Question about Nokia 6288 Cellular Phone
Sea water get in my n-gage......
A bit a water get in my memory card slot...i try leave the n-gage in the sun but no use....what should i do???
  • 89 Answers
Well.. you have to do this immidietly after the phone get in the water becase as soon as the solvent like water , chemical , etc start to make short circuit inside the phone so you must remove the battery immidietly. and its rear that the phone works properly after getting in the water but it won't get seriouly damage as you said you tried to keep the phone in the sun and it won't work this mean that you phone has some problem in the power section . look some one to repair for you and i am sure it won't cost you much
Posted on Nov 30, 2007
SOURCE:
Tomato leaves at top of plant wilt, bottom leaves healthy, but starting to turn themselves over. Weather hot, plants in tomato grow bags.
Never pour water over plants when it is very hot it causes leaf problems as you mentioned , use it on the soil, have you fed the tomatoes because they need food as we do, the leaves showing wilt is responding to direct sun a bit of shade may help.
Jun 28, 2018 | BIT Garden
I have a white rubber sink mat. How do I clean off the coffee and tomato sauce stains?
I tend to scrub my mat with detergent. Rinse it with warm water and leave it to dry off. You can also leave them to soak overnight with soap and then rinse them off in the morning. For really tough stains, I pour baking soda on top, let it sit for a bit and then scrub the mat. You can try leaving them in the sun, because sun bleaches white things.
Jan 10, 2013 | Home
Memory card won't fit into orange slot
that is a good idea to match the memory cards like matching four tires on same card
a bit concerned about 'forcing ' them into the slots though
May 25, 2012 | Acer Aspire T180 PC Desktop
My DX-860G won't format an 8 gig SD memory card. When I try, I get an error. Is there a limit on how large a card I can use?
Hello Mr Clownfish 33
  • Insert your memory card into your computer's reader if you have one. If not, you can purchase a multi-format USB Memory Card reader from Amazon.com or Buy.com
  • 2 Open up 'My Computer'. You should see it under the list of available drives.
  • 3 Check its contents first to make sure that you have the right drive.
  • 4 In 'My Computer', right-click on the drive and choose 'Format'.
  • 5 Leave all the options as they are and click on 'Start'. This is a non-reversible process so make sure this is what you truly wanted to do in the first place.
  • 6 Once the process is completed, take the memory card out and insert it into your Digital Camera or any other device. Try to browse to it to make sure it works fine now.
  • Jun 26, 2010 | Sea and Sea DX-860G Digital Camera
    Memory card wont stay in my phone. whenever i push my memory card into the slot it just comes back up
    Perhaps it has a latch mechanism - you have to push it a bit deeper inside, and then it will latch into place. To remove, push it again deeper and it will pop out.
    If it's not the case, perhaps your socket is a bit worn out, and/or the card is thinner then usual - you can try to increase the friction by applying some self-stick paper or tape on top of your card to make it a little bit thicker.
    Dec 03, 2009 | SanDisk 2GB microSD Memory Card
    I just bought a new memory card for my pc how do i fit it
    You can follow this link and view the video for the same.It has acer aspire memory video as well.
    Hope it helps !!
    Thanks !!
    Sep 10, 2009 | Acer Aspire 5500 5570-2609 Laptop
    P4m800pro-m478 "No video"
    if you have another pci slot install the card there
    if that does'nt work
    your card has probably gone
    please rate me
    thanx
    Feb 02, 2009 | EliteGroup ECS P4M800-M Socket...
    Hello, I would like to upgrade lenovo ram memory. I have a RAM card. How can I place it there?
    On the bottom of the laptop there are one or two panels, remove the screw securing the panel. The RAM module are behind one of the panels. If the memory module does not fit in the memory slot, then you have the wrong type and you need to purchase the correct memory type.
    Your friendly computer shop can advise you on the correct type and speed of the memory module your laptop requires.
    Jan 21, 2009 | Lenovo ThinkPad R51e Notebook
    My PSP Wlan Button And Memory Card
    you have to get fix send back to sony , my sun have thath same probleme yvon !!!
    Dec 31, 2008 | Sony PlayStation Portable (PSP) Console
    Hi Miss Lisa,
    Remove the battery immediately.. Keep it out for a day or two. If you have a Water Pik, Spray out the memory card slot real good. You need to let it dry Dry Dry, absolutely no water or moisture in it beofer you put the battery back in.
    Nov 28, 2007 | Nokia N-Gage QD Console
    Nokia 6288 Cellular Phone Logo
    32 people viewed this question
    Top Nokia Cell Phones Experts
    jonathan mariano
    jonathan mariano
    Ekse
