Back to:
Tags:
GE DCSR483EA Electric Dryer
GE DBL333EAOWW dryer (by 3 users)
posted by jacarp on Nov 28, 2007
I have a dryer that has begun making a LOUD screaling noise when it is turned on. It seems to get better - and even goes away - when it heats up. Also it is better if the dryer is tipped forward.
I took the top off of the dryer and ran it but it did not even squesk. I put it back together and the squeal returned.
All the above led me to believe that there were bad bearings at the rear of the drum. I squirted some non-flammable LIquid Wrench lubricant through the back of the dryer where it looked like the drum was attached. That stopped the squeal but unfortunately some of my clothes have some scent from the lubricant and I think this is only a temporary fix.
If it is indeed a bearing problem, is there a awy to take the old ones off the rear of the drum and replace them with new ones?
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
2 Other Users Have The Same Problem
Comment by BGB1, posted on Apr 05, 2008
My squeaking is from the outside in the back at a contact point. There is a spring like metal piece which makes contact directly at the center of the the drum. If I lubricate it, the noise goes away for a period of time, but always inevitably comes back. Is there a particular type of lubricant to apply that will permanently help this situation?
Comment by soaky, posted on Jan 02, 2008
dryer is making a noise when running comes and goes
Best Solution
posted on Nov 30, 2007
Helpful (85)
GE-MAN
Rank:Apprentice Apprentice
Rating: 91%, 7 votes
yes ...order it... you re better off changing the 2 paire of slices on the front when your take off the front from the drum ...its grey or green or white ...they must be finish ...beware they're expensive ....
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on GE DBL333EAOWW dryer:
I don't want to Accept this solution
Can you Help with these Dryers problems?
Dryers
When you plug in a hotpoint tcd970 for the first time you...
Dryers
when i hit the control buttn or any other buttn nothing...
how can I get to the heat element for replacement alberto...
Hi, my GE dryer also won't keep running when i let go of...
buzzer at the end of drying cycle is not loud enough
Loading problems.
Repair Service
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
