Question about LG L1915S 19" LCD Monitor
Monitor automatically clicks into power saving mode
I have a flatiron monitor that is attached to my laptop. It was working fine; after I was away for two weeks, monitor starts into windows but then immediately goes into power saving mode and image defaults to my laptop screen. When start up says digital mode in power saving and screen goes blank - now where even to go into bios
    Novelist:
    Champion:
  • 254 Answers
Laptops often have a function key which switches from laptop only, external monitor only, laptop & external. One of the top number keys, along with the function (fn for short) must be pressed simultaneously to step through these.
Where these keys are at, may differ from laptop to laptop.
Posted on Nov 28, 2007
2 Suggested Answers
SOURCE:
SOURCE: Monitor automatically clicks into power saving mode
My samsung 19" Syncmaster 920NW monitor is connected to analog port in my hp pavilion laptop.After the windows xp logo and loading,the monitor screen goes blank and the power LED blinks.The display functions normally on booting up in VGA mode (640X480).It functions normally on safe mode (800X600).In the normal mode,the screen goes blank and the power LED flashes.But, the laptop,main LCD panel shows alright.The display adapter is Nvidia GEFOECS GS 7600.What could be the poblem.
Posted on Oct 06, 2007
I have a Dell Dimension e521 desktop that has gone into energy save mode after I ran Norton security check.. Pressing any key or clicking the mouse doesn't do anything. The screen is black and says...
you may find you have the screen resolution set to high, try changing to 1024x768 and try again. if this works it means your monitor ain't up to the job of your better machines.
Nov 15, 2013 | Cars & Trucks
Enable Hibernation in Windows 7 Starter on Samsung N150
Sleep mode on a Windows 7 PC saves power without you having to turn your computer off and without losing any work. This option cuts the power to your monitor, powers down the hard drive and pauses all functions until you awaken the computer from hibernation. Whether you have a laptop, desktop or workstation, putting your computer into sleep mode will lower your electric bill and save money! Click the "Start" button in the lower left corner of your desktop. In the lower right corner of the Start menu, next to the "Shut Down" button, is a button labeled with a small, right-pointing arrow. Mouse over the arrow. The Shut Down menu appears. Point at "Sleep" and click on this option. Your Windows 7 computer goes into sleep mode. Wake your computer from sleep mode by jiggling the mouse. There may be a delay of a few seconds before your hardware powers on. All of your open programs are still open and your work is intact, just as you left it before the computer entered sleep mode. Configure your Windows 7 PC to go into sleep mode automatically when it is not used for a certain amount of time. Click "Start" and select "Control Panel." Click "System and Security." Click "Power Options." A menu opens. Click on "Choose when the computer sleeps" and select the number of minutes of inactivity. You can also set a separate time interval to put your monitor into sleep mode. If you set both to 10 minutes, then your PC and monitor will automatically go into sleep mode after 10 minutes of inactivity Your Computer in sleep mode b> First, save all of your work. Information in computer memory is not saved while your computer is on standby. From the Start menu, select Settings, then Control Panel, then Power Management. Click Standby Beside When I Push the Power Button. Push the Power button. b> Automatically Putting Your Computer on Standby b> Save all work before leaving your computer. From the Start menu, select Settings, then Control Panel. Double-click Power Management. Set the times that you want your system to go on standby, to shut off the monitor and to shut off the hard disks. Click OK. Your computer will go on standby according to the schedule you have entered. b> Putting Your Computer in Hibernation b> From the Start menu, select Settings, then Control Panel. Double-click Power Settings. Click on the Advanced tab. At the When I Push the Power Button On My Computer screen, click Hibernate. Click the Power button. Hope this helps.
Jan 16, 2013 | Samsung N150 Series Netbook
Won't go into sleep mode
Which operating system ?
A menu opens.
Hope this helps.
Nov 25, 2012 | Dell Factory Refurbished 4700-HH79N81...
My LG flatiron W1943TB turns on, says analog power saving mode, goes black and then the power button flashes.. but the monitor is hooked up to my dell notebook bc my LCD died
Hi erin mckinle,
That is probably it's, uh, analog power saving mode. When the screen goes black and the power button flashes, make some mouse gestures or hit some keys that would not affect anything (try spacebar). That should bring up the screen. If you think it goes into power saving mode too fast, go to Control Panel --> Power Options, and change the values. Hope this helps.
Jan 02, 2010 | LG W1934S-BN 19" Monitor
My monitor shuts down after one second.
Dell monitors automatically go into power-save mode after a preset amount of time when the computer is inactive. The Dell monitor will go completely black, instead of showing a screensaver. This doesn't mean that your Dell computermag-glass_10x10.gif has shut down. Instead, this allows your monitor to essentially turn off until it's needed again. You can change how long it is before the Dell monitor goes into power-save mode by changing your display settings.
  1. Step 1 Press any key on your keyboard or move your mouse. Either will turn off power-save mode. Alternately, you can press the power button on your Dell computer tower or laptop.
  2. Step 2 Press any key a second time if the monitor goes from power-save to stand-by mode. Stand-by mode allows the screensaver to appear.
  3. Step 3 Enter your user name and password into the login prompt if your computer requires a login. Press "Enter" to begin using your Dell computer.
  4. Step 4 Change the display settings on your Dell monitor to prevent your monitor from going into power-save mode prematurely. Right-click anywhere on your desktop and choose "Properties." Click the "Screensaver" tab and press "Power." Beside "Turn off Monitor," choose a time amount from the drop-down list and press "Apply."
Nov 13, 2009 | Dell Dimension 3100 PC Desktop
Power saving mode
Prevent the laptop/desktop monitor from going to power saving mode:
  • Click on Start | Control Panel | Power Options.
  • In the Power Option properties window, click on the Power Schemes Tab
  • Set the Turn off Monitor/ Turn off Hard Disks option when on Power (and also Battery for laptop users) to Never.
  • Now click on the Save as... button and assign a name to this power scheme... Let us call it 'Presentation' and then click on OK.
  • That's it congrats!
  • Aug 04, 2009 | LG Flatron L1951S 19" LCD Flat Panel...
    External monitor says laptop is in power save mode and goes blank
    hey jkep
    this has nothing to do with power, here is what to do
    right click your desktop->
    properties->
    click the settings tab->
    click the advance button->
    click the display tab->
    depending on your graphic card there should be 2 or 3 different monitors being displayed switch them on and automatically your TV will turn on then you can change the settings to your likings
    Feb 13, 2009 | Acer Aspire 5610 Notebook
    Dell Monitor Power save mode activate using pc
    yes right click on desktop select properties then click on screen saver then increase wait time problem will solved
    Oct 29, 2008 | ViewSonic VE155b 15" LCD Monitor
    check the primary settings for your default video card.
    Jun 08, 2008 | Dell Dimension 4600 PC Desktop
    I have an LG W2261V, and an old Sharp LL-T19D1-H. The PC runs both just fine, and the PSU has plenty of power. Unfortunately the LG handles power save mode very differently, where the LG would not switch on after entering this mode unless reset (unplugged, PC rebooted, etc). Extremely frustrating, as the old Sharp never had any problems exiting its own power save mode. The LG would enter this mode based on the monitor power settings (in whatever power scheme you are using) in the screensaver tab in display properties. I fixed this by selecting "Never" for "the Turn off monitor" property. I guess this is a warning to those who may wish to buy a new LG monitor, but want to use a power scheme to turn off the monitor.
    Oct 01, 2006 | LG Flatron L1951S 19" LCD Flat Panel...
    LG L1915S 19" LCD Monitor Logo
    470 people viewed this question
    Top LG Computers & Internet Experts
    Ekse
    Alun Cox
    Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
