Question about Microtek ScanMaker 6400XL Flatbed Scanner
Microtek Scanmaker 6400XL
When I turn the scanner on, both lights on the front blink and nothing else happens. This occurred after I moved the scanner to a new location in my classroom. Any help for it?
  • artteacharw Nov 28, 2007
    Now that someone has given me a possible solution, I cannot locate a scanner lamp. Does anyone have a supplier for replacement lamps?
    As a side note, my manual did say that the blinking ready light meant that the bulb is burned out, but it didn't mention the issue with both indicator lights blinking.
    Problem Solver:
  • 8 Answers
This is due problem in scanning lamp it is worn out.
or the power supply it is getting is not normal
Posted on Nov 28, 2007
SOURCE:
How to connect the microtek scanmaker 3800 to system
Run a search for the scanner software on the internet and download it then install it to your computer. (type in microtek scanmaker 3800 software) Then connect the scanner to your pc and turn it on.
Mar 25, 2012 | Microtek ScanMaker 3800 Flatbed Scanner
I need driver for microtek scanmaker 3840
you can download it from
http://www.driverskit.com/freedownload/Scanner/Microtek/ScanMaker_3840_3830_3800_ScanWizard_5_5_93/14515.html
Feb 26, 2010 | Microtek scanmaker 3840
Software for scanner keeps freezing up the computer.
Un-install, then re-install the scanner software. If this does not work, go online and search for software upgrades to your scanner.
Nov 30, 2009 | Microtek ScanMaker 6400XL Flatbed Scanner
Seems to work ok but no light on the front and no moving light
Your Scanner buld is out. Unfortunately for everyone. The company has jipped everyone who has ever bought one of their scanners. Just like Cadillac parts in the 60's, and 70's they produced the scanner, but produced no replaceble parts. Thus, leaving you to buy another cheap-*** scanner. Which in the end will cost you alot. As you may have seen, models are increasing in price. Beyond thais, THEY ARE MADE IN CHINA!!!!!! Take note. cheap stuff from China, instead of having a national repair network, spells All of us being took for a ride!!!!
Apr 07, 2009 | Microtek ScanMaker 3600 Flatbed Scanner
Microtek Scanner installation issue
If running XP SP2, then try clicking Start > right click My Computer > properties > Hardware tab > Device Manager button > expand Imaging devices > right click on your Microtek ScanMaker > uninstall > Re boot > and let XP pick up the device and let the found hardware wizard configure it.
I have seen plenty of hardware that when following the devices manufacturer's instructions for install, such problems as you're having occur and XP SP2 usually will cure it, though you may still need the device manufacturer's CD (for the driver) in your optical drive.
This link: http://support.microtek.com/downloads/bymodelname.phtml?viewtype=2&srch_in=ScanMaker+5950&frmsearch.x=10&frmsearch.y=11&frmsearch=Search&frm_rqst=2&axn=1 will allow you to select between the 5950 and 5950 Pro then on the next page you will be able to download the latest XP driver for your Scanmaker among drivers for other Operating Systems also.
I hope this helps, and Good luck.
Mar 21, 2008 | Microtek ScanMaker 5950 Flatbed Scanner
DRIVERS
download driver
Jan 30, 2008 | Microtek scanmaker 3840
Are you ussing it witha Mac? I could not make this scanner work on System 10.4.x. Had to download software from Microtek and use it with system 10.3.x but it works better with Classic System 9.2 The light stops blinking when used with the older systems and the scanner arm moves. My problem is that the light does not come on.
Dec 06, 2007 | Microtek SCANMAKER 5900 Flatbed Scanner
Can't find replacement lamp for Scanmaker 6400XL
JKL Components was able to create a new bulb for me for Microtek 9800 XL with Transparency Adapter. If you have a different model might need to send the bulb so they can see if it needs to be modified. Worked perfectly. Call Larry: 818-896-0019 ext 124. Very nice, and very helpful
Nov 30, 2007 | Microtek ScanMaker 9800XL Flatbed Scanner
Scanmaker 3700
Driver ScanMaker 3700 for VISTA pls !!!!
Nov 20, 2007 | Microtek ScanMaker 3700 Flatbed Scanner
Microtek ScanMaker 6400XL Flatbed Scanner Logo
175 people viewed this question
Top Microtek Office Equipment & Supplies Experts
Alun Cox
Thomas F. Schneider
Are you a Microtek Office Equipment and Supply Expert? Answer questions, earn points and help others
