Question about NetGear GSM7224 switch 24 ports (S2859748)
Netgear problem the switch cannot open web page and led more then indigate yellow and network is slow pls give me a solution
  • 456 Answers
Just uninstall netgear and install it again
Posted on Nov 28, 2007
I would like to change my pasword
most likely you will need to remove the program from the computer and then reinstall. then you can make a new password.
Sep 15, 2012 | NetGear WGR614 Wireless Router
How do i rest my netgear password
logon on via 192.168.1.1
if you have not change username then it will be
guest
password will be password
you can then find the setting to change them.
if they are set and you cannot remember them hard reset the modem with the inset button on the back with a pin hold for 10 sec. the default will come up.ie admin/password now yu can reset them
Jul 06, 2012 | NetGear Computers & Internet
Info on how to reset the router
You can factory reset the router using the small button on the back, hold it in for 30 seconds with the power on to the router. This will clear all settings from the router including the password, so you will need to set up the router again after the reset.
Sep 21, 2011 | NetGear WGR614 Wireless Router
I need to reset or find my origional password. Please help. Thanks
If you have changed the default password, you need to reset the router to the factory settings to get in with the default user and password (user admin and password as password, or if that doesn't work try 1234 - these are the default password for NetGear routers). Note that you will lose the ISP settings and wireless settings when you reset the router.
Here's a video on how to reset the router to the factory default settings: http://kbserver.netgear.com/media/flash/training/Troubleshooting/NG_WGR614V9Router_TS_LostPassword.html
Feb 17, 2011 | NetGear DG834G Router
I have a netgear wireless router with WPA security. and i bought a WRE54G . I cannot configure the expander as you know netgear IP is 192.168.0.1 and lynksys expander is 192.168.1.240. when i open...
Try to reset WRE54G
Resetting the Range Expander to Factory Default
The range expander can be set to factory default by pressing the Reset button of the range expander for 20 seconds.
NOTE: The default IP address of a range expander is 192.168.1.240.
After resetting the range expander to factory default and you're still unable to access the web-based setup page, make sure that your computer's proxy settings are disabled. For instructions, click here. To disable the proxy settings using a Mac computer, click here.
NOTE: If all the steps above failed, try to disable any security software on your computer before accessing the range expander's web-based setup page. Click here to learn how to disable your computer's firewall.
If you are using a Wireless-G Range Expander (WRE54G v2 or v3) and you can't access the web-based setup page, perform the following steps:
Checking Physical Connections
Make sure that the computer is connected to the range expander's LAN or Ethernet Port. If the range expander is properly connected, check the LEDs on the network adapter. For instructions, follow the steps below:
Checking LEDs on the Network Adapter
Make sure that the LED light of the computer's network adapter is lit or blinking. After checking the LEDs on the network adapter, assign the computer a static IP address.
NOTE: If the network adapter's LED is not lit, try using a different cable to further isolate the problem..
Assigning the Computer a Static IP Address
For instructions on how to assign a static IP address on your computer, click here. After assigning a static IP address, check the computer's connectivity to the range expander.
Checking the Computer's Connectivity to the Range Expander
For instructions on how to check the connectivity of your computer to the range expander, click here. If you're still experiencing difficulty accessing the web-based setup page, reset the range expander.
For instructions on how to restore the range expander to factory default, click here.
If you're still having difficulty accessing the web-based setup page, make sure that your browser's proxy settings are disabled.
If you're using a Wireless-G Range Expander (WRE54G v1), you need to do the following:
For instructions on how to assign a static IP address on the computers' wireless network connection, click here.
Connecting Wirelessly to your Range Expander
NOTE: In this example we used WUSB54GS V1.0 (Wireless-G USB Network Adapter).
If you're using a Mac computer, click here for instructions on how to connect to a wireless network using the AirPort card.
Step 1:
Run the Linksys Wireless Network Monitor by double-clicking this icon 3719-001.jpg at the bottom-right corner of your screen.
4146-005.pngStep 2:
Click Site Survey then select the SSID of your wireless range expander and click Connect.
NOTE: The default SSID of the range expander is in this format linksysRxxxxxx.
4146-007.pngChecking the Computer's Connectivity to the Range Expander
NOTE: If you're using Windows 98 or Windows ME, click here.
If you're using a Mac computer, click here.
Windows 2000/XP
Step 1:
Click Start, then click Run.
Step 2:
When the Run window appears, in the Open field type "cmd", then click OK.
3984-003.pngStep 3:
When the MS DOS Prompt appears, type "ping 192.168.1.240" then press [Enter].
Step 4:
See if you're getting 4 replies, Packets: Sent = 4, Received = 4, Lost = 0 (0% loss)
Nov 08, 2010 | Linksys Wireless-G Range Expander (WRE54G)
How do i reset password for netgear router
There should be the reset button behind the router, click on it for about 5-10 seconds.
Jun 26, 2010 | NetGear WGR614 Wireless Router
Have wireless broadband on home computer with Netgear dont have network key which I need to connect new laptop to wireless broadband Bt of no help and cannot give me a no fo Netgear either even though Bt...
You will need to check the wireless settings of the router .
Is there any computer connected to the router with the Ethernet cable?
If not then connect 1 computer to the router and open the router set up page. Once you open the router set up page, you will be able to find the wireless network key.
Use that password to connect to the wireless network
Click Here for step by step Instructions on how to find the network key
Dec 19, 2009 | NetGear DG834G Router
I hooked up my netgear WGR614v7 to my desk top. why isnt my laptop hooked up to the internet?
Are you connect the laptop wirelessly??IF so follow the steps
1.open the browser page in your desktop(wired computer) and type www.routerlogin.com on the address bar and click enter.It ll ask you usernamand password.username:admin and password:password or if you have set any password.If you are not able to open the router page then unplug the ethernet cable connected to your isolated port on the router and on the address bar type 192.168.1.1 and click enter and give the user name and password.
2.Now we have to configure the router for wireless settings.In netgear smart wizard page at the left side blue screen
*click wireless settings under set up menu.
*In that page enter
name(ssid):netgear1
region:ur country
channel:11
mode:g and b
In security options select wep and key1 give your telephone number so that you wont forget the password.CLICK APPLY.we have secured the n/w.
3.Now in your laptop(wireless computer) scan and connect to the network.
For windows vista-start->connect to->select the network name(netgear2)and click connect->it ll ask for password,enter it(telephone no).you ll successfully connected.Now disconnect the cable and try going online wirelessly.
For xp-start->control panel->network connections->right click on wireless network connection->select the network and configure.
you ll get successfully connected message and you ll be able to go online.If this solution solved your problem pls rate me or if still unable to connect send me the reply i ll help you.
Sep 30, 2009 | NetGear RP614 Router
Netgear wgr614v5
Hi 632423.
We may not have enough information about it but let me set it to bits. Is it your PC / Laptop that doesnt have connection wirelessly or is it you netgearwgr614v5?
By default netgears wireless conneciviy is turned ON by default . If this doesnt work pls check admin settings by accesing 192.168.1.1on your address bar and make sure wireless is enabled . Best if reset to its default settings by pressing the reset button at the back of your router. By doin this  your router will be back to factory settings and by that the time you can check if wireless is on   {  LED light } .
Also check encryption , your wireless client installed on your PC or Windows Zero Configuration is started.
Pls let us know how we can help you more by providing us more info regarding this issue.
Good luck.
Jun 06, 2008 | NetGear WGR614 Wireless Router
NetGear GSM7224 switch 24 ports (S2859748) Logo
121 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
