Question about Whirlpool 24 in. DU1055XTPS Stainless Steel Built-in Dishwasher
Extremely noisy Whilrpool, sounds like electrical resistance.
My one year old Whirlpool DU1055XTPS makes a horrible noise when it is running. It seems to fill okay, and seems to enter wash cycle, but sometimes gets stuick in wash cycle, and other times goes through drain and rinse fine. The noise often changes pitch or frequency, but never really goes away. There are no error lights or warnings, and this noise does not sound like a buzzer, unless it is a seriously out of adjustment buzzer. There does not appear to be any parts or debris visible in the bottom of the tub, but I have not yet removed any parts. Noise seems to come from upper or middle left side, but there is a heat vent in the control panel, and maybe the sound is just resonating on that side because of this vent area? Please tell me what to look for, and how to fix this.
Thank you,
  • 14 Answers
Mine did that when the end of the impeller broke off- the sound is the grinding of the remaining end of the impeller against the gears on the engaging end of the chopper. You'll need to get out your screwdriver to dig in deeper and find out if this is the problem.
Posted on Dec 29, 2007
Loud buzzing noise throu8ghout cycle. Sometimes washer sticks in wash mode
It appears your timer/main controller/CCU has failed in this instance.
For replacement parts - head on over to or and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Mar 14, 2009 | Kenmore 24 in. 16352 / 16354 / 16359...
Loud continuous buzzing noise while dishwasher is running
Hi hope you are well have you checked that the dishwasher isnt touching your units either side their should be a slight gap either side you will get this noise if it is touching anything at the sides or pressed up against something at the back if this is not the problem.
If it is making the noise through most of the wash cycle the the chances are it isnt going to be a pump on the way out the only other thing it could be is the motor that turns the spray arms around and it could be either the top or bottom usually if you can get to the motors you can oil the moving parts as sometimes thse get dry over time.
Try the first sollution first try moving the dishwasher a bit and then try it again if still noisy then the chances are one of the motors has got noisy on the spray arms it wouldnt be the pumps as the noise continues through most of the wash.
Some times just moving the dishwasher will recitfy the problem as the same happens with fridges and freezers if it has been knocked and is not level or is touching a unit you will get a slight vibrating noise so try moving it a bit.
Let us know how you get on
Nov 28, 2007 | Whirlpool 24 in. DU1055XTPS Stainless...
The noise is coming from the power board may be a loose connection or a cold solder joint
How do you fix a noisy whirlpool dish washer DU1100XTP(Q) ?
A hard object has entered the wash module (on some models).
When the object is ground up, the sound should stop. If the
noise persists after a complete cycle, call for service.
Mar 12, 2009 | Whirlpool Gold 24 in. Built-In Dishwasher...
Washing machine will not spin
If this is a Whirlpool washer, you have a broken motor coupler
Jan 23, 2009 | Washing Machines
Motor makes loud rattling noise during rinse cycle
could be the coupler and the only way to truely check it is to take the pump, then the motor off. But it seems strange to me that you say it works fine. Is it spinning? usually when the coupler breaks it sounds horrible and usually will not spin but it will drain.I would check the coupler again.
Jan 05, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Violently shaking and noisy washing machine
I'm assuming you balanced this when you got it, right?
Mar 10, 2008 | Washing Machines
first thing i would check is to make sure your copper water line is not touching the motor this will give you this noise. just take off lower kick plate and start d/w you will be able to tell where the noise is coming from.
Bad noise at begining of rinse cycle.
It sounds like your gear case (transmission) has gone bad. If the washer fills and agitates that tells me that the problem cannot be with the motor coupling and drive motor. It also rules out a pump problem if the washer completes a wash cycle and drains properly. The only thing left is the gears inside the transmission. Sometimes they go bad in a way that portions of the wash will work while others don't. The part number is 3360629 and the price usually runs about $150. I hope this may help you in some way.
Sep 22, 2007 | Whirlpool LSR5132PQ Top Load Washer
Whirlpool 24 in. DU1055XTPS Stainless Steel Built-in Dishwasher Logo
274 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
