freezer will not freeze. no ice on coils in back of inside. frig side is o.k. Fan blowing cold air in the frig side.
vacuumed dust from back side cylinder and fan is blowing in the cylinder. Compressor is hot.
Comments:
Aug 15, 2009
- after turning off for 30 minutes, then turning back on. Next morning freezer was at 5 degrees, but frig at 29 and milk was frozen. Did not replace the board. What is wrong now? do I still need to replace a board even though it is freezing again?
thanks
replace control board on back of unit there is a six by 10 inch cover on back your panel is in there cost aprox 169.00 dollers also replace bo0th thermisters bottem left of freezer looks like a white bullet the other is in fridge behind shelf trim located beside and underneath where the cold air blows into the fridge.
Comments:
Aug 16, 2009
- if you want a conservative approach i would reolace the thermistor in the frige as long as your temp settings are correct .
Need to know how to take off the broken piece of tubing and connect the new. Blue Valve assembly. ...
(More)
Need to know how to take off the broken piece of tubing and connect the new. Blue Valve assembly. Should be simple but I just can't see it.
need the hose that runs under and internally for my profile. Appears to be 1/4 ID and 3/8 OD. It's...
(More)
need the hose that runs under and internally for my profile. Appears to be 1/4 ID and 3/8 OD. It's brittle and leaking
temperature controls are out. Changed main control board but problem persists. fridge is still...
(More)
temperature controls are out. Changed main control board but problem persists. fridge is still chilling, ice works etc
I have a whirlpool side by side and the ice maker doesn't work the arm goes up and down but no water...
(More)
I have a whirlpool side by side and the ice maker doesn't work the arm goes up and down but no water seem to be running
