.
Very simple, takes a few seconds or so, and costs nothing to try.
Apr 17, 2011 | Panasonic DMP-BD30K Blu-Ray Player
When I press any button on remote it says set 2 and i can't fast forward etc
You could try resetting the remote itself (remove the batteries as if to replace them, press any key on the remote to clear its buffer, then re-insert them or use new batteries) - since your unit is on remote command 2 (or SET 2), try pressing 2 and ENTER/OK on the remote together for 10 seconds, then release. This should now restore your remote to the correct command mode for your player. It may also solve the playback function issue.
The remote for most Panasonic DVD units would need to be reset whenever the batteries are replaced.
I understand the instruction manual does not always help the user.
Apr 08, 2011 | Panasonic DMP-BD30K Blu-Ray Player
I have just purchased a magnavox blue ray dvd player, but I cannot get the dvd player to operate after I press the startup button on thed remote.Can you please help me. Thanks
naturally, make sure everything is plugged in correctly, and that the batteries in the remote or charged.
if the player is new, you might want to check the manual to make sure you are operating it correctly.
if the player is not new, and has worked in the past, then the problem is probably something trivial like batteries, or wearing out of the iod on the remote, the plastic on the button in the remote, or something interfering with the signal.
Mar 27, 2011 | Philips Magnavox DVD/VCR Dual Player
Panasonic SC-AK200 CD Shelf System Logo
140 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Ekse
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
