Booing problem HI,ok! i am using Toshiba laptop satellite 2410-303 model when i start the computer it's boot properly but when it reach the OS selection menu & i select the windows( i have tow windows, win XP & win 2003 server) it will restart automatically. i reinstalled the windows but after fey times it will have the same problem.even i am not able to enter in safe mode even by disabling the VGA, sound card. please guide have i can fix this problem?!
    Problem Solver:
  • 15 Answers
Some computers have problems with having two operating systems, such as your xp and 2003. You could try deleting the 2003 server and downloading xp only.
If your os does not work after doing this then it is a safe bet that the problem lies with the xp software you have (It might have a corrupt file on it) and you might need to get a new copy of xp.
If all else fails then your 2003 server should be a fine substitute for your os
Posted on Dec 31, 2007
SOURCE:
How and where to download all drivers for toshiba a665-s6093 after reinstall the os with windows 7 64 bit some of fitur like hot key and etc not working properly....pls need help asap !! thanks
Hi
Go the website of the manufacture, choose your laptop model (
Satellite A665-S6093), and the operating system ( 7-64bit),
and download the software utility for the keyboard
Please tell us your results
Good Luck
May 16, 2011 | Toshiba Satellite A665-S6093 Laptop
I need to reset my laptop
Hello, here are the steps to resetting your computer.
Reinstall Windows from a Disk
1 Turn on your Toshiba Satellite. Insert your recovery disk or the original Windows operating system DVD
into the Satellite's CD/DVD drive. Turn off the computer.
2 Turn on the Toshiba Satellite. In the first few seconds while it is starting up, press and hold the F12 key on your keyboard to access the Boot Menu. (Note: Some Toshiba models may tell you to press "C" to boot
from the CD-ROM). The screen will display boot for this boot up session only.
3 Use the arrow keys to navigate. Select the CD-ROM/DVD drive to highlight it. Press "Enter." Be aware that this setting is for this session only; it is not a permanent change.
4 Allow the computer to start up. Follow the onscreen instructions for reinstalling the operating system from the disk.
Reinstall from a Recovery Partition
1 Boot up the Toshiba Satellite. In the first few seconds while it is starting up, press and hold the F8 key. This will begin the "Advanced Boot Options" menu.
2 Use the arrow keys on your keyboard to navigate the menu. Move the keys to select "Repair Your Computer." Press "Enter."
3 Select your language and keyboard; click "Next."
4 Select your Windows user name from the drop-down menu. Enter your password if required. Click "OK." This will begin the "System Recovery Options" menu.
5 Select the Toshiba Recovery Wizard and follow the onscreen instructions. The Toshiba Recovery Wizard will delete all existing data on the hard drive and reinstall Windows.
Hope this helps!
Mar 28, 2011 | Toshiba 173" Satellite L555S7008 Intel...
MY TOSHIBA SATELLITE PRO LAPTOP WONT GO PAST THE WINDOWS XP LOGO SCREEN AND HAS BEEN FROZEN LIKE THAT FOR HOURS BUT THE LOADING BAR IS STILL MOVING
Hi Good day!!! Try to boot in safe mode, to boot from safe mode, do this: while booting just keep pressing f8 button until advanced boot menu appear after that choose safemode. after that your OS will boot in safemode. if not booting there should be a files missing in your OS you will need to repair it using a CD of you OS. reply to me to help you more
Thank you for using FixYA
Please accept if my solution helps you
Nov 24, 2010 | Toshiba Satellite Pro L300 Notebook
How i can boot from a cd to install os
1. Turn on your computer
2. press the proper key in order to enter bios setup while black screen in progress. this key may f2 or f8
3. investigate the boot device order
4. set the cdrom as #1
5. press f10 key to save and exit.
6. put a bootable installation CD/DVD into the cd/DVD reader's tray.
7. cut off the po-wer
9. power on the computer
if everything ok, the computer will check the cdrom device to boot and start booting from cd.
Aug 18, 2010 | Toshiba Satellite 2060CDS Notebook
Ati2dvag beginning dump of physical memory, what I do ?
Power ON your laptop and press F8 key to enter start up menu. select Safe Mode. If Windows boot normaly, go to Control Panel and Add/Remove Programs. Uninstall VGA driver and its application and then reboot your laptop.
Verify your laptop model and download and install proper driver from;
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?ct=DL&os=&category=&moid=968287&rpn=PSA60U&modelFilter=A65-S1069&selCategory=3&selFamily=1073768663
Hope this will work, best of luck.
Regards;
Hassan
Sep 19, 2009 | Toshiba Satellite A65-S1069 PC Notebook
Problem with sound, modem and bluetooth for Toshiba SatelliteA100
You can download any/all the Windows XP device drivers for your model laptop from the Toshiba WEB site from their download page. Make sure you enter the model of your laptop so you can get the correct drivers. Use this link :-. http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/home.jsp#
Jun 13, 2009 | Toshiba Satellite A100-S2311TD Notebook
Boot mgr is missing
i have almost certain that it is because of your OS boot with the dvd of your OS and try to repair it
May 17, 2009 | Toshiba Satellite PSLD8U-01F00Y Notebook
Problem with installing new windows OS on toshiba A105
You should put the drive back in the external caddy, delete the format, partition the drive for NTFS. format the drive and set as active.
Mar 24, 2009 | Toshiba Satellite A105-S2712 Laptop
Won't Load OS from DVD
If your laptop will post, meaning you can get to the BIOS, then YES. Re-flash it with the original BIOS, or a newer but proper BIOS. Then all should be OK again.
Feb 15, 2009 | Toshiba Satellite M115-S3094 Notebook
Open Questions:
Computers & Internet Logo
71 people viewed this question
Ekse
Alun Cox
