Question about Garmin StreetPilot c340 GPS Receiver
Garmin 340 streetpilot won't even turn on?
I cannot even tunr on my brand new fresh out of the box street pilot 340? Any ideas?
  • 1 more comment
  • Anonymous Jan 05, 2008
    Mine wont turn on either.....Is it some security feature?
  • Anonymous Jun 15, 2008
    Mine won't turn on.
  • Anonymous Jul 18, 2008
    I turn it on it flashes the start up screen twice then dies.
  • 3 Answers
I had the same issue with mine during a trip. Probably needs to be reset. See page 31 of the users manual on Resetting your c340. Once I did this it worked fine.
http://www8.garmin.com/manuals/StreetPilotc340_OwnersManual.pdf
Posted on Jul 22, 2008
  • GENIUSIAM Oct 25, 2010
    It can only be reset if there is power, but lack of power is the issue here. The most likely reason is a blown fuse - I had the same problem and replacing the fuse fixed it. There is a fuse in the end of the car charger. Just inscrew the end of it and a fuse will pop out. Be careful not to lose the spring in it. Get a new fuse 2A/250 and it will work.
Likely the fuse in the car plug-in connector. Try charging your unit via the USB connection to your computer. If that works, you know it's the fuse in the 12-volt car plug.
Posted on Dec 15, 2008
I had the same problem...thanks for the solution!
Posted on Sep 02, 2008
    Welcome Back:
    Visited the website for 2 consecutive days.
Thanks you it worked
Posted on Jul 26, 2008
Send it back to Garmin for repair. It covered under warranty if it is less than one year from the date of purchase.
Posted on Nov 30, 2007
2 Suggested Answers
SOURCE: I cannot even tunr on my brand new fresh out of the box street pilot 340? Any ideas?
You need to press the reset button for three seconds then charge it...the reset button is under the grey mounting around the screen which you have to snap off to get to the reset button.
Posted on Dec 26, 2007
On my garmin streetpilot 7200 it says maps are locked...
I'm not sure if the street pilot is the same as the garmin nuvi. There are details of how to unlock Garmin Nuvi satnav maps at http://www.fixya.com/support/r6197735-no_detailed_maps_found_support_routing
There's more information there than you'll need but you can skip to the part on unlocking maps. I'd imagine the street pilot wouldn't be a whole lot different from the nuvi as they're both made by garmin.
Mar 03, 2011 | Garmin StreetPilot 7200 GPS Receiver
Can the touch screen on my garmin c340 gps be replaced?
Yes, it could be easily replaced. If you want to purchase only touch screen, buy it from :-
http://cgi.ebay.com/GARMIN-C340-C-340-Street-Pilot-Touch-Screen-Digitizer-U-/270622808154?pt=PDA_Accessories&hash=item3f0260585a
If you wanted to replace LCD screen as well, buy it from :-
http://cgi.ebay.com/LCD-Screen-Touch-Digitizer-Garmin-C340-U-/120457660971?pt=PDA_Accessories&hash=item1c0bd60a2b
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Aug 27, 2010 | Garmin StreetPilot c340 GPS Receiver
Our garmin street pilot c330 tells us the battery is dead when it's plugged in and then goes blank. Can this type of battery be replaced?
yes the battery needs to be replaced, even when the GPS has external power the battery must be good for it to work,
May 15, 2010 | Garmin StreetPilot C330 GPS Receiver
How do I change the batter in a Garmin Street
Hi! You may need to change the fuse periodically, which is at the tip of the adopter! regarding battery, you may need to contact waste disposal section for disposing the unit since it contains lithium. Don't consider much presence of high amount heat and direct sun rays at new battery for longer duration and have fine
Dec 21, 2009 | Garmin StreetPilot C330 GPS Receiver
My streetpilot c330 won"t shut off.
IT'S CALLED A FROZEN SCREEN...
2 OPTIONS
ONE, RESET IT !!! (See resetting instructions below)
TWO, let the battery die out!
Waking up your c330...
If you left your Garmin c330 on running the battery will have 1% life left. If you turn c330 back on again, it will flash screen for 3 seconds then die, even charging it at this point will not wake it back up. TO BRING IT BACK TO LIFE... plug in the power home or car into Garmin c330. There is a tab in the front Garmin gray frame of your screen. You must take like your fingernails and under the logo "GARMIN" pull the whole gray plastic frame off. Underneath the plastic frame to the right hand side. There is a "RESET" button. Make sure power is plugged in while hitting reset. Your battery should come back to life. Cheers
Mar 12, 2009 | Garmin StreetPilot C330 GPS Receiver
Re garmain streetpilot
yes it should try finding a local repair place
Feb 01, 2009 | Garmin StreetPilot C330 GPS Receiver
Garmin street pilot c330 instruction manuel
The instruction manual is available to download from Garmin's website, www.garmin.com. Click on the StreetPilot C330, then go to updates and downloads. You should find the manual there.
Mar 05, 2008 | Garmin StreetPilot C330 GPS Receiver
there is a red button on the side of the unit, hold that and the unit will come on.
Nov 28, 2007 | Garmin StreetPilot c340 GPS Receiver
Garmin StreetPilot c340 GPS Receiver Logo
3,278 people viewed this question
Top Garmin GPS Experts
Marvin
Marvin
Steve
Will Halftowaite
Are you a Garmin GPS Expert? Answer questions, earn points and help others
