Question about GE Spacemaker JVM1640SJ Microwave Oven
Bulb replacment for GE Microwave Model JE1540wv002
The info was helpful but the diagram was for a diferent model, is it possible to access the diagram for my model
  • GE Master
  • 9,098 Answers
There should be a very helpful "mini-manual" hidden inside the unit behind the control panel. It has wiring, schematics, and troubleshooting info.
Yours will be found as JE1540WV02 (instead of 002) here: http://www.tinyurl.com/gv383
Posted on Nov 28, 2007
GE Spacemaker Micro/Oven Need to change (inside) light bulb on model #JVM1490SH02 Serial # TH901044K. Where is the bulb located?
While replacing the cooktop light can be done by accessing the cover on the bottom of the oven, replacing the cavity light will require you to pull the oven from the wall and remove the outer cover.
The installation instructions are very handy in this case, and it's best to have two people since the microwave can be heavy and awkward.
You can download GE owner's manuals and installation instructions here.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
Aug 18, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
The light on my ge JEM31 microwave works intermittantly. How do I replace/tighten the bulb.
In there models, the cavity light is located in the magnetron cooling duct on the right side of the chassis.
You need to remove the outer cover to access it. See this file and this file for disassembly help.
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
Jun 28, 2010 | GE JEM31 Microwave Oven
I have the same problem
GE Customer Service is here and they should be able to tell you what the "drop-in replacement" is for your model.
Of course, most microwave problems are pretty simple to repair.
If you're interested in our advice there, please reply back with your detailed symptoms.
Otherwise...
Jun 07, 2009 | GE JE1540 Microwave Oven
GE microwave interior light bulb replacement.
Your post has two distinct model numbers shown, so it's hard to be precise, but I'll try my best.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
I have a diagram at my site which helps you find & replace many GE cooktop and cavity light bulbs. Other models are similar. It's at
http://207.234.249.73/mwd/ge_lamp_replacement.jpg
Always unplug a microwave before removing or installing any bulbs!
If it's an over the range type, remove the vent grille across the top and see if bulbs can be accessed there.
There may be a panel on the bottom covering the light(s), too.
If not, chances are you'll have to remove it from the wall, then remove the outer cover.
Many models use halogen lamps. You must not touch the new one with your bare skin, as the oils will shorten the bulb life.
If yours is an Advantium type, the following instructable should help: http://www.instructables.com/id/SZFF4WSF44XYT8X/?comments=all
We're happy to help and we appreciate your thoughtful rating of our answer.
Jun 03, 2008 | GE JES1289SK Microwave Oven
Burnt bulb in kitchenaid microwave
You may have to remove a panel on the bottom or remove the grille across the top.
I have a diagram at my site which helps you find & replace many GE cooktop and cavity light bulbs. Other models are similar. It's at http://207.234.249.73/mwd/ge_lamp_replacement.jpg
In some over-the-range models, that can mean having to take the oven down from the wall! For safety's sake, that should be a two-person job and it's really helpful if you have your original installation instructions to do this.
Many models use halogen lamps. You must not touch the new one with your bare skin as the oils will shorten the bulb life.
Apr 24, 2008 | KitchenAid KBMC140HSS Convection/Microwave...
Replace Blub GE Microwave oven Model 1540
On my Spacemaker, access for bulb replacement is on the top of the chassis, which is under the top/side cover. From a diagram I looked at, it appears that yours is similar. If so, you have to:
1. UNPLUG the microwave and then remove the three retaining screws that you'll find on shelf or cabinet above the microwave. Get help; the front of the microwave will be heavy when the screws come loose from the top.
2. Rotate the front of the microwave down a little and lift the rear up about a half-inch. At this point, it is free from the rear mounting plate. Set the microwave on a suitable work surface.
3. Remove the top/side cover piece. To do this, remove all the small screws on the top, the back, and the bottom edges on each side. Then slide cover back about an inch and lift it off.
4. In the middle section of the top of the chassis, you'll then see a cover above the location of the bulb. Lift it up to get access to the bulb.
It's a lame design for an over-the-range unit, but that's the way it is.
Here's a link to a diagram of what it looks like after you get the cover off: http://www.partselect.com/MultiModels.aspx?ModelNum=jvm1640sj&searchTerm=img_00115013i05&RefineSearch=0&imgMfg=GE
Nov 27, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
Manufacturers used to include access panels in the rear or side so you could easily change the bulb. That exposed the customer to 110V connectors, and that posed a real liability threat, so they stopped using them.
You now must generally remove the outer cover to replace the bulb.
In many over-the-range models, that can mean having to take the oven down from the wall! For safety's sake, that should be a two-person job and it's really helpful if you have your original installation instructions to do this.
Many models use one halogen lamp to illuminate the cooktop and another to illuminate the cavity. You must not touch them with your bare skin as the oils will shorten the bulb life.
You can find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
Nov 19, 2007 | GE Advantium SCA1000H Convection /...
GE microwave: no lights, no fan, no noise, no heat, but display works.
The control board has been damaged but it can probably be repaired. We repair this common control board problemn on a regular basis for only $39.95 nationwide. If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk You can find helpful exploded view diagrams and order parts by entering your model number here: http://tinyurl.com/gv383 Feel free to contact me directly if you have further questions. I appreciate your thoughtful rating of my reply.
Jun 20, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
Broken light bulb
First of all, always disconnect the oven from the line before you remove or install bulbs, otherwise, you can damage the control board. We repair them all the time because of this. You can find helpful exploded view diagrams and order parts by entering your full model number (without the suffix) here: http://tinyurl.com/gv383 We have critical safety & disassembly info at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk
Apr 21, 2007 | GE JVM1430 Microwave Oven
Light Bulb Replacement On JVM 1860SF001
You can find an exploded view diagram by entering your model number (without the space) here: http://www3.sears.com/ That diagram may help.
Mar 23, 2007 | GE JVM1860 Microwave Oven
GE Spacemaker JVM1640SJ Microwave Oven Logo
420 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
vince
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
