Question about Dell A940 All-In-One InkJet Printer
When i try to fax it says no phone tone someone is on the phone
  • 264 Answers
Well as you have spent two hours with dell, i am sure everything would have been checked, However lets make sure that we have the connections right.
Your DSL must have 2 outlets, 1 which will be connected to the Phone and the other one which should be connected to the DSL Modem. 1 is voice and other one is Internet.
So make sure that you have plugged in the cables correctly. You may try changing the cable and the ends to check that.
Another point is that at the back of the tower you would have two ports for tel line "Line and Phone", so make sure that you have connected the phoneline to the jack which says "Line" NOT THE ONE WHICH SAYS "PHONE"
Pull out the cord from the Tower and plug it in a phone and check that you are getting a dial tone.
I hope that this should resolve the issue you are facing.
Posted on Nov 28, 2007
No one seems to know how to get the HP C6180 All in one FAX to work after it gives the error message UNABLE TO SEND OR RECEIVE FAXES, Press OK. Someone at HP surely has an answer to this problem. It...
The first thing I can suggest is you connect the unit to a known working regular unshared/non dsl phone line.
Check for dial tone.. if you get one.. place the unit in auto answer and call it using a cell phone etc.
If that works.. send a test fax.. at least you will know if the unit functions as designed.. chances are it will.
You do not mention if your DSL is via a Splitter (usually at the NID box) or filter.. or both however it sounds like a filter. A lot depends on how your phone outlets are wired.. if they are Daisy Chained.. you need to check every single filter and every single wall plate connection.. There are three basic wire routing techniques.. also known as Topology.. without knowing your style it is hard to diagnose.. regardless..
Some faxes are more likely to fail to any type of line "noise" than others.
You may need to replace the splitter.. or filter(s) or both..
I have seen broken wires behind the wall plate and even at the NID box on the side of the house. Often these wires appear connected until you examine them closely.
Again.. if you are not sure how the place is wired every jack should be tested. Even had lightning burn a needle sized hole in the phone line once causing a lot of line noise.. especially when it rained.
Disconnect the modem from the line and try the fax.. if it works.. you may have a faulty modem or a leaky port.. so to speak.. which would introduce line noise or interference to the voice line.
Finally as simple as this sounds.. check all he settings on the fax machine.. especially the tone/pulse setting. Obviously it should be set to tone.. these settings should not have changed.. but if it lost power.. worth checking.
Your problem is more than likely a DSL equipment related issue or a termninal connection issue then a fax machine problem.
Best of luck to you
Feb 24, 2011 | HP Photosmart C6100 All-In-One Printer
When someone is trying to fax us, it says on their side that it went through but we hear no dial tone and do not recieve any faxes. What can we do to try to fix this? We have to have our fax working as...
Well first thing is to call your own fax machine from a telephone at your location and make sure that it rings and should hear the tones in the earpiece of the phone you are calling from. If that works, go to your fax and try to make a "copy" on it to make sure it actually prints onto paper. Then get someone locally with a fax machine to send you a fax...make sure your machine answers and then prints the page out. If it wont print the pages out are the pages going into memory???? Maybe your machine is asking for toner or a drum???
Sep 09, 2010 | Office Equipment & Supplies
Fax machine not sending documents
A) Run the fax test on the printer itself to see if it's connected properly and has an active phone line.. HP All-in-one printers still make a dial tone sound even if they aren't connected to a phone line. To run the test 1)..Press the SETUP button. Press the down arrow button until "Tools" is highlighted then pres OK. 2) Press down arrow key again and select "Run Fax test" The printer will then print out the results. It will tell you if anything fails. If it does, the correct the problem it mentions. IF everything passes, then the problem is likely your cable phone line which is a "Digital" and Fax machines still use an analog signal. Here is what you can try to overcome the deficiencies in a cable phone system. 1) Set your fax speed to Medium 2) Turn your ECM (Error correction mode) OFF
To set your fax speed, Press the SETUP button again.. Press your down arrow again until you find "Advanced Fax Settings" and the press OK.. arrow down until you find "Fax Speed" and hit OK. Then choose Medium (14,400) and press OK This will take you to your previous menu (Advanced Fax setings).. Find "ECM Choose OK again.. Then choose OFF and press OK. Press the X button on your printer's control panel and then Retry your fax.. Hope this helps
Jul 21, 2010 | HP OfficeJet 7310 All-In-One InkJet...
No dial tone on phone connected to ext port on epson dx9400f
Buy a double adapter so both cords go to the LINE port. Set your answering machine to 6 or 7 rings so the fax picks up first. Your fax machine will know the difference between voice and fax calls,
Jun 22, 2010 | Pitney Bowes 9920 Plain Paper Fax
I am trying to use the fax facility on my isp is aol .Problem no dial tone. What connections are necessary............via printer,modem & computer ?
Typically, a fax machine is connected directly to a telephone wall jack with a known working connection. Try plugging the fax machine directly into a wall jack first and pick up the handset on the fax machine if it has one. You should get a dial tone. Then try to fax something to someone you know.
The machine can also usually be routed through the modem in a computer by connecting the "line" cord on the modem to the wall jack and plugging the fax machine into the the "phone" jack on the modem. You may need to install the software that came with the fax machine to get this to work.
If you have no dial tone, check the wall jack with a known to be working single line phone. If there is a dial tone, it's something to do with fax machine, the computer modem or the connections.
Some fax machines can take advantage of internet faxing through a cable modem or DSL connection. Check your manual for the options available.
Apr 18, 2009 | Lexmark X5470 All-In-One InkJet Printer
No dial tone
Try disconnecting all units plugged into telephone service. ie. phones, computers, fax machine, sat. rec etc. Then take a known working wired phone to check for dial tone in each of the jacks. Plugging in each unit one at a time, you should be able to find your bad equipment. Disconnect bad equipment and reconnect remaining.
Apr 16, 2009 | Panasonic KX-TG5230M FHSS GigaRange...
Fax nightmare!!!
If you have a BT line and use the 1571 answering facility , when you have a message waiting the dialling tone changes from a constant tone to a split tone. This is to let you know that you have one or more messages waiting.
In order to get the dialling tone to revert to the constant tone you have to deal with the waiting messages in accordance with the options provided i.e Save, Listen Again or Delete. BT say the Split Tone is to let subscribers know when they have a message waiting. This should resolve the Fax problem.
It certainly worked for my phone/fax system.
Good Luck
Nov 28, 2007 | Pitney Bowes 9920 Plain Paper Fax
Outgoing fax never goes
Do you have the same problem with different numbers that you fax to? Are you usinga voip phone service? I use Vonage and have a lot of trouble with faxing. Call the number you are faxing to with a different phone and listen for a fax tone.
Aug 16, 2007 | Brother IntelliFAX 2800 Laser Fax
Dell A940 All-In-One InkJet Printer Logo
Top Dell Office Equipment & Supplies Experts
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
