Question about Canon imageRUNNER 2200
E602-0001 I have the above error code - i have called service but need the copier NOW - as always. Can any of you offer a solution?
  • Joseph Herdman Nov 29, 2007
    dude. I have serviced copiers for 22 years now and that is a very vague explanation of what the problem is. It is an HDD error. You will need to have it reformatted with SERVICE SUPPORT TOOL. You can only get this from an authorized Canon dealer. The system software will have to be reloaded also. If this does not resolve the problem you will need a new HDD. Whomever the so called expert is that answered this problem may want to try a new line of work!
  • 57 Answers
Error Code
E602-0001, 0002
Indicates the presence of an error in write/read operation.
Posted on Nov 28, 2007
    New Friend:
E602-0001
Posted on Jun 22, 2013
SOURCE:
Ricoh aficio mp2105 error code sc495 how to recover
http://terraofficesolutions.com/forum/index.php?topic=36.0
Quoting from the link above:
Ricoh Error Code 495, SC495 Fix - Printer, Copier, Fax Machine « on: October 02, 2012, 11:18:43 pm » The Ricoh copier error code 495 / SC495 is a toner recycling unit error code.
If you receive this error you will want to check:
Your Waste toner transport is nor working ( motor overload )
Check Toner end sensor detective, (is not connected )
If the problem persists you may need to contact a local service technician to take a look at your copier.
Contact us by phone, email, or reply to this post with any questions you may have, we can always help.
Steve Jensen
[email protected]
(760) 580-4190
Mar 21, 2018 | Ricoh Office Equipment & Supplies
Tip
How to resolve Cannon ir400 Error e004
<span>Hi,<br /><br />For error code E004-001 or E004-002<br /><br />Cause:<br />The SSR has a short circuit.<br />&bull; The SSR has an error.<br />&bull; The DC controller PCB has a fault.<br />The heater relay has an error.<br />&bull; The heater relay has an error.<br />&bull; The DC controller PCB has a fault.<br /><br />Description:<br />&bull; The fixing heater remains<br />on.<br />&bull; The fixing temperature has<br />increased abnormally.<br />The heater relay remains on.<br /><br />FIRST TRY TO CLEAR ERROR:<br />Resetting Errors<br />1. The following error codes cannot be reset by merely turning off and then on the main power.<br />They require resetting in service mode:<br />E000, E001, E002, E003, E004, E032, E717<br />1) Start service mode, and select COPIER&gt;FUNCTION&gt;CLEAR&gt;ERR.<br />2) Press the OK key.<br />3) Turn off and then on the main power.<br />2. Error codes other than the above may be reset by turning off and then on the main power.<br />n Detail Code<br />Some error codes offer detail codes, which may be checked in service mode:<br />COPIER&gt;DISPLAY&gt;ERR (3rd block from the right)<br /><br />SERVICE MODE: <br />1) Press the asterisk key ' * ' on the control panel.<br />2) Press '2' and '8' on the keypad at the same time.<br />3) Press the asterisk key ' * ' on the control panel.<br /><br /><br />If these doesnt helps, you need to call service to locate the fault, which is probably bad thermistor.<br /><br />Hope that helps!<br /></span>
on Feb 06, 2011 | Cannon i70 Printer
Call service 7000: 0370082
Toner motor lock error**The top cover interlock switch is damaged and the top cover actuator side does not always seat properly. Replace switch (part of switch regulator pcb) and repair retaining clip
Oct 14, 2013 | Kyocera FS-4000DN Laser Printer
Gestetner Dsc445 service code error
have you checked/replaced the thermostats?
this may also be a problem with your hvt board or power supply.
Feb 26, 2013 | Gestetner Office Equipment & Supplies
System error 007 for canon ir 2018
this is error for fixing film rotation. There is no reset code, you need to replace fixing film in fixing unit, Fixing unit is located under left sideway door above drum unit ( green roller ).
Call service!
Aug 26, 2011 | Canon iR 2016i Black and White Copier
Ihave canon 400 problems. e051, e901, e805 problems frequently please suggest me
by the look at your problems:
E051 - Horizontal registration sensor problems
E001 - Fixing temperature faulty
E805 - The Fan rotation problems
It can be that You have problems with DC contoller ( main pcb ) or the copier is in worst condition and there are faults on every segment.
For E001, you can try to reset error:
1) Start service mode, and select COPIER>FUNCTION>CLEAR>ERR.
n Detail Code
COPIER>DISPLAY>ERR (3rd block from the right)
BUT I THINK THAT THE BEST SOLUTION IS TO CALL SERVICE TO RECTIFY THE PROBLEM OR YOU BUY NEW MACHINE:..
Hope that helps!
Jul 22, 2011 | Canon imageRUNNER 400S Copier
Error code appear my Canon Xerox 405 e.i. e002. Please reply me how to solve the problem step by step. Please reply as early as possible. Thanks, Rajes Acharya
n Detail Code
To enter the service mode:
1) Press the asterisk key ' ' on the control panel.
3) Press the asterisk key ' ' on the control panel
Hope that helps!
PS If not you have problem in fixing unit, probably the fixing thermistor and need to be replaced.
Jun 24, 2011 | Canon imageRUNNER 400S Copier
Service Required Error code F100. What do we need to do?
F100 indicatest HDD failure...
The best way to solve it is to replace a new HDD & update firmware~~~
Oct 07, 2010 | Toshiba e-Studio 350 Copier
The copier shuts down when trying to print
Look for the error code, that would lead you to the problem area, most likely the fuser assy. needs to be replaced. Do this, Press;
ADDITIONAL FUNCTIONS,
press 2 and 8 (together),
ADDITIONAL FUNCTIONS again,
You should now be in Service mode, if not hit CLEAR twice then repeat the steps above.
press COPIER,
press ERR
the one listed at the top is the error code.(write it down)
You can try clearing the code then reboothing the machine with the right side switch and it might work.
This is how you clear the code, follow all the steps above except the last one (ERR) instead select FUNCTION above then CLEAR then ERR. Turn the machine off then back on again.
If that does not help and you are still having the same problem, you could either call Canon with a service call, call a local technician or get yourself a service manual and with the error code you wrote down above try looking it up or contact us again with the error code. Good luck.
Dec 18, 2009 | Canon imageRUNNER C3220 Color Copier
Canon imageRUNNER 2200 Logo
2,073 people viewed this question
Clive
Clive
old marine
old marine
Ekse
