Question about Minolta DiALTA DI2510F All-In-One Laser Printer
ERROR CODE WHEN I TURN ON MY Di2510, DURING WARM UP STAGE AN ERROR CODE APPEARS: THE CODE IS CO8AO. WHAT IS WRONG?
  • highcazony Nov 29, 2007
    the sensor on the sorter bins was faulty, once changed machine worked fine
    Brigadier General:
  • 5,158 Answers
Thanks for posting the solution. it may help other users
Robert
Posted on Aug 29, 2008
SOURCE:
Di2510 black back round during printing
if you have replaced toner and problem still insists, it is fuser problem, you should replace Fuser Unit.
Aug 24, 2013 | Minolta DI2510 Black and White Copier
Minolta di2410 c0500 error code
First ensure that the right side cover is closed correctly. Check that the two latches that are on the door are not broken especially the rear one. Then fine a paper clip. With the machine on look on the right side of the control panel you will find a small hole. Place the paper clip inside the hole. (Once that is done you can only use that paper clip for that only :) Copier tech humor!) Watch the screen you might see abort code that OK. When the screen come on that show the copiers look to the left of the screen in the middle a small "." will appears when it does press 3. Nothing is going to happen. Code will come back. Now press the Utility button you should now see a button marked maintenance mode. Press it then press trouble reset. Once again the machine will go though its normal warm up will see the "." do not do anything. Ready to Copy Should appear. If the code comes back do not reset the code your messing with the fuser (The Hot part). It can catch on fire (That would ruin a perfectly good day) so have a technician look at it.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Jan 22, 2013 | Minolta DI2510 Black and White Copier
Whenever I switch on to start operating, during my waiting to warm up, it displays error code C-D369. and it doesn't function from there.
Error code reset:turn OFF the copier ,press and hold the Utility key to right hand,to left hand turn ON the copier,wait appaire on the display Trouble reset,touch the screen and turn OFF the copier.Wait 2 minute and turn ON.
Jan 17, 2013 | Konica Minolta bizhub C250 All-In-One...
Samsung refrigerator error code 8E
8E = OVER CURRENT ERROR
IPM fault signal (this is caused by the overload of the MICOM INTO during motor action).
IPM: Integrated power module. The IPM controls the motor.
If the fault (low signal) happens to be sensed even once during the washing/rinsing stage, the motor stops immediately. However, during the dehydrating stage the signal is to be sensed, when the number of signals reads more than 6 per 500ms during the Washing or Rinsing cycle action.
If the motor stops working, in one direction ten times, "8E" Error is displayed.
During dehydrating, when the overload is sensed, the motor stops working at once and then feeds back to the initial stage of the dehydration unbalance sensing. When the feed back has occcurred twice, Error "8E" is displayed during the dehydrating unbalance sensing, No error happens by overload sensing. When it happens at more than 800rpm, the process is stopped compulsorily. Power Switch OFF can clear the overload error.
Nov 23, 2012 | Samsung RS265TDRS Side by Side...
E8 front loader washing machines
OVER CURRENT ERROR - Display shows 8E.IPM fault signal (this is caused by the overload of the MICOM INTO during motor action).
HOWEVER, the UK White goods website says:
E8
Temp too high on low temp washesNormally this will be the wash temperature thermistor or NTC that's faulty, please contact us if you need the thermistor with the model and serial number.
You can find more about your Samsung Washing Machine error codes at:
http://www.keepingupappliances.com/repair-help/appliance-repair/washing-machine-help/samsung-washing-machine-error-codes/
or
http://www.ukwhitegoods.co.uk/help/fix-it-yourself/fault-codes/laundry-fault-codes/3069-samsung-washing-machine-fault-codes.html
Jun 21, 2011 | Samsung Washing Machines
I have Konica Minolta DI2510 with problem coed C0500 & C0f032
You can try to reset the C0500 error code press the soft initialization on the right side of control panel when the dot appears on the lcd after reboot press the number 3 key the mode will change to the initialization screen choose the selection for trouble reset after reboot the code will be cleared power on and of for basic screen if this dose not work you will need to replace the fuser unit
in regards to your c0f32 code the toner to carrier ratio is wrong this is caused by the wrong developer being used clean out developer unit and put correct developer in the unit
Jan 24, 2011 | Konica Minolta Office Equipment & Supplies
Turn on get error c0500 on a minolta ep4050
the error codes means Low fuser temperature during warm-up
To clear the fuser error code, perform the following after correcting the cause:
1. With power ON, open the front door and locate the small, rectangular hole below the imaging unit removal tool.
2. Insert a suitable object into the hole to actuate the reset switch .
3. The code should clear and a message to close the front door should appear.
Jul 06, 2009 | Office Equipment & Supplies
E8 error code
8E - OVER CURRENT ERROR
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
May 02, 2009 | Washing Machines
C-0500 code on bizHub 163
ARE YOU CONNECTED TO A LAN CARD OR NETWORK OF ANYKIND.
GO ON LINE AND TYPE IN
MINOLTA DI2510 B/W COPIER C-0500 ERROR MESSAGE
ENTER
ROD
Feb 05, 2009 | Minolta DI2510 Black and White Copier
Minolta DiALTA DI2510F All-In-One Laser Printer Logo
228 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Adorjani Laszlo
Norman  J Weimar Jr
Norman J Weimar Jr
Ed
Ed
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
