Question about Maytag Performa PAV2200
Lid swith maytag washing machine. how do you replace the lid swith on my washing machine
  • 240 Answers
Open the top of the unit by placing a putty knife beween the top and the front panel about two inches in. There is a spring lock that you need to push in, then lift the top. Once you lift the top, you will see the lid switch. Remove and replace. Let me know if you need further help. Jim
Posted on Nov 29, 2007
MY MAYTAG WAS SPINNING BUT SLOWILY. NOW IT WON'T SPIN AT ALL. THE LID SWITH IS GOOD, WHAT ELSE COULD BE PROBLEM?
it could be your agitator troubleshoot the following to isolate the problem: Unplug the washing machine, and turn off the water supply to the machine. If necessary, remove the water hoses from the back of the washing machine because they may be in the way of the access panel. 2 Check that the agitator is seated correctly by opening the lid of the washing machine. If it's loose, pop off the top of the agitator--if there is one--and tighten the bolt that holds the agitator in place. Or, in some models, simply pull straight up and then reseat the agitator. 3 Remove the access panel located in the back of the washing machine by unscrewing the screws holding it in place. This allows access to the drive motor. 4 Press on the drive belt that works the agitator. If the belt moves more than 3/4 inch, tighten the belt to fix the spinner problem. If the belt is worn or cracked, replace the belt. 5 Replace the drive motor, if tightening or replacing the drive belt doesn't fix the agitator. Purchase a new drive motor at a wholesale retailer. Disconnect wiring, remove screws holding motor in place and insert new motor. Screw into place, and connect wiring. 6 Check for any black substance leaking under the washing machine. This might indicate a clutch problem, if the washing machine spinner is not working. Contact a professional repairman to replace the clutch.
Feb 15, 2011 | Maytag Performa PAV2200
Washer doesn't understand that the lid is closed and won't run. I took the lid off and tried to manually push in the swith but no luck. Washer is a Maytag Atlantic MAV6250
Door lock replacement vid and more good stuff
Bonus stuff: Wax motor 101 featuring R11 and Q6 swap out and other cool stuff
Note: both the motor control and the central control has to know that the lock is in place, so the wax motor does 2 things! It locks the door and then sends info back to the central control and the motor control on various models. So the wax motor is crucial. A red wax motor is a new and improved wax motor. What other smart pills have I got? Let see: Neptune washer manuals
Mar 27, 2010 | Maytag Atlantis MAV6451 Top Load Washer
MACHINE WON'T PUMP WATER OUT, STARTS WASH CYCLE THE WASHER GETS TO POINT WHERE IT SHOULD PUMP WATER THEN JUST STOPS. TRIED TO MOVE IT ONTO DIFFERENT SETTING TO PUMP OUT AND WOULD NOT WORK.
SOUND LIKE THE LID SWITH
YOU CAN BYPASS UNDER THE CONSOL 2 PLUG 1 IS POWER THE 2ND IS YOUR LID SWITH SPLICE WIRES LEAVE THE GREEN WIRE PLUG BACK TOGETHER
Jan 31, 2010 | Washing Machines
Kenmore stackable mod number 417.94802301
check your lid switch. if your lid swith is bad, it will fill and agitate, but will not pump or spin. therefore it will not go into rinse cycle without being able to pump out water. some lid swithes control the agitation also (usually frigidaire and older maytags), but i doubt yours does. you can check the lid switch for continuity while opening and closing the lid with a meter
Apr 30, 2009 | Kenmore 98702 Stacked Washer/Dryer
Washer quit
sounds llike a bad lid switch assy, not realizinf the lid is shut, for safety reasons wont run, can you hear any "click" just before the lid actually closes, it should be triggering the lid swith, if no t reppalce the lid switch assy, reall common issue
Apr 17, 2008 | Washing Machines
Maytag MAV6257AWW Washer
Could you describe the noise you are hearing. This will help to determine what to look for.
Jan 13, 2008 | Maytag Atlantis MAV6451 Top Load Washer
Frigidaire Wash Machine
It may be it the Lid switch... bad lids swithes will stop washers from going into the spin and pump out cycle...
Sep 11, 2007 | Frigidaire GLWS1233A Top Load Washer
Washing Machines Logo
85 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
