Question about Brother IntelliFAX 885MC Plain Paper Thermal transfer Fax
Voice mail will not pick up
My fax function works, however my voice mail will not pick up calls now. The call comes in and rings after a certain amount of rings the fax comes back on, not the voice mail.
Thank you
  • Anonymous Feb 13, 2008
    Phone rings but messages will not play. The number of messages, time and date appear on display but no voice message. Manual very difficult to follow. Machine very complicated. Have returned to where purchased and rung Brother but they could not help.
  • dznwrk Jun 25, 2008
    my voice mail will not come on
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Brother Master
  • 1,362 Answers
There is a setting that was not correct, here is the manual go back over it
http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_IntelliFax_885MC_EN_91.PDF
Posted on Jan 04, 2008
SOURCE:
Canon mf5770 not receiving faxes
Most fax machines allow you to set the number of times the phone rings before it automatically answers the phone. So if you phone goes to voice mail after 4 rings and the fax machine is set to start the fax after the 5th ring it will never receive the faxes because the call went to voice mail. Good Luck
Dec 05, 2013 | Office Equipment & Supplies
Can lexmark x4650 be set to recognize fax?
For more details on how to setup your Lexmark X4650 printer for faxing, please refer to the User's Guide found on the Lexmark website.
Additional info:If you have an answering on the same line as your fax:
To make sure the printer picks up incoming faxes, set Auto Answer to On, and then set the printer to pick up after a greater number of rings than the answering machine. For example, if the answering machine picks up calls after four rings, then set the printer to pick up after six rings. This way, the answering machine picks up calls first and your voice calls are received. If the call is a fax, then the printer detects the fax signal on the line and takes over the call.
If you have a voicemail feature associated in the same line as your fax:
Voice mail and fax can share the same telephone line if you subscribe to a distinctive ring service offered by your telephone company. This feature allows you to have multiple telephone numbers on one telephone line. Each telephone number has a designated ring pattern (single ring, double ring, triple ring, or double and triple ring). The different ring patterns let you know which telephone number was dialed, and which device you should use to answer the call.
If you do not have distinctive ring service, then set the printer to receive faxes manually (Auto Answer Off). This setting lets you receive both voice calls and fax calls, but works best if you use voice mail more often. You need to turn off voice mail whenever you are expecting a fax.
Feb 16, 2012 | Lexmark X4650 InkJet Printer
Fax won't answer
If you have an answering machine connected to the same line as your fax:
If you have a voicemail feature associated to the same line as your fax:
I hope this helps.
Should you need further assistance, please contact Lexmark Technical Support Center.
Feb 14, 2012 | Lexmark Pro901 All-In-One Inkjet Printer
Dell 2135CN cuts-off incoming calls to my home phone number after 2 rings and the call goes to the printer. I hear the ringer inside printer, then hear fax tones, even though the call is not a fax. My...
Hi and welcome to FixYa!
Well if that's the case, the printer should be detached or powered of during call operations. The printer detects incoming calls that's why it triggers it to operate. Turning it off during operation will surely be the solution.
Hope this helps and thank you for using FixYa! Have a good one!
Jan 05, 2011 | Computers & Internet
I don't use an answering machine. My phone has voice mail but the machine is not even recognizing when a fax comes in. The fax call goes into the voice mail each time. The phone line is working-I get a...
You need to set your phone to pick up later than the fax machine. set it to pick up on the 4th or 5th ring, set the fax to pick up at 2 or 3. Better yet, get a distintive ring # set up by your phone co. then the fax will only recognize that ring.
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Dec 30, 2010 | Canon PIXMA MX870 Wireless Office...
Printer says DR mode in use what does this mean
DR Mode means distintive ring. This is if you are using two or more phone numbers on one line. For example, you could have your voice mail number and your fax number on the same line, but when a call comes in to your voice mail the fax will recognize the ring pattern and won't pick up the call. If it is truly a Fax, then your fax will pick up the call by recognizing the ring pattern.
Oct 07, 2009 | Brother MFC 8840D All-In-One Laser Printer
Same Number for Fax and Telephone
The fax is designed for use with an answering machine, the greeting for which must be no longer than 15 seconds. If voice mail in this case is referring to answering machine, be certain that the message is as indicated.
If you need further assistance, please post back. Otherwise, thank you for using and rating FixYa!
Mar 29, 2008 | Canon FAX-JX200
Panafax UF6000 answers during voice call
You may want to look and find out if the machine has a fax priority setting. That means that at anytime a fax is received it will terminate the call and answer the fax.
It is a " feature" as some call it. On some fax machines it can be turned on or off. On some, its just on all the time.
Feb 16, 2008 | Panasonic PANAFAX UF-6000 Fax
Set up
Make sure ECM is turned on. Do not turn on Junk Fax because you will most likely block other faxes.
If you really want the fax machine to work properly, you should connect it to a dedicated line.
You will be disappointed with performance if you try sharing it with other items on the same line.
Reasons, your fax line will be busy when your other functions are being used, and obviously you will miss faxes.
If you are taking a call or message when fax comes in, if the machine is made to give faxes first priority, you will be disconnetcted.
Also, which one do you want to set to pick up first?
The fax machine answers on a certain ammount of rings and so does Voice mail. Which has priority to you. DO you want to miss faxes for messages, or messages for faxes.
Set up vioce mail for 3 rings and fax for 4, then you miss the fax. Reverse it and you miss the message.
Just telling you, I have people call all the time for issues with faxes on the same lines with other items, Answering machines, credit card billers, other phones, etc etc etc.
Good luck. But putting multiple items on the same phone line is setting you up for disappointing performance. And it will not be the problem of the fax machine, It is designed to do what it is supposed to.
Just telling you the truth up front. If your faxes and messages are both important to you. You need a dedicated line for the fax.
Dec 05, 2007 | Brother IntelliFax-2820 Laser Fax
Brother IntelliFAX 885MC Plain Paper Thermal transfer Fax Logo
73 people viewed this question
James Cagle
James Cagle
Jim Keysor
ctnozil
