Bad sectors in hard disk
My hard disk have many bad sectors . Only 15GB can be partitioned.
If other 65GB is trying to partition then the partition table completely destroy
Please give a solution. My mail id is [email protected]
    Novelist:
    Champion:
  • 254 Answers
Download the manufacturer's diagnostic software, run it. Perhaps it can do a low-level format which will recover unusable space.
I wouldn't trust this drive with any valuable data, even if the diagnostic software works. The drive is probably soon to fail completely.
Posted on Nov 28, 2007
SOURCE:
Hard disk poblem
click start control panel administrative tools computer management disk management right click on your drive select properties click tools you should see click check now click start two boxes
automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now start
you might tick one box then return after its finished the first repair then return and tick the second box you should not do anything while the chkdsk utility is in progress any input may damage this drive
I found that you get best results by ticking one box then returning after it has finished then tick the other box
since its only the sectors you are having problems with just tick the bad sector box
then download partition magic which will only install on the good sectors on your hard drive
http://www.filehoo.com/download/Partition-Magic-8,0.aspx when you download partition magic you will have the option to make rescue to disks to boot from make these disks then change your first boot device your to floppy drive this will give you options to partition then partition only the good sectors of your hard drive and install an operating system to the good partition
Partition Magic 8.0 description
Partitioning your hard drive plays an essential role in maintaining your computer-preventing conflicts, protecting data, improving efficiency, and increasing performance.
Partition Magic allows you to create, resize, merge and convert partitions without destroying data. Award-winning
PartitionMagic Pro from Symantec is a leader in hard-drive partitioning software. PartitionMagic Pro allows you to create, resize, move, and convert partitions without destroying your data. You can quickly and easily create partitions, which can act as file drawers on your hard disks for storing valuable information such as data files, applications, and operating systems.
Storing information in separate partitions helps you organize and protect your data, safely run multiple operating systems, and reclaim wasted disk space.
hope this helps
Aug 31, 2012 | Western Digital Computers & Internet
Dear sir i have seagate ST3160215AS 160gb sata hard disk. in bios it shows 160 gb but in actual it gives only 149gb. i have tried to dm it but no dm matches it. then i tried ontrack to it. it shows 160 gb....
the hard drive might be damaged bad sectors
the operating sytem will take/use a certain ammount of space onyour hard drive
click start right click on my computer you should see your drive usually C: select properties click tools check now tick both boxes automatically fix files and scan for and attempt recovery on any bad sectors or you could tick one box and wait until its finished then return and tick the other box
then select check now start should schedule this task when restart
do not do anything while the chkdsk utility is in progress any input may damage your computer
then defragment your hard drive
PartitionMagic allows you to create, resize, merge and convert partitions without destroying data. Award-winning
click start run type cmd then type chkdsk/r/f which will scan for and attempt to recovery any bad sectors and automatically fix any corrupt files on your hard drive there are many ways of running the chkdsk utility
hope this helps you
Oct 23, 2011 | Computers & Internet
I got a maxtor ide harddisk which was already partitioned, i tried to format one partition for installing windows, but seems thare were bad sectors i tried to format all but it was not possible. Now the...
When a hard disk has bad sectors, the magnetic layer is worn out and the number of bad sectors will increase. If you keep using this hard disk you risk losing your data. This hard drive cannot be repaired, throw it away and get a new one.
Jun 25, 2011 | Computers & Internet
Samsung hd154ui hard drive - cannot format above 1 TB says 500gb available but does allow one to create a partition
The drive has developed some bad sectors on it
click start run type cmd then type chkdsk/r/f which will scan for and attempt to repair any bad sectors and automatically fix any corrupt files on your hard drive or
click start control panel administrive tools,computer management ,disk management right click on your drive select properties click tools you should see click check now click start two boxes automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now,start should schedule this task when restart
or you could download partition magic
when you download partition magic you will have the option to make rescue to disks to boot from make these disks then change your first boot device your to floppy drive this will give you options to partition then partition only the good sectors of your hard drive and install an operating system to the good partition Partition Magic 8.0 Partition Magic 8.0
note: after you loaded your operating system you will have to change the boot order back to your hard drive
During the boot process you will see on the screen to press a certain key to enter setup Press and hold that key during the boot up process to enter BIOS the scroll down to advanced bios features press enter change your first boot device to cd press escape then press f10 to save to cmos to restart
Hope this helps you
Apr 06, 2011 | Samsung 1.5TB F2 HD154UI/Y HDD EcoGreen F2...
Error code 0f00:0244 during hard drive diagnotic test
the drive has developed some bad sectors on it
hope this helps
Mar 19, 2011 | Western Digital Caviar WD1600 (1600YD) 160...
How to remove bad sectore of hard disc? s/n=0415j1ftc02540
Let's try to explain the question that grinds us all when in cams about the hard disk. Can we actually repair a bad block? Before of the answer you must find some information about what is a hard disk, how does it work, what are bad blocks. After that you must identify them because you will need the exact location of the affected sectors. After you have done that you must run a few steps:
- before you try to resolve the problem with the bad sector you must extract the data that was written to that block. To do this you must run a Recovery program that you can find freeware on the net.
- bad sectors are unreadable parts on your hard disk but the nature of them must not be always physically and that part of the platens to be destroyed. The bad sectors can be simulated by some programs. This means that some programs installed on your computer can interrupt the reading process on to another segment of the platens. That is in the most happier cases but the chances that the bad sectors are cause by this is less then 10 percent. In this case is difficult to resolve the problem because even the Scandisk or other identification programs used to discover bad blocks will give a rapport that nothing is wrong with your hard disk. The best way is to uninstall the latest programs applied to the computer.
- lets supposed that you have a 20 gigabits partition on your hard disk that has bad blocks. After the identification program it will indicate you where are the blocks situated on the partition. So this way you can isolate them in to another partition that you must never use again. Another scenario can be created and the bad sectors can be at the beginning of the partition in the middle of it and at the end of the partition. Know it's a little bit tricky because you can't just go on and create three new partitions to eliminate the bad sectors from use. In this case most of the new hard disk has a spare space available just for this type of scenarios. You must access the CASH memory of the hard disk and indicates to the hard disk that instead of writing down on the effected blocks it must write to the spare blocks.
- another to restore the hard disk is to use the low level format option. Many of you think that low level format is a program. Wrong, the low level format option is set for any BIOS and can be easily use if you know some command line programming. The low level format can take to be complete a very long period of time but in the most cases we can obtain marvelous results. Actually the low level option takes every cluster of the hard disk and identifies them again (throw a thermal process) and writes down on the memory of the hard disk what sectors can be written and witch blocks are un-writable. This procedure is the best that can be because it will need no effort from your side to try and avoid the bad blocks that already exists and the hard disk itself know where the bad blocks are.
In conclusion the bad blocks can't be fixed. The problem is a permanent one and we can only try to use the hard disk until it is broken down for good. But if you are having financial problem this is a best way to keep going with your old hard disk.
Thank you for choosing FixYa! Your rating will help me succeed and continuously help a lot people.
Feb 03, 2011 | Maxtor Hard Drive
Hard disk Bad sector Problem
Bad sectors is a sure sign of bad problems down the road. I recommend Backing up all you data and replacing the drive as soon as possible. The drive is failing. Hope this was helpful.
George
Jul 16, 2008 | Computers & Internet
Open Questions:
Computers & Internet Logo
783 people viewed this question
Ekse
Alun Cox
