Question about RCA F31672ET TV
Occassional bad noise and picture
RCA 32 inch ColorTrak Plus. TV is hooked to cable. I can produce the problem by wiggling the coax connector - even with no cable attached. TV is from October 1996 and belongs to my mother-in-law, age 90. Repair shop estimate is $95 to $105 to fix on site. Is it worth fixing?
rsjack307@charter.net
  • reb44 Nov 23, 2008
    TV is connected coaxial to cable (no box). Occasionally, the channel will go fuzzy and deterrioate all together. Going to coaxial cable and "moving it" will resolve issue.
    Genius:
  • 1,694 Answers
Bad ground connection in tuner.....good old set to fix and
older folks get attached and comfortable = why rock the boat?
If it lasts a couple more years.............................T.
Posted on Dec 23, 2007
How do I hook up my ps3 to my rca colortrak?
would be best to get a old vcr, then with a cable you hook it to the vcr and play it thru the vac
Mar 03, 2015 | RCA Colortrak 2000 Tv Large Tube Screen Tv...
How do i hook up mono tv with eterxnal speakers with a dvr box
If the DVR has RCA-type connectors, yellow to yellow for picture, and white to white for sound. Tune tv to line input.
If the DVR supports outputting everything on coax, use a piece of coax cable, and tune tv to channel 3.
Your coax cable from wall has to go into DVR first, then out to tv.
Aug 26, 2014 | RCA F32650 32" TV
CT-32SL 13 antenna busted off, how can we hook up
you can use your rca connectors for your cable if your cable box have rca all you need is rca jacks if you don't have a box and all you have is the coax , then you can use a vcr or a dvd with coax input and rca output "hope i explain this right {" tv-----rca's--2---rca jack output vcr ---coax input ---hook up coax CABLE
May 14, 2010 | Panasonic CT-32SL14 32" TV
RCA 27 inch ColorTrak Plus. TV is hooked to cable. I can produce the problem by wiggling the coax connector. The screen goes through various degrees of snowy-ness until I find the sweetspot on the coax....
The failure with this TV is due to faulty ground in the tuner that is why when you wiggle the cable connected to the tuner the picture clears up. If this failure is not repair, it will corrupt the data on the eprom until the TV will not power ON anymore.
Check the info from this link to find more info on the failure of your TV.
Let me know if you require further assistance.
Apr 12, 2010 | RCA F31672ET TV
LCD TV IS CONNECTED TO CABLE USING SATELITE. CABLE IS RUN APPROX 150 FT FROM SAT DISH TO TV. RECEPTION IS VERY GRAINY,,,IS IT THE LENGTH OF CABLE? THE CABLE IS 100FT CONNECTED TO 50FT CONNECTED TO TV....
Is the satellite receiver HD or standard?
If it is standard you should hook up the box to the tv via RCA cables (Yellow/Red/White) and this will help with the picture quality.
If it is a HD receiver then hook up the box to the tv using a component video cable and this will drastically change the quality of the picture.
Using a coax cable to attach from the box to the tv essentially is connecting an analog signal to the tv and this will produce a lower quality picture...
Good Luck!!
Jan 02, 2010 | Samsung LN32B360 32 in. LCD HDTV
How do I repair where the coax cable connects to my 13 in TV
go to RADIO SHACK and get a RF MODULATOR ,this will do the trick , good luck , AJ
May 22, 2009 | GE 32GT740 32" TV
TV Problem
The first thing is to check to see if the fuse is blown,if so replace with a 5 amp fuse,fuse is located near were the power cord connects to the board,make sure set is disconnected from power.
Feb 28, 2008 | RCA F32672SB 32" TV
Getting sound from DVD player but not a picture
Are you sure all cables are secure in the back and that all cables are in their appropriate place?
It could also be other variables dealing with the actual signal from the cable company. I have had an experience with an unshielded coax cable that was tweaking out due to a thunder storm.
Post back after you have checked all cables and also call your cable company to see if there are any problems with the broadcast currently, as that could be a cause.
Best of luck.
~Ominious Depression
Jan 08, 2008 | Televison & Video
Female coax connector in tv bad?
If your cable converter box has audio/video connections on the back of it,you don't need to worry about using that RF coax connector. Just hook it up the same way your DVD is hooked to the TV input jack. Get a 3-wire cable (yellow-red-white)hook it to the same colors on the back of the cable box and hook the other end to an unused input on the back of the TV. Then select that input with your remote and watch TV.
Aug 30, 2007 | Sharp 27J-S100 TV
RCA 25GT511 - fuzzy picture slight static sound; wiggle coax rear mount temp resolve
There might be a bad (loose) connection in the RF isolator or the tuner (both are silver boxes. Try to unplug the coax and bend the RCA tabs in so that the connection gets firmly made when reconnected. This may help. If it does not The connector may have to be replaced.
Aug 08, 2007 | RCA 32V550T 32" TV
Televison & Video Logo
101 people viewed this question
Top RCA Televison & Video Experts
jason
Steve Allison
Steve Allison
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
