Question about Philips J44414
PC cam SIC4700/37 drivers for windows xp 64x
Yes i found the drivers for it and installed it on my dell laptop and when i try to use it it says no webcam found on your system and i installed the driver before plugin it in and after it is installed i plug it in what is the problem?
  • Philips Master
  • 2,130 Answers
1st You download Webcam Driver.
drivers After this install the Webcam driver in the system.
Installation of Webcam Driver
Go to the control panel
Click on the System Icon
Click on the Hardware Tab
Click on the Device Manager s
Select the Unknown Device or printer device where yellow Question Marks sign on it.
Right click on it and uninstall it.
After this go to the top of the device manager and click on scan for hardware changes.
Driver installation Wizard start.
Brows Your Driver from the Hard Disk and click on next.
Driver will be install.
Posted on Dec 24, 2013
  • 83 Answers
This happens on my labtop too, I found the souliton though, if you read the box is it comply-able with your PC? If so, try just reinstalling it
Posted on Nov 29, 2007
SOURCE:
I want to upgrade my window 32 bit to 64 bit in dell optiplex 380 PC. but i don't have win CD or any recovery drive..didn't receive any system restore cd from dell.. what to do.?
1st ur oem dell key found on ur pc is compatible with both 32x and 64x but u must backup ur os before reinstalling use windows 7 maintenance section to do a full backup
2nd check ur oem version if on the key if pro or home premium then google to find an iso compatible with ur version but 64x after that head to the dell website and download the specific drivers
Dec 21, 2013 | Computers & Internet
I have a Dell 530 S Dell Inspiron. Its Webcam has stopped working. Any solutions
The very first step is of course to check your web cam connection. Most web cams use the USB port to connect to the PC, so check if your USB cable is properly plugged. For build-in web cams this steps does of course not apply. Many new laptops have a build-in web cam. Also try connecting your web cam directly to your PC instead of through a USB hub (if you are using one).
The next thing is to do is to check your Windows Device Manager and see if the hardware is recognized and installed properly.
It might be that the hardware is recognized as a camera, but the right drivers are not installed. The yellow explanation mark will indicate a problem.
Other devices in Windows XP device manager
If the device is not recognized in Windows XP, Right-click the device, and in the pop up menu select Update Driver Software. Then follow the instructions on screen, but make sure you allow Windows to search the web for updated drivers.
In case no driver for the web cam can be found, you can try a third party driver finding program that scans your PC for installed hardware and allows you to install missing drivers.
If this fails, the next step would be to un install the software that came with your web cam. Use the Add or Remove Programs feature in the Control Panel. If that does not work you can use a third party un installer.
After un installing the software, restart your PC and then reinstall the web cam software. In most cases this will solve the problems. Depending on the software, you might need to unplug your web cam during the software installation.If your problem is not fixed then you have to buy a new one.
Hope the above information will be helpful to you.
Thanks.
Oct 08, 2010 | Dell Inspiron 530 Desktop Computer
I have a windows 64x system on my computer and the driver cd from sitecom is only for 32x systems! so, where could i find a driver for a windows xp profesionell 64x version for a 54g wireless usb adapter...
it is ok if your have 32x for your driver 64x will be backwards compatible unless you are receiving an error after the installation then you really would need the 64x drivers for that USB adapter ^_^ but I believe your 32x should work on the 64x, on lt the 64x driver if installed on a 32x will not work because it will be higher than what the system requires but if you already have 64x in your computer and you only have a drive for 32x then It should work.
May 03, 2010 | Computers & Internet
Error showing media device is not found using XP , presariov3000
the drivers might need to be a 32x 64x or check with the product sightand look for pruduct support / drivers-downloads check for you model type and re-download drivers and install but before installing remove drivers previously installed. hope this helps
Apr 01, 2010 | HP Compaq Presario v3000z Notebook
Windows xp computer not reading windows transfer cable
please download and install the driver found on the bottom of the page linked on the xp computer:
http://www.belkin.com/support/article/?lid=en&pid=F5U258&aid=6100&scid=0
May 29, 2009 | Dell Dimension 2400 PC Desktop
Problem in webcam
What type of Dell notebook is it?
You may need to uninstall the driver and get the updated one from dell.com website. Install the updated driver and then reboot. Please rate me.
Thanks
Feb 17, 2009 | Dell Vostro 1510 Notebook
Dual boot vista/XP on dell studio 1737, drivers needed ?
For the video drivers you might try the intel generic drivers for xp these should work here is the process.
For the audio use the latest vista driver and then follow the steps here.
The latest driver in combination with f you are using Microsoft Windows XP*, you may need to first install KB888111.exe, the Microsoft* UAA High Definition Audio Package version 1.0a. should work.
Jan 30, 2009 | Dell Studio 1737 Laptop
Dimension 4700 with Barracuda 500Gb SATA HDD
You have to go online and search then download the drivers for preparing SATA laptop harddrives for installation of Windows XP otherwise during installation it will tell you there is no hard drive found.
Dec 12, 2008 | Dell Dimension 4700 PC Desktop
Problem installing the driver
Mine did the same thing - just ignore it and click ok - it will work believe me - just do it and it'll work.
Sep 12, 2005 | Creative Labs PC-Cam 550 Digital Camera
Philips J44414 Logo
59 people viewed this question
Top Philips Computers & Internet Experts
Ekse
Steve Allison
Steve Allison
Are you a Philips Computer and Internet Expert? Answer questions, earn points and help others
