Question about Acer AC 713 17" CRT Monitor
Monitor green where it should be black
Hi
I recently moved my PC from one room to another. When i switched it back on, all the monitor has a green tint to it esp where itshould display black. I have unplugged and tighted what i could..no luck thus far.
  • 57 Answers
The Monitor has a problem either with the color gun or the IC inside sometimes it just needs to be solder back into place,it happened to me once when i moved around my monitor,i had to solder the board inside,hopefully u don't have to replace any parts good luck.
Posted on Nov 28, 2007
  • 749 Answers
Resolder some components on the boards inside your monitor especially on the CRT neck board.
check also your monitor cable connection to the System unit.
also check if your video card was fully intact on the board.
SOURCE:
Have A Samsung 940Bw connected via DVI connection and has worked fine for last 3 years. Monitor was on and working fine went out of room and came back to black screen and the blue light flashing on the...
First thing I would try will beusing this monitor with another PC using the same the same setup to see if it works OK. We need to narrow down the cause of the problem first since you have three parts that can be bad; Monitor, DVI cable, PC Video card/PC. It is just a process of elimination to locate the problem.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Apr 14, 2011 | Samsung Syncmaster 940BW LCD Monitor
I have a compaq FS940. It worked perfectly fine until a recent move were we had to diconnect everyhting. When i reconnected it all my monitor just instanlty goes to sleep. My modem works fine but the...
mdl34, Your monitor is listed as "time to retire" and get new unit on retrevo .com You might try "reseating" all the connections to the monitor and vga connector on the pc. examine all the connector "pins" in the cable connector and note any damaged or bent, crushed pins. Try moving monitor to a "known-good" fully booted pc to see if same problem occurs. Swap-in a good monitor to your pc to prove that pc is operating correctly. 12fixlouie
Aug 07, 2010 | Compaq Computers & Internet
Issue with the monitor
well
borrow a monitor and thy that.
or move your pc to a friends good monitor and try that.
or more easy
press button 2
if the OSD menu id dead the monitor is dead.
http://www.manualsdir.com/manuals/68175/compaq-mv-740.html?page=8
if that test passes. then the PC is sick
but no PC told.
nor OS
Jun 04, 2017 | Compaq MV 740 17" CRT Monitor
Monitor changing colors hpvs 15
Try the monitor with a different computer. If it work, then the problem is the other PC, if it does not work, then your monitor is failing.
good luck
Dec 13, 2008 | HP vs15 15"LCD Flat Panel Monitor
Still having trouble with EMachines T3882
I feel your pain. I finally moved my pc to a room with no windows! But seriously, try a different monitor first. See if you can borrow someone's to just try it before you do anything else. If that borrowed monitor works fine, then you know what the problem is. (Which I believe is the problem.) By the way, what started all of your problems?
Aug 20, 2008 | E-Machines eMachines Desktop PC
My new hp2408w monitor goes black when I quit working for a while. I walk back in the room ready to continue and the screen is black, the screen saver is not on and I don't know how to make it come back...
You may have the power saving features enabled in XP. I believe it's on by default. Usually the monitor would come on automatically by moving the mouse. You can disable this feature:
Start -> Control Panel -> Switch to Classic View (if not already enabled) - > Power Options -> Change "Turn off Monitor" to never
May 31, 2008 | HP Computers & Internet
NO POWER AT ALL!
Does the power supply have its own power switch?
It is located next to where the power wire plugs into the back of the PC.
Jan 10, 2008 | E-Machines eMachines Desktop PC
Monitor switching to standby - CV735 monitor with Presario 5000 series desktop
my compaq crt monitor not showing color. its shows only blue, green colors . u please tell me. what is the problem in.how to solve it.
is the monitor fault or any other.
Oct 30, 2006 | Compaq CV735 17" CRT Monitor
Acer AC 713 17" CRT Monitor Logo
77 people viewed this question
Ekse
Alun Cox
