Question about Toshiba 57H93 57" Rear Projection HDTV
57H93 Toshiba My 3 year old son tried to "clean the TV like Daddy" with Lysol kitchen cleaner... I tried cleaning it off with a damp cloth or Monster LCD cleaning solution, it didnt work. I think I'm gonna hafta replace the screen. Any thoughts where i can get a replacement screen? Also some other sites spoke of different protective styles of screens. thanks Derrick [email protected]
    Genius:
  • 1,694 Answers
Protect screen Part # 23311038.......117.30
Fresnel screen ( inside ) # 23311014 ...65.47
Lenticular screen ( middle) # 23311128....81.96
You should only need the protector screen......T.
Posted on Nov 29, 2007
SOURCE:
Self cleaning oven
After the self cleaning process you might see i wight powdery residue. This can be cleansed out with a damp cloth. No chemicals should be needed. If you use household cleaners you may have some odore when you use your oven so I would just use a damp cloth.
Apr 04, 2014 | Tappan TGF320 Gas Kitchen Range
Fix screen got wet
These screens do not like water or chemical cleaners. I would try rubbing a soft damp cloth on a small section then dry it quickly gently with a soft dry cloth. If you see an improvement, clean the rest of the screen that way slowly a section at a time. Thats how I cleaned my Samsung Projection TV screen, I spent 30 min or so doing it but it was not very dirty.
Good Luck :)
Nov 08, 2013 | Mitsubishi Televison & Video
What is the best way to clean a 46" LCD Toshiba TV
You do not want to use any harsh chemical or anything in excess. What I use and recommend is simply water and dish soap such as ivory. Use clean lint free paper towels or cotton or soft fabrics. You put a drop or two of detergent on a damp towel.You gently wash the screen then wipe it dry. The towel needs to be damp but not enough so that you get any running water.You may need to do it in small sections. If you use too much soap you get streaks. If that happens just get another damp piece without soap and go over and then use the dry to wipe the screen dry. The soap takes off anything without harming the anti-glare coatings on the screens. The wrong type of alcohol or a harsh cleaner can strip these coatings off or damage the plastics. Dish soap and water is very safe dirt cheap and found in the kitchen usually. ;-]
Sep 02, 2011 | Toshiba 46SL417U LCD TV
How do I clean my lg screen on my tv properly
Hello
Buy one Bottle of Monster ScreenClean Home & Office Display Cleaner
Make sure your TV screen is completely cooled before cleaning. Have TV turned off for about 30 minutes before cleaning to allow screen to cool off. Unplug TV. Make sure the area where TV is located is well lighted. This will make it easier for you to see if you are leaving any smudges behind when you clean your TV screen. I suggest you get a Monster ScreenClean Display Cleaning Kit, unless you have a couple of clean and quality Microfiber cloths in your home. If so, you can buy the ScreenClean solution separately. Some LCD TVs come with a Microfiber cloth, but they are usually a bit small
Spray Monster ScreenClean to Center of TV
Assuming you are using the Monster brand display cleaner, remove the little plastic cap on top of the bottle pump. Please do not try to go cheap with display cleaning solution when you most likely have a not so cheap TV. The cleaning solution will be much cheaper than having your screen repaired or replaced. The Monster directions state to either spray the ScreenClean solution onto the Microfiber cloth or directly onto display surface. Although the Monster solution is drip resistant, it does trickle sometimes, although very slowly. For that reason, I suggest if you are going to spray your screen directly with the Monster solution, spray toward the center of the TV screen about 8 inches away from the surface. Do not worry, if you forget and spray the solution closer to the frame of the TV, the display cleaning solution is still rather slow in to trickle down your screen. Just use a little caution
Gently rub Microfiber cloth in a circular motion to apply the cleaning solution evenly over entire display. Repeat with dry portion of the Microfiber cloth if the TV screen needs extra polishing. You may get a smudge free cleaning without the dry portion of your cloth if your TV screen was not that dirty
To clean the frame of most LCD and plasma TVs use a clean eye glass cloth dampened with water. Make sure to go in one direction around the frame of the TV. Check manufacturers directions to be certain, but for most the eye glass cloth should be fine. Since it is made to take care of eye glasses, it does not scratch. For certain it works fine on the Samsung Touch of Color TV frames
May 13, 2011 | LG Televison & Video
I used a soap/water solution to clean my plasma screen but used a regular cloth instead of microfiber and now there are horrible streaks on the tv that won't go away. Help! Is there anything I can do?
You can try to use a harsher cleaner like lysol but sometimes the streaks are permanent. The screen is glass but some tvs have a glare reduction layer that can be destroyed with harsh cleaners (like lysol). Your soap cleaning shouldn't have damaged it.. I would try just water and see if the streaks change. If they keep changing as you clean, its probably some scummy residue, but if they apprear to be permanent, then it could be damage. I always recommend the store bought plasma cleaner with the microfiber cloth, but if you smoke or have a really dirty tv, sometimes you have to cut it with lysol or something. Clean at your own risk, as anything not made to clean the tv can sometimes cause damage. I've seen paper towels scratch the glossy frames sometimes even.. good luck
Jun 11, 2010 | Panasonic Viera TH-50PX80U Plasma TV
Front screen
HOW TO CLEAN TV SCREEN;
Much like anything in your home, TV screens get dirty with fingerprints and dust and require a periodic cleaning. Keeping your TV screen clean is essential for ensuring a clear picture. However, cleaning the front of your TV is not something that should be left for the cleaning lady. The use of certain cleaning products and solvents can damage the front of your TV screen. Special care must be taken in order to make sure that your TV screen is cleaned properly.
Every kind of TV has different steps for proper cleaning. If you are unsure what kind of TV you own, consult your TV user's manual to ensure that you are using the right cleaning method.
  • Direct-View - Older direct view TV's can be cleaned with glass cleaner and a paper towel. Newer tubes that may contain any special coatings, like an anti-glare coating, should be cleaned with a damp cotton cloth. If you are unsure if you have any special coatings, it is best to be safe and use the damp cloth.
  • CRT Rear-Projection - Before you can begin cleaning, you need to determine if you do, or do not have a screen shield. A screen shield is a hard plastic cover over the front of the TV screen. If you can't tell, give the front of the TV a light tap. Another way to tell is to check for ridges in the screen area. If you can feel ridges on the screen, then you do not have a screen shield. Rear projection TVs without a screen shield require a special kind of cleaner and rag. These are available for purchase at your local TV service center. Those that do have a screen shield should be cleaned with a dry or damp soft cloth. If it's extremely dirty, a mild soap may be used. Do not use paper products, such as paper towels, to clean the screen shield. Paper products can easily scratch the surface of the shield. Screen shields can have a tendency to streak while cleaning. If this happens, use a dry cloth and buff the screen in a small circular motions.
  • Microdisplay Rear-Projection - All microdisplay TVs have some sort of screen shield on the front. These TVs should be cleaned with a damp cloth. Microdisplays with a shiny screen shield can be cleaned with a mild soap if extremely dirty. Those with a flat screen shield should not be cleaned with any cleaning agents. Do not use paper products to clean the front of the TV because they could scratch the screen surface.
  • Plasma - Plasma owners should clean the front of the TV with a soft, damp cloth. The use of a mild soap for heavy cleaning is acceptable. The use of heavy cleaning agents could strip the special coatings on the screen, and paper products can scratch the front of the TV.
  • LCD Flat Panel - Be careful with flat panel LCD TVs! Use a slightly damp soft cloth to clean the LCD screen, then immediately dry with a soft cloth. Do not press ******* the screen during cleaning. Doing so could cause severe damage to the display. Do not use any cleaning solvents, such as glass cleaner or soaps, to clean the LCD screen. Paper products could scratch the front of the screen. If you have a pet or child that rubbed something on the screen that you feel could stain or damage it, contact your local TV service center for assistance.
When dusting the TV cabinets, dust with a damp cloth or a mild cleaner. Paper products can scratch the surface of high-gloss cabinets, so avoid paper products. Heavy cleaners can strip the finish off of TV cabinets over time. When cleaning speaker grilles, dust with a dry cloth. Wet cleaners could stain or damage the grille cloth.
Hope this may help;
DON'T FORGET TO RATE:
Sep 06, 2008 | Toshiba 55H70 55" Rear Projection...
Cleaning screen on my 1080i hd panasonic????
GA_googleFillSlot("TL-Leader-Article"); Hope this may help; DON'T FORGET TO RATE;
Aug 31, 2008 | Panasonic PT-47WX51 47" Rear Projection...
Screen
  • LCD Flat Panel - Be careful with flat panel LCD TVs! Use a slightly damp soft cloth to clean the LCD screen, then immediately dry with a soft cloth. Do not press hard on the screen during cleaning. Doing so could cause severe damage to the display. Do not use any cleaning solvents, such as glass cleaner or soaps, to clean the LCD screen. Paper products could scratch the front of the screen. If you have a pet or child that rubbed something on the screen that you feel could stain or damage it, contact your local TV service center for assistance.
Oct 25, 2007 | Hitachi 51G500 51" Rear Projection...
Stain on screen
most of the time you wont get these types of stain out but sometimes they do come out. what i use is monster screen clean. if it doesnt come out you will need to replace the sreen. they usuall run from 75 dollars to 150
Aug 31, 2007 | Sony KP-ER43M61 43" Rear Projection...
GREEN LINE ON PROJECTION TV
I hope you have repaired this concern by now, but if you have not there are cleaners one can buy at local electronic retail/part stores made for cleaning your bs screens, or your can use a mild soap such as dawn with a damp, soft cloth. Make sure you wipe up&down, not side to side. i hpoe this was helpful.
Apr 10, 2007 | Toshiba 43A10 43" Rear Projection...
Open Questions:
Toshiba 57H93 57" Rear Projection HDTV Logo
163 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
