Question about Mitsubishi VS-5043 50" Rear Projection Television
Convergence My tv's convergence is all messed up,Is there a code for internal convergence?convergence I have access to on TV doesnt solve problem
    Genius:
  • 1,694 Answers
1) Repair convergence circuit = replace STK IC's
2) Reset alignment with customer controls
3) Internal alignment,if needed.................................T.
PS. Major hand re-solder will be needed when chassis is out.
Preventative,necessary...............
Posted on Nov 29, 2007
SOURCE:
My R56WH78 tv has lost convergence overnite,I can not access any convergence menu with the remote control,What should I try next.
This RCA tv model have a dead convergence fuse at FL231 at the right side of a FBT- a big black plastic block with a wire hook to a board.Must resolders the FBT-(Flyback tranformer too).U have all the tools and also can do basic soldering work too?Yes,try website like Ebay.com to by the RCA tv convergence fuse to replaced at location FL231 and and also resolder FBT-Flyback tranformer too.Will solved this tv RCA model convergence problems.
Aug 02, 2011 | RCA R56WH76 Projection Television
When I first turn on the TV the picture is messed up sometimes it shows a double picture.If I turn it on then off and back on again the picture is fine.Whats wrong? My second problem is that when I turn on...
Ur tv covergence board it is dying.Tv are developing a convergence picture problems.Tv have colors R,G,B lines mis alignments,have colors shadows pictures or 3D pictures look alike?Yes,than the tv convergence board it dying must require replacement like 2 STK convergence ICS and some or all of it resistors too.Fixed the tv convergence board to solved the tv convergence picture problems.The shop will cost u like $300-350 for parts and labors.
Jun 30, 2011 | Mitsubishi WS-55819 55" Rear Projection...
I bought this model from a friend and he mentioned that when moving the tv around it might get bumped a little bit and this could "throw the colors off". HE said i could pop the outter casing off...
Tv now have colors R,G,B lines mis alignments,have colors shadows or 3D pictures look alike?Yes,this tv have a problems known as a convergence problems,sorry but ur friend screw u over.This tv the convergence board is dead.The tv convergence board require replacing 2 STK convergence ICS and some or all of it resistors too.Fix the convergence board to solved the tv convergence picture problems.U have all the tools and can u do basic soldering?Yes,tries websites like Tvrepairworld.com,Tvrepairkits.com to buy a convergence kit to repair it ur self.Or the shop,will cost u like $300-350 for parts and labors.
Jan 22, 2011 | Philips Magnavox 51MP392H Rear Projection...
Can a hitachi convergence be fixed without a remote? seems like red is adjustable, but cannot access the blue line with our universal remote
Ur universal remote was able to move - + from the convergence grid wright,it is a good remote.The tv convergence board is dead.The tv convergence board the 2 STK convergence ICS and some or all of it resistors are dead too.These parts must be replaced on the tv convergence board to solved the tv pictures convergence problems.The shop,will cost u like $300-350 for parts and labors.
Dec 19, 2010 | Hitachi 43FDX01B TV
52" projection, colors have seperated making images in triplicate
Go to the main menu on your TV and scroll down to picture then press select. Then scroll down to convergence and press select again. Next follow the on screen instruction on how to perform a static convergence on your set. If this doesnt solve your problems check all capacitors in the convergence section of your TV. If problems persist replace both convergence chips.
Aug 13, 2010 | GE D52GW12 52" Rear Projection HDTV-Ready...
52 inch (Model D52W19) RCA TV's sound doesnt work
internal / external selector switch on back of tv near inputs or setting in menu under settings or sound labeled - internal amplifier/ external amplifier.
Sep 28, 2009 | RCA D52W19 52" Rear Projection Television
KP-53HS30 RE-SET CONVERGENCE MANUALY
that is not posible is a prosses that first you need to get in to service mode and if you don't know what you are doing you mess up your tv I' could give you the code but is leting you mess up or buying another tv if you still call me any time 520-248-4242
Nov 25, 2007 | Sony KP-53HS30 53" Rear Projection...
Color problem/ convergence menu help
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Sony Convergence
http://www.techlore.com/blog/entry/19694/Sony-Convergence-Repair-My-Sony-TV-has-a-distorted-picture-/
http://www.techlore.com/article/19631/Sony-Convergence-Procedure/
Nov 08, 2007 | Samsung HC-P4363W 43 in. TV/DVD Combo
Magnavox Projection Tv Problems!!!!!!!!
This is why if you don't know what you are doing in a tech menu, exit it! You will have to go through and do a full convergence alignment now. It isn't that hard but, not that easy.
Mar 24, 2007 | Philips Magnavox 9P6034C 60" Rear...
Televison & Video Logo
62 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
