Question about Panasonic DMR-E80H DVD Recorder
Panasonic DVD recorder
Self checks for too long
A self-check for these models can sometimes last for 3-7min's (sometimes longer) depending on how much recorded data is on your hard drive. Plus it checks all unrecorded space on your hard drive as well. Don't forget that it must check 200Gig. If it self checks for longer than 20-30mins turn off at the wall and let cool down. Try again in an hour or so and it should rectify itself. If it continues to self-check for longer than 20-30mins refer your machine to an authorized technition
Posted on Dec 02, 2007
SOURCE: PANASONIC DVD RECORDER STUCK ON
This can usually be down to two things, a faulty PSU board which is going to be expensive and needs to be professionally repaired, or simply a faulty or dirty DVD has been inserted into the machine.
Try the following:
1. Hold down Standby and Eject buttons on front panel together for 60 seconds (until the recorder goes into standby mode).
2. Now hold down Eject button until it ejects the disc.
3. Now insert a different DVD disc and see if that cures the problem.
If that fails then it's probably a faulty PSU, and unless the recorder is under guarantee or warranty it will be too costly to repair.
Posted on Jun 20, 2009
SOURCE: my panasonic dvd recorder is showing error screen
My DMR-EZ47V was displaying error U61 after developing a fault while trying to load a disc. It seems it is sensitive to some brands of disc. I managed to get the disc out and after that it instructed press OK button. On doing so it ejected disc tray and switched off. Subsequent efforts of switch ON/OFF just came up with the same failure. Eventually after placing a known good recorded disc it managed to recover and return to normal.
Posted on Jul 05, 2009
Palmbeach
  • 185 Answers
SOURCE: Panasonic DMR-E55 DVD Recorder
Ok guys, you asked for a fix for the DMR E55 Self Checking cycle. Here goes.
In 99% of cases this is caused by a faulty regulator on the main power board. The power board is located on the right hand side of the unit. The regulator is IC001 which is mounted on a thin metal strip which acts as a totally inadequate heatsink. This means that this component constantly works at temperatures beyond its tolerance. Because of this it usually lasts a couple of years and then starts causing problems. The Self Checking syndrome is typical. If the regulator burns out completely, it can take other components with it, blow fuses and scorch the circuit board.
If you are competent in using a soldering iron with care, order an STRG 6353 regulator. These can be obtained online from a number of suppliers. Disconnect your DMR E55 from the power source and remove the lid.
Next, remove the fixing screws from the circuit board on the right where the regulator is located. Carefully remove the multi connector on the left side of the board. Remove the screw above the power connector on the rear of the unit. The power board can now be removed from the cabinet. Using a small pair of wire cutters, clip all five pins from the old regulator as close the the top of the board as possible. Undo the screw securing it to the heatsink and remove the old regulator which can now be thrown away.
Next, using your soldering iron, remove what's left of the pins from the printed board and with a solder sucker or desoldering braid, clear the holes ready to accept your new regulator. Be careful because if you over heat the print it can lift away from the board.
Use a little heatsink compound on the back of your new regulator, poke the pins through the circuit board and then secure it to the heatsink. I usually fit an extra heatsink on these units which helps to reduce heat and prolong the life of the new component.
Next, resolder the 5 pins on the print side of the board. Use a magnifying glass and make sure you haven't missed anything or bridged connections in error and caused short circuits.
Now put the board back. This can be a little trick but it's easy enough if you take care. Replace all the screws and carefully reconnect the multi connector.
If you have followed this correctly, switch the unit back on, pop in a DVD and give it a try. Unless you are very unlucky, You DMR E55 will no longer repeatedly self check and will operate correctly. Whilst it saddens me to hear that some of you guys would toss your DMR E55s into the trash can for such an easily repairable problem, please do not attempt this unless you are confident in your own ability.
Finally, do check that the fan operates but remember it is temperature controlled and will not activate until it is needed. Do not assume it is faulty because you do not see it working straight away. I have repaired lots of DMR E55s and I have never found a single fan or fan control circuit to be faulty. That's not to say it can't fail. good luck...
Posted on Jan 15, 2008
SOURCE: Stuck in self check mode
Manually pull down the front shield, then somewhat forcefully pull down the inner shield and maybe two little white pins so the tray is exposed with nothing blocking it. Have someone plug the machine in while you are holding everything out of the way and the tray should start to open. Pull your fingers out quickly so you don't block the tray from sliding out.
Posted on Apr 02, 2008
DR NITIN
  • 221 Answers
SOURCE: My Panasonic DVD Video Recorder
It needs repairs. You should take it to the Service Center.
Posted on Jun 25, 2008
My panasonic dvd model DMR-55 won't turn on and the digital clock is not even working when I plug it in. How do I get the dvd in the machine out?
My Panasonic is stuck on self check when a new DVD is inserted?
It turns on and other functions are in-accessible during this self check
Any help greatfully appreciated.
Feb 15, 2010 | Panasonic DMR-E55 DVD Recorder
Self checking
I have had a Panasonic DMR-E85 with this exact same problem you are describing. As I bought a Freeview Dual-tuner PVR I just bought a second-hand DMR-E55 as I liked the Panasonic interface. Two months down the line it is now exhibiting the exact same problems, except now as well as the continual self-check rebooting, it's also refusing to eject the disk. Booo. Time for me to buy a new DVD recorder again, and this time certainly not Panasonic... :(
Dec 04, 2009 | Panasonic DMR-E55 DVD Recorder
Recorder keeps 'self checking' then taking dvd back to begining, although only on recordable dvd's, not rented. Are recorders worth repairing or are you better just buying another?
Dec 02, 2009 | Panasonic DMR-E55 DVD Recorder
Panasonic DMR-ES15 DVD recorder startup failure
The unit failed during self check, probably the power regulation board. A check by a qualified TV/VCR repair person is in order.
Nov 20, 2009 | Panasonic DMR-E55 DVD Recorder
Panasonic DMR E65 cycling in self test on start up
Check the IC in the primairy power supply,common fault.
Jul 22, 2009 | Panasonic DMR-E65 DVD Recorder
Self check will not stop
Hi
This is very common, please see my earlier posting which will tell you how to repair it, by clicking the link.
DMR E55 Self Checking Repair
Best wishes
Mar 21, 2009 | Panasonic DMR-E55 DVD Recorder
Recorder self-check... after inserting a disc.
Inserting a disk OTHER than Panasonic will cause a system crash. I'm betting Panasonic has code that causes this so you don't use cheaper generic DVDs. I now have to mail order the Panasonic DVDs (since nobody carries them) and have never had a crash since!
Jan 30, 2009 | Panasonic DMR-E85H DVD Recorder
Will my non finalzied discs play on a panasonic ez 28 or ex 768
You will have no problem playing your non finalized discs on any of the Panasonic DMR range including the DMR EZ28 series. The DMR E55 can also easily be repaired if you can use a soldering iron and a little care. Please checkout my other postings for full repair details.
Cheers...
Oct 08, 2008 | Panasonic DMR-E55 DVD Recorder
Stays in self check mode
If self check keeps going after 1 minute unplug machine and open top cover remove 4 screws that hold the recorder top cover remove disk reinsert screws and plug in see what happens.
Most of the time a small scratch or fingerprint on recorded disk cause these units to lock up
Jul 18, 2008 | Panasonic DMR-E55 DVD Recorder
Panasonic DMR-E80H DVD Recorder Logo
248 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
