Question about Yahoo YHT-630 System
Curtis dvd 2047 - Trouble Shooting
I can see and hear my DVDs but how do I get the normal television channels to come out on the speakers?
  • 2 more comments
  • manageit Nov 30, 2007
    I hooked up the splitter and did get the sound, unfortunately I can not control the loud sounds/volume.
    Any tips for this?
  • Anonymous Dec 08, 2007
    System works fine then when I go DVD fine, but returning to Cable/Sat I don't get sound thru Bose speakers.
  • Anonymous Dec 29, 2007
    Can get sound through speakers when playing dvd's and cd's but no sound from normal channels. tried an optic cable from unit to tv but still nothing. any suggestions?! its the HT-TX35 model.
  • PaulRo Jan 29, 2008
    I have the same problem. I can get the sound from any component but can only control the volume when it is hooked up tp the DVD player the speakers came with. The speakers do not have a separate volume control and can only be controlled by the remote for the DVD. Even when the remote with the dvd is set at volume 0 if I connect the input to the satellite the volume booms out a loud level.
Esto es un dvd de basural lo compre unos 4 meses me travajo y ya no serve el audio nose escucha
Posted on Aug 18, 2008
Yes, buy a good dvd player. This one is more junk from china.
We did not get through 2 dvd movies and have lost audio.
Posted on Jul 09, 2008
  • 115 Answers
What provide the picture to your TV? (cable or Sat).
If you use either of these then on the back of the boxes are outputs, Video (yellow) and Audio (red / White). if you put the audio output to your amp you will get sound thru your speaker but will need to select (what ever input choice where you plugged in red / white) the input on the amp when viewing TV.
A better solution would be to place a splitter (RCA so that the audio can still go to TV and the Amp) from each color. So when you don';t want the amp on you still have audio on your TV.
Posted on Nov 29, 2007
  •  Larry
    Larry Nov 30, 2007
    Ok now you get sound, but you didn't say which unit you were using for the volume. If you split the signal from the cable box then that gives you the initial volume control. If set loud then you will have little control!
    try lowering the volume of the cable box (using reomte supplied with box) then try raisng or changing the volume of your Amp.
    If you are now able to vary the volume using the amp , then you only need to find a happy medium betweenthe two.
    Sometimes you may need to lower the volume of the TV, if your Tv settings may have an audio set up, you might try telling TV you are using external speakers.
    Making any of these changes does no harm, just make a few notes and circle the change that gives you the best response and write / print out how you did it. Sometimes I put the paper under the amp or tape it to back of TV so I can easily locate it.
Curtis DVD 2047 - It has been working great then when we turned it on tonight, we could only get a tiny bit of sound from the speakers. We have checked to make sure everything is still plugged in correctly and checked mute buttons and anything else we could think of.
Posted on May 18, 2008
Curtis mathes tv cannot change aux back to normal channel like three. how do you get to get dvd from aux to normal channel.
Just contact the folks at the link below:
They are great a helping folks with problems with their Curtis Mathes televisions and stereos; and they do it for free :)
Feb 22, 2014 | Televison & Video
I want to know how to change the preset channels on my remote
first use the remote to enter the menu and look for channel setup--you should be able to add or delete single channels that way.
Oct 30, 2012 | Curtis CMC13101 Combo
YAMAHA RXV 350 Right Speaker not Working
The amplifier for this channel is NOT working.
Feb 09, 2012 | Yamaha RXV-350 Receiver
While moving my parent's Curtis Mathes Cm19001 TV produced in 1999, I touched the channel button which took the TV off of channel 3. We've tried to use the channel buttons to return to channel 3,...
I have one of this tv model too.Just used a RCA component cables like Y,R,W hook one side to the tv Video IN INPUT holes and the VCR the other end of the cable to VCR Video OUT INPUT holes.Now just pushes a channel manual button up or down a couples for the tv go into VIDEO Mode.Play the dvd player it will work.Or try to buy a tv original remote.Return the universal remote.
Jun 18, 2011 | Curtis-Mathis CM19011 TV
My home theatre was connected successfully playing the cd movie, but after turning off the dvd and go back to watching tv the sorroung system speakers do not give a sound to the television. is it that i...
select tv input on ur theater system. u can hear audio fro the frond left and right speakers. if u want to hear the audio from the surround speakers, then press the A-MODE button on ur remote to select different type of sound modes. press again and again to select different sound field. select one which suits u.
Dec 27, 2010 | Curtis DVD5091 Theater System
No television channel mode , when i go to source and go to TV it reverts back to DVD. I need to get to set-up to program channels and it will not allow me. If I messed up the initial channel scan how do I...
Hello, Try a soft reset, unplug the TV from the AC outlet then reconnect, then power the TV on. You should get some kind of a start up menu. If you don't then make sure you're DVD is operating normally there might be something wrong with the disc player and that is why it is reverting to disc pick up or disc load.
Sep 28, 2010 | Curtis Televison & Video
I am not able to hear the dialog while playing DVDs. The background is great and comes through all 5 speakers, however, to be able to listen to the dialog, I have to switch over to 2-channel or Stereo. ...
Well let me first ask is the center chanel working? or properly hooked up. Cause most of the times when in 5.1 the talking or "dialog" as you put it comes only through the center channel its just kinda how they do it. Listen to see if the center channel is working. if you are unsure try hooking up a speaker that you know works into the center channel speaker output. If no sound comes out then the reciever possible has blown its center channel. Please follow up with a comment and i will be glad to assist you further thanks, Midwes-tek
Sep 17, 2010 | Coby DVD765 Theater System
Sound on DVDs
It sounds like she has the player set to output 5.1 surround sound, but only has left and right channel speakers hooked up. Either change the dvd player to only send two channels or hook up a center channel speaker.
Jan 01, 2009 | Computers & Internet
Curtis Mathes TV Remote Control Codes for Programming the remote to the TV
I own a One-for-All universal remote, and my booklet says the setup code for a Curtis Mathes TV (without a built-in DVD or VCR) is one of the following numbers: 0030, 0047, 0054, 0060, 0093, 0145, 0154, 0166, 0451, 0702. I can not guarantee these numbers will work with your remote, but it is worth a try.
Jul 03, 2008 | Curtis-Mathis CM32010 TV
Yahoo YHT-630 System Logo
367 people viewed this question
Top Yahoo Audio Players & Recorders Experts
Greg Ulan
micky dee
Are you a Yahoo Audio Player and Recorder Expert? Answer questions, earn points and help others
