Question about Garmin StreetPilot c340 GPS Receiver
I cannot even tunr on my brand new fresh out of the box street pilot 340? Any ideas?
Garmin 340 won't turn on?
  • 1 more comment
  • jerryzhao Dec 02, 2007
    I have the exact problem.
    JZ
    I got my Garmin c340 today. Was able to turn it on the first time after it was installed. Then I could not turn it on however I tried.
    Jz
  • Anonymous Dec 22, 2007
    same here.
Just read the suggestion about the reset button underneath the silver front and it worked. Thank you Thank you Thank you. I have become very dependant on my Garmin and I didn't feel like buying a new one.
Posted on Jan 07, 2008
You need to press the reset button for three seconds then charge it...the reset button is under the grey mounting around the screen which you have to snap off to get to the reset button.
Posted on Dec 26, 2007
Garmin recommends charging the device for at least 15 min prior to turning it on as the battery may be completely discharged. Worked for me.
Posted on Dec 22, 2007
There is a red button on the side of the unit, hold that and the unit will come on.
Posted on Dec 01, 2007
2 Suggested Answers
SOURCE:
  • 3 Answers
SOURCE: garmin 340 streetpilot won't even turn on?
I had the same issue with mine during a trip. Probably needs to be reset. See page 31 of the users manual on Resetting your c340. Once I did this it worked fine.
http://www8.garmin.com/manuals/StreetPilotc340_OwnersManual.pdf
Posted on Jul 22, 2008
Do you have to change the batteries in a GPS C- 340?
The battery should last a long time but eventually it will not hold a charge. Here is a very helpful link on how to change the battery if needed.
Thanks for using FixYa
http://www.batteryeducation.com/2010/08/garmin-street-pilot-c340-battery-installation-instructions.html
Jul 16, 2011 | Garmin GPS
HI, MY GARMON STREET PILOT C 340 IS NOT WORKING, IT JUST SAYS, SEARCHING FOR SATTELITE MY SON IS IN WILDWOOD NJ AND HAS THIS PROBLEM WITH IT
Give Garmin Technical Assistance a call. They will run you through a series of diagnostic and reset button sequences to try. The unit may just be faulty; in either case you will find out after the diagnostics are performed.
Jun 23, 2011 | Garmin nuvi 350 GPS Receiver
Can the touch screen on my garmin c340 gps be replaced?
Yes, it could be easily replaced. If you want to purchase only touch screen, buy it from :-
http://cgi.ebay.com/GARMIN-C340-C-340-Street-Pilot-Touch-Screen-Digitizer-U-/270622808154?pt=PDA_Accessories&hash=item3f0260585a
If you wanted to replace LCD screen as well, buy it from :-
http://cgi.ebay.com/LCD-Screen-Touch-Digitizer-Garmin-C340-U-/120457660971?pt=PDA_Accessories&hash=item1c0bd60a2b
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Aug 27, 2010 | Garmin StreetPilot c340 GPS Receiver
How do I change the batter in a Garmin Street
Hi! You may need to change the fuse periodically, which is at the tip of the adopter! regarding battery, you may need to contact waste disposal section for disposing the unit since it contains lithium. Don't consider much presence of high amount heat and direct sun rays at new battery for longer duration and have fine
Dec 21, 2009 | Garmin StreetPilot C330 GPS Receiver
My garmin 340 suddenly stopped working
Ummmmm "Low battery"....... not too hard to figure out. You need to charge it for several hours. If the battery is low it WILL go out on you and during that time, the battery may recover enough to come on briefly then go off again. Please charge your battery!
- Jim
Sep 13, 2008 | GPS
Garmin street pilot c340 battery appeared low, used USB cable to hook up pilot with my computer but device doesn't appear to turn on, computer cannot locate device on Drivers, can I rechare steet pilot...
I followed the instructions of the Online manual for the Garmin Street Pilot c-340, I removed the faceplate of the Street Pilot and then using my thumb pressed down on the reset button. I then pressed the power on button on the side of the device- the screen lit up, I then plugged one end of the USB cable into my computer and the other end into the device. The information on the screen of the device indicated the Lithium Battery was charging properly.
Jul 14, 2008 | Garmin GPS
Garmin Street Pilot III map source data card not accessible
Garmin has issues with the newer (ROHS Compliant) cards, so If you recently bought this card get a replacement from garmin.
I had these issues too with a 256 MB, garmin replace the card with 2 128MB cards, worked fine after that.
Mar 26, 2008 | Garmin Streetpilot ColorMap GPS Receiver
Garmin 340 streetpilot won't even turn on?
Nov 28, 2007 | Garmin StreetPilot c340 GPS Receiver
Garmin StreetPilot c340 GPS Receiver Logo
Top Garmin GPS Experts
Marvin
Marvin
Jean-Luc Steffann
Sheldon Dedek
Are you a Garmin GPS Expert? Answer questions, earn points and help others
