A picture of what looks like a battery is flashing on the front of my computer in orange. The computer will not boot up. It is plugged in to AC. My battery has not worked for a while so I have justed used AC. Could my battery have completely have died and as a result my computer will not even run on AC?
It sounds like your battery is completely dead and will not charge. If your battery cannot charge, its time to get a new battery or a new PC. Wish I had better advice for you. Good luck!
More than likely, your power port has gone bad, which is a VERY sommon problem with laptops. Even if the battery is removed entirely, the laptop should run on outlet power. In this case, you can double-check your power adapter (if it has an LED, make sure it comes on) and yo ucan always purchase another power cord to test it and return it if it's not the problem. Otherwise, since the power port is attached to the motherboard, it is not a particularly cheap piece to replace, but may be worth the investment.
Was this helpful?
Yes
No
Popular Solutions for Compaq Evo N610C PC Notebook
My Acer laptop when typing, my cursor moves anywhere on the page where the typing then starts, as...
(More)
My Acer laptop when typing, my cursor moves anywhere on the page where the typing then starts, as well as dragging and dropping problems. Is there a sensitivity setting to fix this? I can't find anything in the device manager.
hi! the pc's memory apparently was just about 'full' when I tried to view a short video holiday trip...
(More)
hi! the pc's memory apparently was just about 'full' when I tried to view a short video holiday trip from sd card via usb card reader when the screen went dark. the fan is still working, the cd/dvd drives locked up with the cd/dvd drive for some reason seemed like it was running (light on & wirring sound) the battery light is blinking also. I removed the memory ram and cleaned it, but it doesnt seem to power up. only fan working and battery light flashing. its a desktop pc by the way. Assistance would be appreciated! thank you..
while working in word i end up touching the mouse pad and the cursor moves away.resultant, the words...
(More)
while working in word i end up touching the mouse pad and the cursor moves away.resultant, the words which i type either lose their alignmetn?sentences or spellings
