Question about Jensen CD3610 CD Player
Searching for stations on its own
Every so often the radion will start searching on its own but it doesnt stop it just keeps going
  • 709 Answers
Hi Troubledinny,
I have had the problem before and it was the Tune button had gotten dirty inside the face plate. I got a can of Air from Radio shack, and blew out behind the button. You may have to open the Faceplate to clean yours.
Posted on Nov 28, 2007
SOURCE:
My google search keeps stopping and wont let me search anything what do i do to fix it
try to reinstall it if doesnt work instal firefox if will be much better
Jan 17, 2016 | Google Cell Phones
Want to install a motion sensor into a light switch
Paste this address into your browser for RS Components:
http://radionics.rs-online.com/web/search/searchBrowseAction.html?method=browseSection&Nty=1&Ntx=mode%2bmatchallpartial&Ntk=I18NAll&Nr=AND%28avl%3aie%2csearchDiscon_ie%3aN%29&Ne=4294957972&N=4294965241&Ntt=motion+sensor+%2b+switch
You can go to their main webpage http://www.rs-components.com/index.html , pick your country and search for motion sensor + switch and select electrical wiring accessories from the results.
Feb 17, 2011 | Microwave Ovens
Hello and thank you. There is no power coming from the Cigarette Lighter (power Outlet as listed in the manual) of my 2006 Chrysler 300 Touring. I have searched both fuse boxes of the vehicle and can not...
Fuse is located under the spare tire well and is in the fuse panel and is an 20 amp fuse that is slightly misaligned on the middle row of the box. This will fix cigarette lighter in ash tray in lower middle cluster of radio and a/c.
May 15, 2010 | 2006 Chrysler 300M
I am replacing radion in 2003 Chevy Venture Van and when i put the new radio in it says it is locked. How do i get the code to unlock it
Well, to start your search, simply check online. Type in the exact make and model of the radio and search for the unlock code. Or check the box the radio came in and look for a phone number you could call.
Apr 12, 2010 | Car Audio & Video
Water keeps filling and doesnt go to next cycle
Your pressure switch stops the water and allows it to start the next cycle. It's a switch either in the control panel or at the top of the tub with a small tube connected to it which goes down between the inner and outer tube. As the water level increases the air in the tube is compressed until there is enough pressure to make the switch stopping the water from filling. This tube can get clogged and the switch won't work. Remove the tube and clean it out. Blowing on the tube when it's still connected to the switch will make the switch if it's working and clear.
Sep 03, 2009 | Washing Machines
Motorolla headset h700 pair with blackbery
On the Blackberry, Go to Options, Bluetooth. Select the blackberry button, Add Device, and search. If search doesn work, try listen. While these are going conduct the following on the Headset:
Close theheadset. Go to the phone and choose discover, or search. Open the headset and pressand hold the big button. It should then turn purple and should be recognized.
Also make sure the battery on theheadset is charged before doing this.
If this doesnt work: Start the search onthe phone, Keep the boom of the mic closed when you press and hold the buttonon the h700. the light should turn purple. After this, open the boom
Jun 06, 2009 | Motorola Mobility H700 Wireless Headset
Panasonic CQ-C8300N CD Player Problem
i have the same problem but on a model cq-c5400w i suspect may be security feature ? have checked with logic probe happens inside main micro.
Aug 14, 2008 | Panasonic CQ-C8300N CD Player
How do I program the radion station?
The device you listed is a 6 cd changer, it does not hold radio stations.
As for the head unit in your car, you can try tuning in the station and then pressing and holding the location number you want to save it to (1-6).
That works for most of them.
You can add the model name and number to this question if that doesnt work.
Best of Luck.
Oct 12, 2007 | Xtreme Sound WMS6100RW 10-Disc CD Changer
Jensen CD3610 CD Player Logo
52 people viewed this question
Top Jensen Car Audio & Video Experts
Larry Tezekjian
Larry Tezekjian
Mike Duncan
Mike Duncan
xxxxxx xxx
Are you a Jensen Car Audio and Video Expert? Answer questions, earn points and help others
